Subwoofer Mounting Depth Question
Discussion in 'Audio & Video' started by 1999cutiger, Jun 2, 2018.
  1. Jun 2, 2018 at 1:26 PM
    1999cutiger
    1999cutiger [OP] Community Organizer
    2017 Toyota Tundra SR5 4x4
    RBP 67R AK-8 20x9 wheels Nitto Ridge Grapplers 275/55/20
    I have a 2017 Tundra CrewMax and I am thinking about building a sub box to install behind the back seat. I am trying to determine what my maximum mounting depth should be for the subwoofer drivers themselves....in a box that will be a good tight fit behind the seat....using 3/4” MDF.
    Does anybody have a recommendation for a safe mounting depth for the drivers themeslves? There are so many subwoofers out there with so many different mounting depths...I just want to make sure they will fit depth wise in a typical size box.
    Thanks in advance for your help....
  2. Jun 5, 2018 at 4:12 PM
    1999cutiger
    Nobody? Wow...tough crowd.
    Alright, I found the 10” shallow mount sub I want to use where mounting depth won’t be an issue. Can anybody tell me what dimensions I should use so that the box is wedged between the wall and the seat back nice and snug? I realy just need the bottom depth, top depth, and the angle of the face. I can determine the width of the box based on the sub requirements for internal air volume. I plan on installing this box directly behind the center portion of the seat (behind the fold down arm rest). 2017 Crewmax
  3. Jun 5, 2018 at 4:43 PM
    Larmand
    Larmand Im 100% correct, part of the time! TTC #145
    Lucas
    Fort Worth, TX
    I cant answer your question, but if you look up the JL stealth box, I'm sure dimensions will be posted. Then you can cut the length in half for 1 sub. It's what I would do if I were building my own box.
  4. Jun 5, 2018 at 4:52 PM
    louscrw
    louscrw all jacked up on Mt. Dew
    Lou
    Warner Robins, Ga
    2017 MGM CM Limited 4WD
    in signature
    Here are the dimensions of my box straight from their website
    It’s a dual 10” box. I have JL TW3 subs
    Width 50”
    Height 12”
    Top Depth 3.5”
    Bottom Depth 6.5”
  5. Jun 5, 2018 at 4:56 PM
    1999cutiger
    Thanks guys...very helpful.
  6. Jun 5, 2018 at 4:58 PM
    1999cutiger
    Do these dimensions make for a good snug fit behind your seat?
  7. Jun 5, 2018 at 5:00 PM
    louscrw
    Lou
    Warner Robins, Ga
    in signature
    Yes, I have speaker grills on the subs, it is very snug.
  8. Jun 5, 2018 at 5:05 PM
    1999cutiger
    Sounds like exactly what I’m looking for....thanks bud.
  9. Jun 5, 2018 at 5:07 PM
    louscrw
    Lou
    Warner Robins, Ga
    in signature
    I tried to take a pic for you, but it’s hard to get my phone back there. This is the best I could do.
    You can see the box is flush against the back of the seat. The plastic you see is the trim on the seat covering the hinge
  10. Jun 5, 2018 at 5:14 PM
    1999cutiger
    Wow...yeah, that looks snug alright...thanks for the pic!
    Just to clarify, the dimensions you posted are the outside dimensions of the box with 3/4” mdf?
  11. Jun 5, 2018 at 6:51 PM
    Beerdude77
    Beerdude77 New Member
    2018 Silver Sky Tundra Limited TRD CM
    Linex bed, "Toyota" Console Safe
    What's your motivation for only going with 1 sub? And Go Tigers!
  12. Jun 5, 2018 at 7:16 PM
    1999cutiger
    Honestly, I’m 42 and I have two girls who routinely ride in the back seat. I just want something that sounds good without being “over the top”. My days of cranking up Kid Rock to 11 are over...
  13. Jun 5, 2018 at 7:17 PM
    louscrw
    Lou
    Warner Robins, Ga
    in signature
    Yeah, should be outside dimensions..not sure about the material used. Here is the link to the box...http://www.audioenhancers.com/vehiclespecific/tuncm110.php
  14. Jun 5, 2018 at 7:43 PM
    Beerdude77
    That was honestly the exact same route I had planned to go too for nearly the exact same reasons (age and 2 young boys) But then after realizing the space behind the seat is not accessible anyway I started having second thoughts, then I learned about having a bass remote knob that can control the bass and I am so glad I went with 2. It fills the music better and on those classic songs that I used to jam to in my teens/20's I can bump as loud as I can stand and turn it down whenever I pull up to a stop light or have the fam with me. I installed my knob just below the notch in the center console for a cord to sit in when the console is closed right where my hand hangs when driving and is so easy to control without even thinking about it. Just something to consider so you don't do a lot a work and then later wish you had added the second one. This isn't my truck but the picture of the bass knob is exactly where I put mine:
    http://www.diymobileaudio.com/forum...ta-tundra-crewcab-xsp-x-sq-audio-build-2.html
  15. Jun 6, 2018 at 3:54 PM
    1999cutiger
    Just when I had myself convinced one 10” sub would be sufficient....you come along with all your logic and stuff...lol.
    You’re right....I should get 2. When my wife gets super pissed I’ll give her your contact info...lol.
    What are the specs on the box you are using?
  16. Jun 6, 2018 at 6:20 PM
    Beerdude77
    I have a ported box but am getting a sealed box on Friday. I'll take measurements of both once I install the sealed box likely Sunday night at the earliest since I have to go out of town this weekend.
  17. Jun 6, 2018 at 6:28 PM
    Beerdude77
    Oh and just tell her that a stereo system is cheaper than a new convertible, trip to Vegas, or younger girl friend for your "mid life crisis" lol
  18. Jun 7, 2018 at 4:15 PM
    1999cutiger
    I would really appreciate that....thank you.
  19. Jun 7, 2018 at 4:15 PM
    1999cutiger
    Hell yeah....she should be thanking me.
    Beerdude77 likes this.
