Stripped T30 Bolt (Bed Rails)
Discussion in '3rd Gen Tundras (2022+)' started by SithLord92, May 22, 2022.
  1. May 22, 2022 at 5:37 PM
    #61
    Rubberdown
    Get in there with the dremel and slot it!!! Go go go!
    Moon likes this.
  2. May 22, 2022 at 5:39 PM
    #62
    shawn474
    shawn474 Lego connoisseur
    MoCo, Maryland
    This 100%
  3. May 22, 2022 at 5:43 PM
    #63
    SithLord92
    SithLord92 [OP] New Member
    2022 Supersonic Red SR5 Premium
    No, I don’t have anything the right size. They’re either too big or too small. It’s gonna coke off one way or another. My biggest thing is probably just being afraid to really screw something up.
  4. May 22, 2022 at 5:45 PM
    #64
    xtyfighterx
    xtyfighterx New Member
    Ty
    North Idaho
    2015 Black Crewmax Mid Travel
    Left hand drill bit
  5. May 22, 2022 at 6:12 PM
    #65
    Donas
    Donas New Member
    TN
    22 Tundra Platinum
    Go to Home Depot tomorrow and get one of those flat heads I linked. You'll use it all the time after this.
  6. May 22, 2022 at 6:17 PM
    #66
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    Try to do it like we get broken wheel lock lug nuts off.
    Find a socket that is just a tad smaller than the bolt head and hammer it on.
    Put your rachet or impact driver on it and back it out.
    Would that work??
    https://youtu.be/o3QiFX1Rstc
    No way would I take this to the dealer, I'd be too embarrassed..:eek2::thumbsup:
    SithLord92[OP] likes this.
  7. May 22, 2022 at 6:27 PM
    #67
    SithLord92
    You guys are awesome!
    Moon likes this.
  8. May 22, 2022 at 6:42 PM
    #68
    Teegee
    Teegee Around
    Grouch
    21 MAX
  9. May 22, 2022 at 6:44 PM
    #69
    Donas
    Donas New Member
    TN
    22 Tundra Platinum
    1lowlife likes this.
  10. May 22, 2022 at 6:48 PM
    #70
    Teegee
    Teegee Around
    Grouch
    21 MAX
  11. May 22, 2022 at 6:52 PM
    #71
    Rubberdown
    That ain’t gonna work or fit. Slot it! slot it! You can do it!
  12. May 22, 2022 at 9:05 PM
    #72
    1lowlife
    DADA
    2014 MGM DC SR5
    That would be my first choice.
    A cutting wheel on a Dremel would make a nice screwdriver slot..
    If that didn't work you just keep cutting on the bolt head enough with a Dremel wheel and you could probably pop/chisel the head off with a big flat blade screwdriver and a hammer.
    Then a left twist drill bit would probably get it out.
    Sounds like it is too tight for left twist drill bits right now.
  13. May 22, 2022 at 10:17 PM
    #73
    Wahayes
    Wahayes Older I get the wiser I realize my dad was
    Will
    2017 tundra limited *sold*
    325/60r20 falken at3w, 2.25 dobinsons ,20x9 +20 fuel torque wheels, leer xr100, bmc
    You're going to have so many bad ass fucked bolt head screw tool doodads after this thread it's gonna be awesome!!! Lol you're going to be like the flex seal guy " I have a tool for that":goingcrazy:
  14. May 22, 2022 at 10:27 PM
    #74
    Diablo169
    Diablo169 ROKRAPR
    Max
    Santa Cruz
    06 Double Cab 360k+
    2” Lift, Bilstein 5100’s and 885’s second notch, Rear 5100’s Icon 3 Leaf Pack and Firestone Air Bags w/Daystar Cradles. Spider Trax 1.25” Wheel Spacers, 4Runner Pro Wheels, Falken AT3W 285/75r17 (34x11).
    Yeah bro, slot it and use an impact driver. Just did the same on the rock buggy the other day.
    Damn Allen heads on U Joint straps!
    Moon, 1lowlife, Mater and 2 others like this.
  15. May 22, 2022 at 10:46 PM
    #75
    Wahayes
    Will
    Allen heads suck. I had to slot one today (used a hacksaw) that stripped on a brand new winch. Needed to remove the clutch housing to clock it.
    Diablo169[QUOTED] likes this.
  16. May 23, 2022 at 3:05 AM
    #76
    Retired...finally
    When it comes to removing stuck fasteners, listen to the guy with 290k on his truck for he knows what he's doing.
    Diablo169[QUOTED] and Donas like this.
  17. May 23, 2022 at 3:13 PM
    #77
    Donas
    Donas New Member
    TN
    22 Tundra Platinum
    Well OP?.....
  18. May 23, 2022 at 3:16 PM
    #78
    Retired...finally
    I hope he doesn't post a picture of a drill bit sticking out of the outside of the bed.
    murtro, Wahayes and Donas like this.
  19. May 23, 2022 at 3:20 PM
    #79
    22PlatWCP
    22PlatWCP New Member
    Mississippi
    2022 WCP Platinum 4x4
    :ohsnap:
  20. May 23, 2022 at 3:29 PM
    #80
    DanSanDiego
    DanSanDiego New Member
    2019 Tundra Limited 4x4
    I work in the rigging industry and have a lot of experience with frozen and stripped fasteners. One trick we had a lot of luck with was using an easy out and grinding the tip down so that it is a tight fit in the head of the bolt (where the torque bit would go). You want it to be just a bit tight so you need to hit with a hammer so it seats nicely in the head of the bolt. You can find a cheap set on Amazon or your local Harbor Freight.
    Another option is to use a flathead screwdriver that is the perfect size so that if you hit it with a hammer it wedges in to the torque head.
    Try heating up the fastener if possible to soften any loctite that an installer may have used. Sometimes people use red loctite instead of the temporary blue loctite.
  21. May 23, 2022 at 4:59 PM
    #81
    SithLord92
    Didn’t even attempt today, I feel like garbage today, woke up very sick.
  22. May 23, 2022 at 5:00 PM
    #82
    SithLord92
    Don’t think I’d go that far lol.
  23. May 23, 2022 at 5:01 PM
    #83
    Retired...finally
    Hope you feel better. Now, go back to bed and come back tomorrow and we'll have 42 more things for you to try. Just don't use a longer drill bit than what is necessary.
  24. May 23, 2022 at 5:05 PM
    #84
    SithLord92
    I used shorter drill bits when I initially drilled and tried to extract. And thank you, I’m never sick and I can usually power through, but this knocked me on my ass today.
  25. May 23, 2022 at 5:51 PM
    #85
    Donas
    Donas New Member
    TN
    22 Tundra Platinum
    Your truck says, you can run but you can't hide.
    Hope tomorrow is better.
  26. May 23, 2022 at 6:10 PM
    #86
    SithLord92
    I hope so too, it was so bad they literally told me to go home after two hours of work. Just didn’t have the energy to do anything but shower, drink water, and lay in bed.
  27. May 23, 2022 at 6:22 PM
    #87
    Donas
    Donas New Member
    TN
    22 Tundra Platinum
    You got the China flu?
    22PlatWCP likes this.
  28. May 24, 2022 at 6:18 AM
    #88
    SithLord92
    Not sure what it is, think it’s just a regular flu. But I do know this is a rough one.
  29. May 24, 2022 at 7:32 AM
    #89
    Wahayes
    Will
    All you need is a 2ft drill bit and and wall plug in electric drill with too much torque..... that ought to do it ! lol
  30. May 27, 2022 at 9:43 AM
    #90
    DanSanDiego
    Have you been able to get the stripped fastener out yet? Just wondering
