Stubborn O2 sensor
Discussion in 'Other Toyota Vehicles' started by tja1080, Mar 5, 2019.
  1. Mar 5, 2019 at 5:45 PM
    tja1080
    tja1080 [OP] New Member
    TJ
    Whidbey Island WA
    2016 Platinum
    I’m putting an after market exhaust on my wife’s 2012 IS350 and the O2 sensors won’t budge... sprayed with PB blaster, no joy. Any tricks that I’m not aware of?
    I’m thinking that I’m going to have to get it on the lift and use a breaker bar of some sort.
  2. Mar 5, 2019 at 7:50 PM
    Geezer
    Geezer New Member
    Heart of the Catskills
    2019 Tundra Limited
    Heat. Heat the bung up with a propane torch until it glows red.
    driverdog likes this.
  3. Mar 5, 2019 at 8:18 PM
    Vince
    Vince New Member
    Vincent
    Terre du lac, Missouri
    2011 White DBL cab 5.7
    K&N intake, Air bags
    You could just drive it until it's hot and try to tighten it first once you get a turn then you should be able to take it out.
  4. Mar 5, 2019 at 9:33 PM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    2012 and you’re trying to swap the original sensors over to the new exhaust? Sounds like the perfect time to install some new Denso sensors to me.
    tja1080[OP] likes this.
  5. Mar 6, 2019 at 5:40 AM
    tja1080
    TJ
    Whidbey Island WA
    2016 Platinum
    I have the socket set. I’m letting it marinate in some PB blaster for now. Ordered new sensors last night. When the sensors come in I’ll take it to the hobby shop on base and get it on a lift.
