Stripped bolt
Discussion in '2.5 Gen Tundras (2014-2021)' started by mikefen1985, Jan 1, 2020.
  1. Jan 1, 2020 at 11:12 AM
    Pinay
    Pinay New Member
    Monet
    Mahal kita Kuya
    Lots of options OP!! Good luck! Let us know how you do!
  2. Jan 1, 2020 at 11:56 AM
    mambo143
    mambo143 New Member
    Phil
    Maine
    2016 Tundra TRD Crewmax
    Bilstein 6112, 5160, Coachbuilder 1” shackle lift, Wildpeak A3’s, LED backup, Maxiplus mats, Bak Rollover Mx4, BedRug, Westin HD Headache Rack. Westin HD Brush Guard, Spidertrax 1.5 spacers. TRD Brakes. Headlight Revolution LED. TRD rear Torsion Bar. Dirty Deeds 10 inch Stainless. TRD Pro Grill. Bushwhacker Pocket Flares. Baja Designs Combo Driving/Fog lights.
    If the nut is still in place, try fastening a pair of vice grips to the bolt head and turn counter clockwise while pulling down. it may catch the thread and then you can remove it.
  3. Jan 1, 2020 at 12:08 PM
    JohnLakeman
    Outside of Weird, TX
    2017 MGM DC TSS 4.6L
    The weld nut has not broken free if the bolt is tightening 1/2 turn then quits tightening. If the weld were broken loose, it wouldn't tighten even a 1/2 turn, it would just free-wheel.
    To remove the stripped bolt, pull down on the head as you slowly turn the bolt counter-clockwise (Lefty-Loosey). Even better, insert a BIG flat screwdriver under the head and use that to lever down on the head as you turn. You can probably get the bolt out. Then you need to decide if it's the bolt or the weld nut that is stripped by examining the bolt threads closely. Stripped threads can be hard to see sometime; maybe just a single cut across a thread, not necessarily all of them boogered.
    Try a fresh bolt, and get it started straight WITHOUT the bracket in the way the first time. If you begin to feel unusual resistance after less than two turns, you're probably still not started straight, or you're trying to use a common thread in a metric hole. Because you've boogered the threads, there may be a little more resistance, but not like before. If you used the aftermarket hardware, it's likely the bolt that stripped. I would have more faith in OEM hardware than aftermarket China-made; i.e. use the Toyota bolts if they're still there.
  4. Jan 1, 2020 at 2:08 PM
    mikefen1985
    mikefen1985 [OP] New Member
    Western mass
    2024 Tundra SX package
    Thank you for the good information
  5. Jan 1, 2020 at 2:28 PM
    JohnLakeman
    The better term is not "stripped" but "cross-threaded". You've managed to get the first few threads cross-threaded by starting the bolt crooked.
    If you can get the old bolt out, and overcome the cross-threading by carefully starting a fresh bolt straight, you probably won't have to do any re-tapping. If you have a metric tap with the right thread, you could use it to very carefully clean up the cross-threading in the weld nut, but that can be dangerous without experience and is probably not essential. The original Toyota bolts like those are self-tapping...they were originally driven into a virgin unthreaded weld nut with a power tool. If you get one started crooked, it will cut new threads or mess up the old threads.
    Good luck.
