STravis Go Anywhere, Camp Anywhere Build
Discussion in '2.5 Gen Builds (2014-2021)' started by STravis, Jun 28, 2020.
  1. Dec 14, 2022 at 6:13 AM
    #331
    STravis
    STravis [OP] SOB Fabrication Vendor
    Travis
    Ruidoso, NM
    17 TRD Pro CM, 08 Supercharged Single Cab
    It feels massive sometimes too, especially when I'm trying to follow that FJ60 through some trails.
  2. Dec 30, 2022 at 8:51 AM
    #332
    STravis
    Travis
    Ruidoso, NM
    I added some traction boards and some additional diesel storage for the heater. I should be able to get about 5ish super cold full nights out of the heater now without having to get diesel.
    PXL_20221226_221635918.PORTRAIT.jpg PXL_20221226_221627141.PORTRAIT.jpg PXL_20221226_221613336.PORTRAIT.jpg
  3. Jan 8, 2023 at 4:41 PM
    #333
    STravis
    Travis
    Ruidoso, NM
    Did a little camper maintenance today. Cleaned some of the interior out, replaced the water pump fuse that was blown, organized a few things and lubed all the zippers on the sleeping bag and awning bag. Also ran the heater for a bit to blow some crud out and make sure it was all still functioning. Hopefully getting out next weekend for some cold camping.
    I'm also tossing around the idea of replacing the rear camper door and tailgate with a single piece and a large door that opens to the side or barn style doors.
  4. Jan 8, 2023 at 6:15 PM
    #334
    helidave
    helidave Hellacopter
    flagstaff
    2015 DC 4x4
    Did you ever make a battery warmer setup?
    Wallygator likes this.
  5. Jan 8, 2023 at 8:22 PM
    #335
    STravis
    Travis
    Ruidoso, NM
    I still haven't messed with it. I figured if I'm using the camper and need all the accessory power I will also have the heater going and heating the space where the battery lives. It will discharge down to 0*F and we haven't had any long stretches of weather like that in a while.
  6. Jan 25, 2023 at 6:23 PM
    #336
    STravis
    Travis
    Ruidoso, NM
    I got a piece of gravel stuck in my rear brakes a couple weeks ago so I ended up needing to swap pads and rotors. The rock chewed up the pads and rotor both before I could get it all taken care of. I also installed a diff drop that has helped a ton.
    Also, on our last camping trip we had a gust of wind rip out guy lines out for our awning and break a couple of the arms. I'm working with OVS currently trying to get something done as far as fixing it or replacing it.
    PXL_20230125_161601267.PORTRAIT.jpg PXL_20230125_161614167.PORTRAIT.jpg PXL_20230125_161706796.PORTRAIT.jpg
  7. Jan 25, 2023 at 6:51 PM
    #337
    2mchfun
    I have found shade sails work better than most canopies because the material is mesh vs solid. They take a little longer to set up, but they are cheap, lightweight, and effective. No, I don't camp in the rain. Just an option!
  8. Jan 25, 2023 at 7:09 PM
    #338
    STravis
    Travis
    Ruidoso, NM
    I love the 270 just due to how quickly we can set it up and tear it down. One of the biggest selling points was being able to pop it open on the side of the trail for breaks and keeping the kiddo out of the sun. I just need better stakes than what I was using.
  9. Feb 10, 2023 at 3:16 PM
    #339
    STravis
    Travis
    Ruidoso, NM
    OVS got us up and running again. They sent me two new arms and a new hinge bolt.
    I also ordered the awning walls to add to it for extended camp spots and bad weather.
    PXL_20230204_184847273.PORTRAIT.jpg PXL_20230204_221507786.PORTRAIT.jpg PXL_20230204_221536700.jpg PXL_20230204_221547429.PORTRAIT.jpg
  10. Feb 14, 2023 at 7:01 AM
    #340
    Djayyykiddoh
    Djayyykiddoh New Member
    Deej
    Eastvale CA
    2021 WCP Tundra Platinum
    I had bought the same OVS Awning late last year and it that arm snapping at the weld happened to me as well.
    Im thinking about switching mine up to their new 270LTE one, the arm design seems a bit different. My bed rack sits right below roof level so their regular 270LTE one rubbed against my cab so i had to recess it back about a foot off the bed. :(
    STravis[QUOTED][OP] likes this.
  11. Feb 14, 2023 at 7:12 AM
    #341
    STravis
    Travis
    Ruidoso, NM
    I don't fault OVS at all for the arms breaking in my situation. A huge gust of wind ripped the stakes out of the ground and if the arms didn't break I'm pretty sure it would have destroyed the awning brackets or the camper side. I like the bigger awning and mounting it to camper makes it clear the cab by quite a bit. The new LTE awning is an awesome choice for bed racks for sure though.
  12. Mar 13, 2023 at 3:01 PM
    #342
    STravis
    Travis
    Ruidoso, NM
    I have added a bunch of communication stuff recently. I put in a ham radio, added a weboost on a folding mount and we also picked up a Garmin inreach messenger. Now that we have a kid I would really like a way to get a message in or out in case of any emergencies.
    PXL_20230313_170600037.jpg PXL_20230313_170609931.jpg PXL_20230313_171228330.PORTRAIT.jpg PXL_20230313_171237836.PORTRAIT.jpg
  13. Mar 13, 2023 at 3:12 PM
    #343
    Punisher29073
    Punisher29073 New Member
    Ryan
    White Knoll, SC
    2019 Tundra TRD Pro
    Clearance lights, Light bar in front bumper, Ditch lights, CB Radio, AGM Battery, SLEE Sliders,
    Interested in the helpfulness of the weboost.
  14. Mar 13, 2023 at 3:14 PM
    #344
    STravis
    Travis
    Ruidoso, NM
    The area we live in and commute through has spotty service and so far I've noticed I can talk on the phone a lot further into the dead zones than I could before. There are still a couple areas where my phone won't work but it's a lot better than before the weBoost.
  15. Mar 13, 2023 at 3:24 PM
    #345
    Wallygator
    Very smart! An with the way things are going in this world I believe this should be my next focus. Which model ham radio and weboost did you go with? If you took the ham test, how was it? Did you take a course or self study?
  16. Mar 13, 2023 at 4:10 PM
    #346
    helidave
    flagstaff
    2015 DC 4x4
    How do you like that radio? I've been looking at the same one.
  17. Mar 13, 2023 at 4:43 PM
    #347
    STravis
    Travis
    Ruidoso, NM
    I'll like the radio here : https://www.amazon.com/gp/aw/d/B08XBPD81Y?ref=ppx_pop_mob_b_asin_title
    The weBoost is the drive reach OTR
    I haven't taken the ham test yet, just utilizing the radio for gmrs and frs stuff right now. I do plan on getting a technician license though.
    Wallygator[QUOTED] likes this.
  18. Mar 13, 2023 at 4:44 PM
    #348
    STravis
    Travis
    Ruidoso, NM
    For what I'm going to be using it for, it's perfect. I'm definitely not using it to it's full capacity but I have a few fire department friends that use them in their personal trucks and like them. They do complain about how slow it scans though.
    helidave[QUOTED] and Wallygator like this.
  19. Mar 14, 2023 at 7:35 PM
    #349
    STravis
    Travis
    Ruidoso, NM
    I recently installed an anytime rear camera and front camera from trailgrid pro.
  20. Mar 14, 2023 at 7:41 PM
    #350
    STravis
    Travis
    Ruidoso, NM
    We're also in the process of replacing the kingcamp air mattress in the camper. We love how comfortable the mattress is, but the large single piece is a pain to have in there full time. We miss the ability to move the panel around to make room.
    We have a 4" thick sleeping pad foam being upholstered now with marine grade vinyl and we will be having some custom covers made for them.
    These pictures aren't ours, but an example of what ours will look like.
    FB_IMG_1678719694197.jpg FB_IMG_1678719700000.jpg FB_IMG_1678719710305.jpg FB_IMG_1678719714050.jpg
  21. Mar 16, 2023 at 12:08 PM
    #351
    STravis
    Travis
    Ruidoso, NM
    Here's some recent pictures.
    FB_IMG_1677538114318.jpg PXL_20230226_160515252.PORTRAIT.jpg PXL_20230226_160624357.PORTRAIT.jpg PXL_20230304_194311847.PORTRAIT~3.jpg
    These are from when @Jonnynewton909 came to town to get his bumper installed.
    PXL_20230213_212130883.PORTRAIT.jpg PXL_20230213_212114032.PORTRAIT.jpg PXL_20230213_212025655.PORTRAIT.jpg
  22. Mar 19, 2023 at 5:31 AM
    #352
    STravis
    Travis
    Ruidoso, NM
    A few pictures from camping over the weekend.
    PXL_20230318_025011273.NIGHT.jpg PXL_20230318_022041967.NIGHT.jpg PXL_20230318_135151070.PORTRAIT.jpg PXL_20230318_135207054.PANO.jpg PXL_20230318_135244101.PORTRAIT.jpg
  23. Mar 19, 2023 at 8:29 AM
    #353
    CaptRussia253
    CaptRussia253 New Member
    Ruslan
    Truck is looking nice. Love the snorkel. Need to convince my wife why I “need” it haha.
    SAGE63 and STravis[OP] like this.
  24. Mar 19, 2023 at 1:39 PM
    #354
    STravis
    Travis
    Ruidoso, NM
    Just tell her it's essential for the overall health and longevity of the engine. It's a snorkel now or a new truck sooner than later.
  25. Mar 19, 2023 at 2:44 PM
    #355
    CaptRussia253
    Ruslan
  26. Mar 21, 2023 at 12:59 PM
    #356
    itsZEUStime
    itsZEUStime New Member
    Paul
    2019 White Tundra SR5 Crewmax
    RCI Sliders RCI Skids Prinsu Rack AJT Chrome Delete Pop & Lock Power Tailgate Lock Super Pacific Camper Incoming
    Great looking rig!
    Question regarding the awning, how is it attached to the Atlas? Did you add any special type of bracket or support where the arm pivots at the back corner?
  27. Mar 21, 2023 at 1:01 PM
    #357
    STravis
    Travis
    Ruidoso, NM
    I am using the AT overland brackets. They installed them for me. I am running 3 brackets on the side with the awning.
  28. Mar 21, 2023 at 1:05 PM
    #358
    STravis
    Travis
    Ruidoso, NM
    Our new mattress is all done. It's a little on the firm side, but it should break in a little bit. If not, the foam can easily be replaced. It ended up being 4" thick. We should be getting some fitted sheets made pretty soon.
  29. Mar 24, 2023 at 3:47 PM
    #359
    Florida AF
    Logan
    North Florida
    Created an account after reading your thread....
    Well done!
    bulldog93 and CaptRussia253 like this.
  30. Mar 24, 2023 at 6:22 PM
    #360
    STravis
    Travis
    Ruidoso, NM
    I'm glad I could inspire you haha. Thanks for the compliment! Let me know if you have any questions!
    Florida AF[QUOTED] likes this.
