STravis Go Anywhere, Camp Anywhere Build
Discussion in '2.5 Gen Builds (2014-2021)' started by STravis, Jun 28, 2020.
  1. Dec 4, 2024 at 5:32 PM
    #661
    STravis
    STravis [OP] SOB Fabrication Vendor
    Travis
    Ruidoso, NM
    17 TRD Pro CM, 08 Supercharged Single Cab
    I got the wheel and tire pulled this morning and located the leak. Sure enough, it's about a 2.5-3" crack in the wheel that is blowing air like crazy.
    Another thought I had today was that maybe I cracked it slightly on one of our wheeling trips and throughout all the highway driving the last couple weeks the crack heat cycled and started to spread. Just a theory.
  2. Dec 4, 2024 at 5:40 PM
    #662
    CaptRussia253
    CaptRussia253 New Member
    Ruslan
    Glad you found it before the wheel disintegrated.
  3. Dec 4, 2024 at 7:34 PM
    #663
    STravis
    Travis
    Ruidoso, NM
    You and me both! Could have been a wild ride for sure.
    Now let's see if I hear back from Black Rhino about a warranty.
  4. Dec 5, 2024 at 6:28 AM
    #664
    CaptRussia253
    Ruslan
    If they don't warranty the wheel just sell the other 4 and get something else. I want to see some polished beadlocks on the truck :rofl:
  5. Dec 5, 2024 at 7:09 AM
    #665
    STravis
    Travis
    Ruidoso, NM
    I think polished would look sweet. I don't even know what wheel I would run anymore, I wish SCS would come out with a 17".
  6. Dec 5, 2024 at 8:45 AM
    #666
    CaptRussia253
    Ruslan
    My SCS do fit nicely compared to the SSWs. More tire options are coming out for 18s.
    I'm a big fan of KMC wheels or Methods with bead grip.
  7. Dec 7, 2024 at 2:20 PM
    #667
    STravis
    Travis
    Ruidoso, NM
    I think I'm going to sell the black rhino wheels and get these methods.
    They are dirt cheap at the moment, have bead grip, and have a higher capacity.
    The black rhino warranty process has left quite a bit to be desired. I'm not sure if they'll replace it or not until after I ship it to them.
    Anybody interested in a set of 4 or possibly 5 wheels? One will be brand new if they warranty it.
  8. Dec 7, 2024 at 3:11 PM
    #668
    CaptRussia253
    Ruslan
    I really like those. What are the specs?
    STravis[QUOTED][OP] likes this.
  9. Dec 7, 2024 at 5:55 PM
    #669
    STravis
    Travis
    Ruidoso, NM
    17x8.5, 0mm offset and 2650 load max load.
    CaptRussia253[QUOTED] likes this.
  10. Dec 7, 2024 at 6:22 PM
    #670
    CaptRussia253
    Ruslan
    0mm offset, yes! Excited to see what you do to fit 39s with that offset.
    Im looking at 39s and wife is super happy :rofl:
  11. Dec 7, 2024 at 6:38 PM
    #671
    STravis
    Travis
    Ruidoso, NM
    I actually had a guy give me some 40's so it will be with 40's. I'm actually on 10mm offset now so it won't be too much wider. About .394" further out.
    I say order 39's right now!
  12. Dec 7, 2024 at 6:39 PM
    #672
    JrJrOffroad
    JrJrOffroad Somewhere in the west
    Anthony
    Monument, CO // Cave Creek, AZ
    Not sure if you have had bead grip before but you are gonna really like them. I ran them on my jeep and I could run sub 8 PSI every time I went wheeling with no issues.
    CaptRussia253 and STravis[OP] like this.
  13. Dec 7, 2024 at 7:14 PM
    #673
    STravis
    Travis
    Ruidoso, NM
    I haven't had them before, but I've heard really good things. I'm really not wanting to go to a different wheel but they should be an upgrade.
    SAGE63 and CaptRussia253 like this.
  14. Dec 7, 2024 at 7:59 PM
    #674
    CaptRussia253
    Ruslan
    There’s a local guy to me selling a new set of 39x12.5 kanati mud hogs I might have to snag.
  15. Dec 7, 2024 at 8:17 PM
    #675
    STravis
    Travis
    Ruidoso, NM
    I say do it. I can't remember, are you regeared?
    JrJrOffroad likes this.
  16. Dec 7, 2024 at 8:18 PM
    #676
    CaptRussia253
    Ruslan
    No but 4.30s work just fine :rofl:
  17. Dec 7, 2024 at 8:24 PM
    #677
    STravis
    Travis
    Ruidoso, NM
    Haha I'd start the gear research and saving now if you're even looking at 39's. You know you'll end up there anyways.
  18. Dec 8, 2024 at 6:06 AM
    #678
    CaptRussia253
    Ruslan
    True. I have the money saved up now just waiting on a few things first. 5.29s are on the to do list for sure. I might just do a rear limited slip instead of lockers though.
  19. Dec 8, 2024 at 7:45 AM
    #679
    STravis
    Travis
    Ruidoso, NM
    I'm running a powertrax in my rear and it works pretty well. If I did it again it would have e lockers front and rear.
  20. Dec 8, 2024 at 9:53 AM
    #680
    CaptRussia253
    Ruslan
    Why is that? I like the idea of not worrying about air or line possibly getting damaged.
  21. Dec 8, 2024 at 10:30 AM
    #681
    STravis
    Travis
    Ruidoso, NM
    With the e locker you don't need to worry about having a compressor, air leaks aren't an issue and you don't need to worry about an air leak in the diff pressurizing everything causing leaks..l
  22. Dec 8, 2024 at 12:06 PM
    #682
    CaptRussia253
    Ruslan
    Didn’t know they made an e locker for the Tundras! Well that changes things up.
    Edit: Just noticed you said e locker originally haha my bad.
  23. Dec 8, 2024 at 12:28 PM
    #683
    STravis
    Travis
    Ruidoso, NM
    @n0rth has them and likes them. He should have more feedback on them for you
  24. Dec 8, 2024 at 2:50 PM
    #684
    SAGE63
    San Diego County
    love my 701 bead grips in bronze 18x9 +25, with 37s not in the 39s crowd... stuffs nicely and no rubbing.
    STravis[OP] and CaptRussia253 like this.
  25. Dec 8, 2024 at 3:47 PM
    #685
    STravis
    Travis
    Ruidoso, NM
    My 39x12.50 works really well on my 10mm offset wheels, but I am getting a set of 40x13.50's for free so tubbing is in my future anyways so I might as well go 0 offset and just cut everything.
    TOYOTARIG and CaptRussia253 like this.
  26. Dec 13, 2024 at 9:40 AM
    #686
    STravis
    Travis
    Ruidoso, NM
    Quick question for some of the people following my build before I decide whether or not to make a separate post.
    I had a Tacoma come into the shop this week with the bumper mounts completely torn off from some abuse. We rebuilt the bumper mounts and beefed them up and tied in a couple gussets to make sure it won't happen again. Would there be any interest in possibly designing a kit for the tundra that beefs up the bumper mounts before they get destroyed? It would be a weld on kit and it would probably retain the factory inner stud and replace the outer studs with 1/2" bolts. Any thoughts?
    PXL_20241212_184749454.jpg PXL_20241212_184753540.jpg PXL_20241212_204353118.jpg PXL_20241212_204901120.jpg PXL_20241212_231755072.PORTRAIT.jpg
  27. Dec 13, 2024 at 9:59 AM
    #687
    Mater
    Mater New Member
    Nick
    SD
    2016 MGM Platinum
    Is it a cut and weld or just weld? Cut and weld I, personally, would get cold feet.
    Not sure if you’ve seen the Demello bumper’s support bracket but it wraps around and bolts through the frame and is pretty slick other than it interferes with pretty much all shock reservoirs. This is a photo I have of a fellow member here. The bolt goes through where the red circle is. Just something to think about..
  28. Dec 13, 2024 at 10:24 AM
    #688
    STravis
    Travis
    Ruidoso, NM
    I'm not sure how we would do it yet, possibly just remove the outer studs, drill out the holes and then weld on the plate and gussets. I've seen brackets like those, we do something similar for the tundra that utilizes the tow hook bolts, this would just be supplemental to aftermarket brackets like the one you referenced. Just extra strength to keep it from bending from impacts, winch pulls and general off-road use. The flimsy stock metal fatigues fairly easily.
  29. Dec 17, 2024 at 6:32 PM
    #689
    STravis
    Travis
    Ruidoso, NM
    The new methods came in yesterday and I got them mounted today. I didn't like the style as much as the black rhinos right out of the box but once I got them on the truck I liked them better. The color is a better match for the cement also. I like the kind of rallyish look of these.
    I'll get the black rhino's listed for sale after I get them cleaned up. The 5th wheel replacement should ship early January unless something weird happens with the warranty.
    PXL_20241216_224928887.PORTRAIT.ORIGINAL.jpg PXL_20241217_182553122~2.jpg PXL_20241218_002614967.PORTRAIT.ORIGINAL~2.jpg PXL_20241218_002626381.PORTRAIT.ORIGINAL~2.jpg PXL_20241218_002649542.NIGHT~2.jpg PXL_20241218_002707818.NIGHT~2.jpg PXL_20241218_002725102.NIGHT~2.jpg PXL_20241218_002734762.NIGHT~2.jpg
  30. Feb 2, 2025 at 7:22 PM
    #690
    STravis
    Travis
    Ruidoso, NM
    I installed a start x remote starter and ordered some husky floor liners for the truck last week. Nothing crazy going on on that front.
    We took it up to Colorado this weekend and picked up a new ride for my wife. This one will end up being a fun project I think.
    37's are on the way for it already. I'm going to repurpose the old black rhino wheels for this and I ordered some kanati terra commander rtx tires for it. Less than $1,400 for 5 from priority tire so I couldn't pass them up.
    Then it will be getting high clearance bumpers and a roof rack.
    PXL_20250202_004622598.PORTRAIT.ORIGINAL.jpg PXL_20250201_162752042.jpg PXL_20250201_171703968.PORTRAIT.jpg
