Stuck in park
Discussion in 'Lighting' started by Lol, Jul 9, 2017.
  1. Jul 9, 2017 at 8:20 PM
    Lol
    Lol [OP] New Member
    Tommy
    Tx panhandle
    2016 limited tundra
    2.5" lift,black out badges,gunner wheels, retractable tonneau cover.
    I installed new spider tail lights on my 2016 limited. As it turns out didn't get wires right blew fuse. I then reversed plugs on them put in new fuse and works all is good until I tried to drive it and it won't come out of park. The owners manual is no help at all it doesn't have a list or anything like a list I guess you have to guess. Thanks in advance
  2. Jul 9, 2017 at 8:31 PM
    Check the wiring again, on both. Be sure you're also replacing with the corrct fuse.
    To get out of park- remove the small square cover to the left of the shifter.
    Stick a pen or something else in, and you'll be able to get out of park.
  3. Jul 10, 2017 at 7:11 AM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    To add a little to what @Sean266 said. I have read that if you have a brake lamp out (or not plugged in or some sort of open circuit in the brake light circuit) the truck can't be shifted from park and you'll need to use the method outlined above. I've only read this and keep telling myself that I need to pull a bulb to try to verify this, but I keep forgetting to do this when I'm tinkering.
    nk1794 and joonbug like this.
  4. Jul 10, 2017 at 10:53 AM
    niru316
    niru316 New Member
    2017 Tundra TRD Pro CrewMax
  5. Jul 10, 2017 at 3:51 PM
    Lol
    Lol [OP] New Member
    Tommy
    Tx panhandle
    2016 limited tundra
    Thanks a lot guys the brake light fuse was burnt out also appreciate the good info on tundras.com
    equin, nk1794, T-Rex266 and 2 others like this.
  6. Jul 10, 2017 at 6:11 PM
    kenomouth64
    kenomouth64 New Member
    Tetrus
    2007 Toyota Tundra Sr5 4x4 (TRD Off Road) Crewmax 5.7L
    Hold the Line! If you are not holding the line, abandon your ship. Destruction is inevitable without more to hold the line!
    Well that is good to know...
    I can envision myself being in the same dilemma and going mad trying to figure out what was going on.
    nk1794 likes this.
  7. Sep 27, 2018 at 5:58 AM
    Dgray1961
    Dgray1961 New Member
    This just happened to me. I tried the @T-Rex266 suggestion and was able to get my truck in gear. Got home, replaced the 15a STOP fuse, and fixed the problem. Thanks guys.
    jrquist, Bob, nk1794 and 1 other person like this.
  8. Sep 27, 2018 at 6:03 AM
    Tacogrande
    Tacogrande New Member
    Jeremy
    2016 SR5 dbl. cab long bed gray
    Husky weatherbeaters,short antenna,window deflectors
    I remember reading in the manual about how to insert something into the secret opening by the shifter if the truck is stuck in park...its good to know.
    nk1794 likes this.
  9. Feb 7, 2021 at 11:12 AM
    Pringle
    Pringle New Member
    2012 Tundra
    Check the STOP fuse under the hood. It is marked on the inside of the fuse box.
    jrquist likes this.
  10. Feb 7, 2021 at 12:09 PM
    blackdemon_tt
    blackdemon_tt Battery Slayer
    Pretty sure, they figured it out....
    T-Rex266 likes this.
  11. Nov 15, 2021 at 1:22 PM
    Exile824
    Exile824 New Member
    2016 Tundra Crewmax
    I also have a 2016 Tundra with Spider aftermarket LED taillights. I had to replace a taillight recently. Bought the replacement Spider taillight from CARiD. Truck has now blown that 15 amp STOP fuse twice causing the transmission to lock in park. I have notified CARiD and am sending a work order from my mechanic. Mechanic said the frequency of the LED lights was causing the problem. Anyone else heard this?
