Stripped T30 Bolt (Bed Rails)
Discussion in '3rd Gen Tundras (2022+)' started by SithLord92, May 22, 2022.
  1. May 27, 2022 at 11:15 AM
    #91
    Mater
    Mater New Member
    Nick
    SD
    2016 MGM Platinum
  2. May 28, 2022 at 7:22 AM
    #92
    SithLord92
    SithLord92 [OP] New Member
    2022 Supersonic Red SR5 Premium
    Bolt is out!
    raylo, mlive, 316KS_Runner and 3 others like this.
  3. May 28, 2022 at 7:25 AM
    #93
    Retired...finally
    :cheers::yay:
  4. May 28, 2022 at 7:47 AM
    #94
    Rubberdown
    Yeeeeeehaaaaaaa! What worked?
  5. May 28, 2022 at 8:04 AM
    #95
    Blang805
    Blang805 New Member
    Central Coast California
    2010 CrewMax Platinum 4x4
    Build in Signature
    this is such a cliff hanger... HOW DID YOU DO IT
  6. May 28, 2022 at 8:17 AM
    #96
    Wixo
    Wixo The Best Member
    Mawr
    RGV
    5.7L 4x4 CrewMax SB
    Tint
    Last resort-ish, get a socket that barely almost fits around it. Hammer it into the torx. Pull ratchet it out.
  7. May 28, 2022 at 8:37 AM
    #97
    19TurdPro
    19TurdPro New Member
    2019 Tundra TRD Pro
    Hey man, I just spent 15 minutes reading thru 4 pages of your saga while taking a shit. I can't feel my fucking feet anymore. You're gonna leave us hanging like that?
  8. May 28, 2022 at 8:46 AM
    #98
    Teegee
    Teegee Around
    Grouch
    21 MAX
    Post of the month
    mlive, Donas, SithLord92[OP] and 2 others like this.
  9. May 28, 2022 at 8:53 AM
    #99
    Retired...finally
    Yeah. I wanna see who wins the internet for the day.
    Wixo likes this.
  10. May 28, 2022 at 10:56 AM
    #100
    DanSanDiego
    DanSanDiego New Member
    2019 Tundra Limited 4x4
    Really glad you were able to get it free. This forum has been great.
    SithLord92[OP] likes this.
  11. May 28, 2022 at 11:49 AM
    #101
    SithLord92
    Lmao, sorry guys! I’ve been busy so I haven’t been updating as frequently. Thank you all for your input and advice, you have no idea how appreciative I am.
    The method I used was the dremel. Slotted it deep enough to get a flathead in, and pounded the shit outta it to get it to turn, now it’s out!
    raylo, Donas, 316KS_Runner and 2 others like this.
  12. May 28, 2022 at 12:29 PM
    #102
    Tundragrappler
    Tundragrappler New Member
    northeast
    2020 Tundra TRD Pro
    stock
    212067E8-6FA9-4DE3-BCE1-D69F604D5559.jpg Nice that you got it fixed.
    I had the same problem on my 2020. I had the dealer install a drop-in bed liner, which required them to remove the rails and reinstall. When I bought my tonneau cover and started the install, I found I had several stripped heads on the rail bolts. I couldn't find a dremel grinder to get in there to cut a slot, so I used an oscillating tool with a metal blade to do it.
    Even then, I had to use a heavy duty screwdriver in the slot, and turn it with a pair of channel locks to get one of the bolts out. I broke the blade on one of the screwdrivers. What a pain in the butt. When I went to the local dealer (not the one where I bought it) the parts guy selling me the replacement bolts said that they are often overtorqued from the factory, which may be true, but I think mine were made worse by the dealer employee who used a rattle gun and possibly the wrong sized torx bit.
  13. May 29, 2022 at 9:03 AM
    #103
    SithLord92
    Tonneau is also on and was a breeze.
    mlive and DanSanDiego like this.
  14. May 29, 2022 at 2:44 PM
    #104
    FALQN
    FALQN New Member
    Midnight Black, 4x4 Crew, TRD Sport
    OEM Running Boards, Wheel Locks, Hard Cover, Home-made Kicker Sub
    Post of the week!!! Can’t stop laughing…even shared with the wife.
    JPritch, raylo and Retired...finally like this.
  15. May 29, 2022 at 4:48 PM
    #105
    Donas
    Donas New Member
    TN
    22 Tundra Platinum
    Congrats! Did you try that Milwaukee tool I linked? Everyone needs one of those in the toolbox, a million uses.
    I guess it wasn't the China flu you had, back in business too soon....
  16. Jun 8, 2022 at 12:40 PM
    #106
    nrm91
    nrm91 New Member
    Boise, ID
    2022 Platinum CrewMax Magnetic Grey
    35/11.5/20 Toyo AT III's
    What size Dremel wheel did you use? I have literally the same exact issue right now.
  17. Jun 8, 2022 at 12:44 PM
    #107
    Donas
    Donas New Member
    TN
    22 Tundra Platinum
    I used a standard cut off wheel in an angle grinder, worked perfect. The whole job took minutes.
  18. Jun 8, 2022 at 1:08 PM
    #108
    nrm91
    nrm91 New Member
    Boise, ID
    Did you have to cut the slit at an angle? If I hold my Dremel cutting disc at 90 degrees, the disc is not big enough. But I can cut at an angle
  19. Jun 8, 2022 at 1:20 PM
    #109
    Donas
    Donas New Member
    TN
    22 Tundra Platinum
    No, that's exactly why I used an angle grinder vs Dremel; the cutting disk is so much larger.
  20. Jun 8, 2022 at 2:00 PM
    #110
    nrm91
    nrm91 New Member
    Boise, ID
    What size grinding wheel did you use? 4.5" x 1/4" ??
  21. Jun 8, 2022 at 2:01 PM
    #111
    Donas
    Donas New Member
    TN
    22 Tundra Platinum
    Harbor freight cheapy
  22. Jun 8, 2022 at 2:40 PM
    #112
    Rubberdown
    Glad you got it all squared away OP. You da man!
    NewImprovedRon likes this.
  23. Jun 8, 2022 at 3:23 PM
    #113
    nrm91
    nrm91 New Member
    Boise, ID
    So you grinded it down with that, then used the flathead screwdriver? Is 7/8" not too thick?
  24. Jun 8, 2022 at 3:46 PM
    #114
    Donas
    Donas New Member
    TN
    22 Tundra Platinum
    7/8 is the arbor size, the disk is 1/16 thick. I just made a cut across the center and used a huge flat head screw driver.
  25. Jun 16, 2022 at 7:01 AM
    #115
    Firemedic1428
    Firemedic1428 New Member
    2022 Blueprint Platinum CM
    The term you are looking for is JIS (Japanese Industrial Standard). I have a 1984 Honda Nighthawk motorcycle I'm restoring, and a good quality Vessel impact driver and JIS screwdrivers are the first tools I bought for this project. You can tell its a JIS if it has a "." engraved in the cap of the screw.
  26. Jun 16, 2022 at 9:13 AM
    #116
    Retired...finally
    When I first started with Honda in 1973 I was gived two T handle screw drivers. Still have them and use them to this day
  27. Feb 26, 2023 at 5:12 PM
    #117
    Moon
    Moon New Member
    2013 Tundra grade crewmax
    The link was unavailable, can you send again please.
  28. Feb 26, 2023 at 5:30 PM
    #118
    Donas
    Donas New Member
    TN
    22 Tundra Platinum
  29. Feb 27, 2023 at 2:34 AM
    #119
    RookieEP
    RookieEP New Member
    2020 Tundra Limited TRD Magnetic Gray
    None
    This is what I did with same issue when I had my 2020
  30. Feb 27, 2023 at 8:13 AM
    #120
    Moon
    Moon New Member
    Thank you for this thread! My New Peragon tonneau has been sitting on porch for over 2 mos. All 8 rail bolts are trashed on my 2013
    I’m going to harbor freight tonight!
