Stubby antenna, freaking waste of money!
Discussion in '2.5 Gen Tundras (2014-2021)' started by Buster1, Jan 3, 2020.
  1. Jan 23, 2020 at 4:56 AM
    Crunch527
    Iowa
    TRD Supercharger/BAM
    Antenna design is tied to the technology in the antenna and the reception frequency...mostly its physics and there are limits to what can be done and not impact reception performance.
    It’s Why the “stubby” antennas 1) don't perform as well as the OEM antenna and 2) its why our trucks didn’t come from the factory with a stubby antenna. If it did come from the factory with a stubby antenna we’d all be bitching that the radio in our brand new truck was garbage and there would be threads all over this forum about how Toyota effed it up;)
    In some cases if you are close to the radio station broadcast antenna with good line of sight, the stubbier can work ok. Reality says, For most of us it doesn’t work out that way.
    I hate removing my stock antenna stalk for the car wash but could give two effs as to what it looks like. It just needs to work and I HATE static on my local radio stations.
    I have thought about getting an electric antenna but they can be a pain in the ass too because they typically have nylon gears and those eventually wear out.
    Cheers
    Black Wolf likes this.
  2. Jan 23, 2020 at 5:01 AM
    MikenMike
    MikenMike New Member
    RACEtruck
    I got the original too bc i thought it would attract more chicks...now i have no chicks and no reception....i switched back to the oem...and atleast get good reception meow
  3. Jan 23, 2020 at 5:13 AM
    This^^^^^. I've tested several different stubbies of various lengths and none of them had improved reception over OEM. How could they? The shorter stubbies totally failed up in the mountains here which was to be expected and the OEM performed way better up there. I went to OEM on my 07 and will be going back to OEM on my 14.
    Nothing to do with XM though.
  4. Jan 23, 2020 at 5:13 AM
    9am53
    9am53 New Member
    adam
    2015 Black RCLB 4x4
    2020 PRO headlights and grill
    I have a 13" rydonair, or something like that and it works perfectly. I have to tighten it up once in a while, but otherwise I get fine reception and it looks great.
  5. Jan 23, 2020 at 5:15 AM
    Tchase
    Tchase MostlyLurk
    Buckley WA
    2019 White Tundra Limited
    In work
    I was getting static with my oem, perhaps you can have too much signal like OTA tv
  6. Jan 23, 2020 at 6:14 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Same, mine works fine but I bought it mainly for looks.
    Outbound[QUOTED] likes this.
  7. Jan 23, 2020 at 6:37 AM
    WrigglingWilly
    WrigglingWilly Well used Member
    2018 Tundra 4x4 5.7 8.1bed
    LineX
    I bet OPs antennae was built in the sweat shop when they had the new 5 year olds in for training. The 8 year old techs usually do a better job.
    plumber802 likes this.
  8. Jan 23, 2020 at 6:38 AM
    9am53
    9am53 New Member
    adam
    2015 Black RCLB 4x4
    I got mine for looks and because while reversing under some tree branches I had the stock antenna whip my windhsield once and my A pillar once, the second of which bent the antenna. I dont want my wiindshield cracking or paint chips in my truck...
  9. Jan 23, 2020 at 6:41 AM
    bryand
    bryand New Member
    Alabama
    2010 4.6L 2wd DC Black
    Bilstein 5100
    I too got mine mostly for looks but haven't had any issues with it. My factory one was bent at the base or I probably wouldn't have replaced it. Half the time I use my phone over Bluetooth anyway since the radio is on commercials.
  10. Jan 23, 2020 at 7:26 AM
    9am53
    9am53 New Member
    adam
    2015 Black RCLB 4x4
    FYI, for the canadians out there eading this thinking they want a shorter antenna - about a week after I paid 25 bucks for mine from Amazon I noticed Canadian Tire has a roughly 12 or 13" long short antenna in stock with the car audio section for like 15 bucks...I would have gotten that had I had known.
  11. Jan 23, 2020 at 8:04 AM
    FlipMonkey21
    FlipMonkey21 New Member
    Mark
    SoCal Glendale
    2019 Toyota Tundra 4X4 Sport
    2019 Toyota Tundra Crewman TRD Sport Kings 2.5 Front & Rear suspension Camburg UCA Method Wheels MR312 18X9 +18 Offset 5x150 matte black w/toyo open country RT 35x12.5R18 tires Toyo Open Country RT 35X12.50 R18LT 123Q 10 P.R TRD Front Sway Bar (Removed) TRD Rear Sway Bar ( Removed) Carven Cat-Back Kit (torque 65lbs to 70lbs of torque) Windows tint Bakflip MX4 Bed Cover TRD CAI NSV air compressor AJT Design chrome delete NSV Light Bar Diode Dynamics 42" light bar Diode Dynamics SS3 Max Pod CBI Full Skid Plate CBI Lower Control Arm Shield Sibi Built regear Revolution 5.29 Harrop rear lockers Rigd mega swing Wheel lock Deaver springs U-748 King 3x16 650 Coil springs
    bought one for like $30 from Amazon and it works fine but all depends on where I'm driving but rarely use my radio have google play. :) Pretty much just bought mine for looks.
    BravoDeltaRomeo likes this.
  12. Jan 23, 2020 at 12:58 PM
    1fujifilm
    1fujifilm New Member
    Bear
    19 Tundra Crew
    I agree with Ferguson, XM is separate and uses the antennae on the roof. Why Yo can't integrate the two like Chev is beyond me.
    I use XM only and on day one I take off the screw in antennae and put a plastic bolt in until I sell it.
    I go from 15MPG to 15MPG due to the reduction in wind resistance (no gas savings, just a joke).
    Bear
  13. Jan 23, 2020 at 1:14 PM
    nodak67
    nodak67 New Member
    JR
    just remember this is from very old memory ...
    automotive antenna are quarter length of the wave (based on the middle of the fm band which is around 100) which comes out to ~31 inches. as long as you are doing the length as a division of 2 (1/2 wave) or 4 (quarter wave), the reception should come out ok.
    if you go by that reasoning in your post, then the XM antenna shouldnt work, but in reality if you break open a XM antenna, it has a coil around 31 inches inside if i remember correctly from an old shark fin taken apart.
  14. Jan 24, 2020 at 12:34 AM
    Crunch527
    Iowa
    Yes you are correct...the technology in the antenna...in other words how the antenna is designed. My guess is the stubby antennas are based 1/4 wave design assumptions and 1/4 wave antennas are less efficient (low impedance) than 1/2 wave (higher impedance).
  15. Jan 24, 2020 at 4:13 AM
    GELCW
    GELCW New Member
    Erik
    Northern Virginia
    2018 Gray Tundra Platinum
    I tried it too, and it didn't work for me either. I just returned it.
  16. Jan 24, 2020 at 4:23 AM
    Woodtickmp
    Woodtickmp Black beast/beauty/pearl
    Mathew
    west bend WI
    2010 tundra double cab black TRD rock warrior
    3in front leveling kit with camburg engineering upper A-arms, 2in block in the rear and 6 pack leafs, 295/65/17
    I know you are talking about stubby antennas but I removed mine and ordered a antenna splitter for my cb radio and it works great. I only have one antenna.
    TTund16 likes this.
  17. Jan 24, 2020 at 4:52 AM
    BravoDeltaRomeo
    Bruce
    MB Canada
    2019 Cavalry Blue Tundra CM
    So to sum this entire thread up.....
    - You won't know if it works until you try it.
    - They are NOT all junk.
    - Buy from somewhere you have a chance to return it.
    - They look cooler and won't break in an auto carwash.
    - XM will work with or without your OEM wire antenna.
    - Chicks don't dig stubbys: size does matter.
    Anything else?
  18. Jan 24, 2020 at 5:33 AM
    9am53
    9am53 New Member
    adam
    2015 Black RCLB 4x4
    Size matters...like I always tell the ladies - It may not be long, but it sure is skinny
  19. Jan 24, 2020 at 5:40 AM
    #49
    mrburns05
    mrburns05 New Member
    Jacob
    Menifee CA.
    2018 4.6L White DC SR5
    Maxtrac 3.5” Spindles Bilstein 6112 Icon AAL Icon 2.5” PB shocks Coachbuilder +1 Shackles AFE dry filter TRD AIA Magnaflow muffler TB Coolant Bypass
    Radio? People still use that? I will admit I bought my stubby just for looks
    TTund16 and RebelRide93 like this.
  20. Jan 24, 2020 at 7:13 AM
    #50
    Rocman
    Rocman New Member
    Randall
    Reno, NV
    2019 Tundra Platinum
    Sorry to hear the stubby's not working for you...I've installed this one and have had -0- issues. Good luck!
    AntennaMastsRus - The Original 6 3/4 Inch is Compatible with Toyota Tundra (2000-2020) - Car Wash Proof Short Rubber Antenna - Internal Copper Coil - Premium Reception - German Engineered
  21. Jan 24, 2020 at 7:51 AM
    #51
    TunaDr
    TunaDr New Member
    2007 Tundra
    I joined to see what is possible
    I live in city center more or less and when I removed oem antenna my radio still worked with all the channels I listened to. I threw on the stubby for looks after that. Drive all up and down southern california and still get radio just fine.
  22. Jan 24, 2020 at 10:12 AM
    #52
    Crunch527
    Iowa
    ok...I'll play...I ordered one...if it works and I dont have to take it off for the car wash I'm happy...I will follow up next week.
  23. Jan 24, 2020 at 11:10 AM
    #53
    TTund16
    TTund16 New Member
    Anytime I say who is this singer never heard of them ... My wife laughs and says because they are not on AM. lol
    Btw if your antenna hits your garage door and/or under ceiling storage, they sell one that is only 2-3" shorter and I haven't noticed ANY performance issues.
  24. Jan 24, 2020 at 11:42 AM
    #54
    9am53
    9am53 New Member
    adam
    2015 Black RCLB 4x4
    Mine is not supposed to go in a car wash (not that I’d ever go into a drive through car wash anyways) but like I mentioned earlier my original long antenna got hung up on some brush and whipped towards the truck and smacked it on 2 separate occasions. This ended up loosening the base...it pulls away from my truck a lot more than I’m comfortable with, I’d be more worried about that than bending a cheap antenna.
  25. Jan 24, 2020 at 11:50 AM
    #55
    9am53
    9am53 New Member
    adam
    2015 Black RCLB 4x4
    Here is mine from a bit of a distance, ive posted this pic elsewhere, but here it is for those who havent seen it.
  26. Jan 25, 2020 at 11:49 AM
    #56
    mrburns05
    Jacob
    Menifee CA.
    I actually have used the xm and Fm a couple times here and there and the antenna seemed to work fine. It was a cheap $12 4” one from Amazon, came from China or something
    edit: I also plasti-dipped it because a pc was carbon fiber replica and I just wanted black
  27. Jan 25, 2020 at 1:27 PM
    #57
    Kojack
    Kojack New Member
    MIke
    Black Mountain, NC
    2017 Tundra XSP CrewMax
    I just put mine on yesterday and I have to say, I hear no difference from the stock whip. Stations come in clear with no static. I’m please with it.
