Stuck Key
Discussion in '2nd Gen Tundras (2007-2013)' started by Liz22kmc, Feb 18, 2020.
  1. Feb 18, 2020 at 1:19 PM
    Liz22kmc
    Liz22kmc [OP] New Member
    Liz
    2011 DC SR5 4.6L Tundra
    Hey all! My key is getting stuck in the ignition in the ACC position. Any quick fixes to get this sorted out?
    If no quick fixes, what part should I be prepared to replace?
  2. Feb 18, 2020 at 1:26 PM
    15whtrd
    15whtrd Mr. Blonde
    How about some key graphite. Typically you use that stuff on a new lock to help get it worn in. At least that’s what a locksmith told me. And spraying it with anything ultimately can lead to it gumming up. I think I would try a silicone spray since it dries. Also does it help if you jiggle your steering wheel to get the key to go back to the proper position?Otherwise it’s probably the lock cylinder either worn out or in need of some love.
    NewImprovedRon likes this.
  3. Feb 18, 2020 at 1:28 PM
    Johnsonman
    Johnsonman New Member
    Austin
    Sequoia
    A good locksmith is best to check it out. My older 4runner's key got stuck, locksmith made a repair for $50 compared to a few hundred for a new tumbler. Now has a feature where key can be removed in any position, kinda handy...
    bleach, Liz22kmc[OP] and 15whtrd like this.
  4. Feb 18, 2020 at 1:29 PM
    Liz22kmc
    Liz
    It seems like the only thing that will get it out is turning the ignition on and off a few times while reversing and pulling forward, almost like to straighten out the steering wheel.
    15whtrd[QUOTED] likes this.
  5. Feb 18, 2020 at 1:29 PM
    15whtrd
    15whtrd Mr. Blonde
    That’s actually the best solution if you can’t free up yourself. A good locksmith should be able to remedy that no problem. And if ultimately it needs new parts, he’s your man.
    Liz22kmc[OP] likes this.
  6. Feb 18, 2020 at 1:32 PM
    15whtrd
    15whtrd Mr. Blonde
    If you’re not into trying to take it apart yourself. I would just hit up a good locksmith. They might be able to take apart the tumblers and get it all going for you.
    Liz22kmc[QUOTED][OP] likes this.
  7. Feb 18, 2020 at 9:24 PM
    FWD Tundra
    FWD Tundra New Member
    Washington
    2013 Tundra 4WD Double Cab
    I would say spray some good electrical contact cleaner in it then use (after it evaporates) the graphite as mentioned in an earlier post.
