Subwoofer box build
Discussion in 'Audio & Video' started by Toyotech16trd, Aug 30, 2016.
  1. Aug 30, 2016 at 9:25 PM
    Toyotech16trd
    Toyotech16trd [OP] New Member
    Ohio
    16 inferno trd crewmax
    Interior led conversion, wheel well leds
    Has anyone built there own box for 3rd Gen crewmax.
  2. Aug 30, 2016 at 9:32 PM
    Check out tacotumes.com specializes nothing but Tundras...I have a CM that came with a system in it. it has a box that has 2 10" fits snug
  3. Aug 30, 2016 at 9:33 PM
    Oops sorry never measured it either not ported it's sealed
  4. Aug 30, 2016 at 9:36 PM
    Toyotech16trd
    Ohio
    Yea, I've been on there site... was just wondering if anyone had the specs on the box. I was thinking about building a box, just trying to save some time. Thanks tho
  5. Aug 31, 2016 at 6:18 AM
    Bminus
    Bminus New Member
    I built one in my 14 crewmax for 2 Stereo Integrity BM MKIVs. Its got roughly .6ft^3 per side. I believe the dimensions were something like 52"W X 18" H X 6.5" D1 X 2.5" D2
    There is also a bolt that's connected to the rear window motor on the passenger side. I made an indention in my box where this bolt was because the box would not sit straight. I also cut my stock sound barrier on the back wall in order to fit the box better (You may not have to do this, Im not the best at box building).
    I can't remember how much taller I could have made the box, but I do know that 52" is about the max width to keep it perfectly between the back seats when they are folded up, and 6.5" is gonna be about as deep as you can fit it at the bottom and still have plenty of clearance for the sub.
    I recommend a grill for your subs so that you can have piece of mind that they aren't hitting the back seat because its gonna be close.
    Also, I recommend lots and lots of closed cell foam between the box and back seat. My back seat rattled pretty bad at first, adding foam to just about everywhere I could made a significant difference, but I still need to add more. On really high volumes the head rests rattle lol.
    AnonVet likes this.
  6. Aug 31, 2016 at 6:25 AM
    Toyotech16trd
    Ohio
    Thanks buddy, you just saved me a whole lotta time.
  7. Aug 31, 2016 at 6:29 AM
    Bminus
    Bminus New Member
    No Problem, I still recommend measuring yourself though. LOL
    You may be able to play with the top depth and height in order to change the angle of the wedge and get a better fit.
  8. Aug 31, 2016 at 6:42 AM
    Toyotech16trd
    Ohio
    You got 10" or 12" subs? Do you have any pics?
  9. Aug 31, 2016 at 6:44 AM
    Bminus
    Bminus New Member
    They are 12" shallow subs.
    No I haven't taken any with the box in the truck
  10. Aug 31, 2016 at 6:47 AM
    Toyotech16trd
    Ohio
    I was thinking 2 10s not sure yet tho
  11. Sep 5, 2016 at 11:34 AM
    AnonVet
    AnonVet That's what she said!
    Weatherford TX
    2015 TRD SR5 CM
    7 inch pro comp 35x12.5 RPB Repulsars (Hate'em) 18x9 Rhino Glamis Bilstein 5100's TRD Pro grille Murdered out Spyder heads Smoked tails Leds all around her Debadged Go Rhino BR5 Front Bumper
    If you could post up some pics of your set-up that would be great. I've been looking into doing this but I've only seen setups that are under the seat. And i personally like that space for randomness.
  12. Sep 5, 2016 at 12:13 PM
    Toyotech16trd
    Ohio
    A few pics of the mock box out of cardboard using the specs given above.20160905_145952.jpg 20160905_145952.jpg 20160905_150045.jpg 20160905_151031.jpg
  13. Sep 5, 2016 at 12:16 PM
    Toyotech16trd
    Ohio
    It fits perfectly, I've already had my seats out and checked. Of course you have to adjust measurements depending on the thickness of wood u plan on using. I'll post pics of actual build when i start maybe next weekend.
  14. Sep 5, 2016 at 12:20 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
