strange noise when accelerating
Discussion in '1st Gen Tundras (2000-2006)' started by NotaCarGuy78, Aug 12, 2015.
  1. Aug 12, 2015 at 8:55 PM
    NotaCarGuy78
    NotaCarGuy78 [OP] New Member
    2005 Toyota Tundra XSP
    None
    i've had my 2005 tundra for almost 6 years. I haven't had very many complaints with it. well, within the last month i had done an oil change on it and everything had been going good up until about a week ago. i noticed that when i stepped on the accerlertor the engine, or what i believe to be the engine, starts making a rapidly moving ch-ch-ch-ch sound. i've noticed the sound around 35 mph, 45 mph, and once it hits 50 mph it stays constant. I noticed that it has no correlation with the rpms, due to the fact that it isn't doing it while it shifts. Any help would be greatly appreciated.
    Thank you
  2. Aug 13, 2015 at 8:21 AM
    LOTSOFTOYS
    LOTSOFTOYS Toyota Whisperer
    Jace
    Mile high
    2005 Tundra DBL cab
    Does it feel power is down?
  3. Aug 14, 2015 at 7:41 PM
    NotaCarGuy78
    None
    power seems about what it was before. Also, the noise is more of a loud humming/vibrating not like previously stated.
  4. Aug 14, 2015 at 8:14 PM
    LOTSOFTOYS
    Jace
    Mile high
    2005 Tundra DBL cab
    So only when your moving right? 35, 45 and above 55? Not engine rpm related u stated.... does it change with decel? Or not and purely speed related?
  5. Aug 14, 2015 at 8:15 PM
    LOTSOFTOYS
    Jace
    Mile high
    2005 Tundra DBL cab
    Do me a favor, go a steady speed when it's humming loud. Wth out tragic around. Turn left a bit, a little harder than a lane change. Did it get louder? Or go away? How about turning right?
  6. Aug 14, 2015 at 8:31 PM
    NotaCarGuy78
    None
    Ok I will try. It goes away almost immediately after decel. And comes back as soon as I step on the gas.
  7. Aug 14, 2015 at 8:36 PM
    LOTSOFTOYS
    Jace
    Mile high
    2005 Tundra DBL cab
    Regardless of speed? Pinion bearings in the rear differential change noise on decel/accel.
    Wheel bearings typically change when steering side to side....
  8. Aug 15, 2015 at 10:39 AM
    NotaCarGuy78
    None
    I took it on some curves while maintaining a constant speed where the humming/vibrating was loud. The sound didn't stop nor get louder. It's in between 30-35 mph now, when the humming starts. I'm curious as to why it wouldn't be doing this at a lower speed.
  9. Aug 15, 2015 at 11:21 AM
    NotaCarGuy78
    None
  10. Aug 15, 2015 at 11:24 AM
    Mike Tread lightly.
    south carolina
    Are your ujoints property greased? By that pic they arent and haven't been in awhile.
  11. Aug 15, 2015 at 11:28 AM
    NotaCarGuy78
    None
    How would I check that, mike?
  12. Aug 15, 2015 at 11:30 AM
    NotaCarGuy78
    None
    I checked the rear differential for any leaking seals and didn't find any.
  13. Aug 15, 2015 at 2:01 PM
    LOTSOFTOYS
    Jace
    Mile high
    2005 Tundra DBL cab
    Time for a mechanic. U said it changes quite a bit when on or off the Gas at that speed.... tell them that
  14. Aug 15, 2015 at 2:29 PM
    NotaCarGuy78
    None
    ok. Thank you very much for your help Jace. i appreciate it.
  15. Aug 15, 2015 at 2:37 PM
    Mike Tread lightly.
    south carolina
    Get a grease gun and grease up the joints via grease fittings. When you see grease start to come out of the ujoint area stop.
  16. Mar 9, 2016 at 6:27 PM
    bigoltater
    bigoltater New Member
    KC
    2005 Tundra DblCab4x4
    Leveling Kit,33'BFG
    Mine does the same thing, no answers here I see.
  17. Mar 9, 2016 at 6:57 PM
    Nor7
    Nor7 Chilton Manual Guy
    2007 Tundra Limited CM, 5.7L
    When I first got my Tundra I noticed a sound when I was accelerating hard. It was a high pitch scream. Then I realized it was me.
  18. Mar 9, 2016 at 6:58 PM
    bigoltater
    KC
    Leveling Kit,33'BFG
    Lol
  19. Jun 22, 2018 at 12:46 PM
    moflea
    moflea New Member
    Felicia
    2005 Toyota Tundra V8 4x4
    About a month ago my 2005 started making a hissing"ish" noise from engine compartment (I think). About the same time the check engine light came on. I took it to Autozone and they told me the codes said something about the air, like O2 sensor or air filter or 1 other thing. They suggested that I should start with the air filter, being the cheapest fix if it worked. The first day the light came on was very humid here (live in Arkansas). The check engine light stayed off for a couple of weeks and the noise seemed to diminish some. 2 days ago it was very humid and the light came on again and I can hear the noise. I have changed the air filter now and it is still making the noise. I think it might not be as loud but I am not sure. It happens as I push on the accelerator. When I am sitting still or moving. I, like everyone else, want to fix this before it worsens or causes problems, but do not have the extra funds to go to the dealership for their reading of the light. Help please.
  20. Jun 22, 2018 at 7:53 PM
    LOTSOFTOYS
    Jace
    Mile high
    2005 Tundra DBL cab
    Given your lack of mechanical knowledge you may need to have a mechanic look at it.autozone doesn't know shit... sounds likes a vacuum leak
    6ixofone likes this.
  21. Jun 23, 2018 at 6:03 AM
    Afkouki
    Afkouki New Member
    2006 Natural White Limited
    I did not have any zerk fitting on my factory U-joints, they were sealed units
  22. Jun 23, 2018 at 6:40 AM
    ShreveportTSS
    ShreveportTSS Huh?
    Eric
    Louisiana
    2018 5.7 4x4 Crewmax TSS
    U-joints will do this. They can creak, shudder, pop, whine, click, and a number of other things. I would pull it and have your friendly local driveshaft shop replace them. Or take it to them if you want to avoid having to wrap the tail shaft to keep it from leaking tranny fluid while the drive shaft is out. Shouldn't be too $$$.
  23. Jan 12, 2019 at 5:10 AM
    military062701
    military062701 New Member
    Antonio
    2018 Tundra 1794
    Have you received any information or a fix on this?
  24. Jan 19, 2019 at 3:49 PM
    Whocares
    Whocares Member
    Grease those points
  25. Jan 21, 2019 at 7:25 AM
    military062701
    Antonio
    2018 Tundra 1794
    Just came from the dealership. I have a 2018 with right at 17k miles and was hearing the same noise. I was told I need a new rear differential. It doesn't bother me as much because I'm still under warranty but I also don't want to be in the shop getting a differential every 2 years.
  26. Jan 21, 2019 at 8:48 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Holy s%^T. You're rear diff went out with only 17K? How in the world..I'd be really curious to know what exactly failed. Is it possible all the fluid leaked out? That's the only thing I can think of.
