Stock Wheel Question
Discussion in 'Wheels & Tires' started by Ronin73, Mar 27, 2019.
  1. Mar 27, 2019 at 9:55 AM
    Ronin73
    Ronin73 [OP] New Member
    2019 Tundra Crewmax SR5 4x4 5.7 Magnetic Grey Metallic
    Hello!
    If I have stock 255/70/18 on the base steelies on the right and I swap out to stock 275/60/18 on the stock wheels to the left, will the base steel TMPS work on those?
    m-BHRu-Sle-U1m-RYK-Rid2-BFNQ_59d462e5861dbf39e904436348b39b8d6161e961.jpg m-H18l-Dk87v-Ogzt-V4-Koko-D-Q_65d8bb0218e8192ff90b282efce10146e2d02dae.jpg
  2. Mar 27, 2019 at 9:57 AM
    Bprose
    Bprose Old member
    VA
    17 Tundra CM TRD
    From what I’ve read on this site, no. Steel and alloy rims use different tpms’s.
  3. Mar 27, 2019 at 10:13 AM
    bfd300
    bfd300 New Member
    No the Steele’s use a diff angle on the stem. You need tpm’s for factory aluminum wheels. I went through this. Coolsprings Toyota $59 I paid for each.
    What year do you have?
  4. Mar 27, 2019 at 10:18 AM
    bfd300
    bfd300 New Member
  5. Mar 27, 2019 at 10:23 AM
    Ronin73
    2019
  6. Mar 27, 2019 at 10:24 AM
    Ronin73
    Dang...over $200 additional I have to add to the price of the rims and tires I would get?!? That is ridiculous. I'll just save my money and keep the steelies. Thanks everyone.
    pro2amendment likes this.
  7. Mar 27, 2019 at 10:35 AM
    Faht Nocker
    Faht Nocker Platinum Member
    Woody
    Milky Way
    2016 Super Fast White Platinum 4x4 Faux PRO Tundra
    check discount tire maybe
  8. Mar 27, 2019 at 10:36 AM
    bfd300
    bfd300 New Member
    Unless you can find wheels off of a 2018 or newer with tpm’s.
  9. Mar 27, 2019 at 10:51 AM
    Billy I
    Billy I AKA Storm Shadow
    2013 Tundra TRD Off Road White
    I have the wheels on the left and want to replace the lugs with black lugs. I've been looking around but not sure what the right fit is. Anyone have any suggestions?
  10. Mar 27, 2019 at 11:02 AM
    AK 6.7PSD Replacement
    AK 6.7PSD Replacement New Member
    IL, MO, KS, DE, IL, AK, SC...
    2018 SR5 DoubleCab 4x4
    I can tell you from personal experience that they do NOT work. I got the TRD wheels for $300 as dealer takeoffs and spent another $300 on TPMS.
    The truck/steelies/TRD were all 2018 models
  11. Mar 27, 2019 at 1:00 PM
    dacunn
    dacunn New Member
    2018 Crewmax
    It works. I have a 2018 that had steel wheels. Bought used TRD Off Road wheels
    and had them powdercoated black like the TRD Pro's. Discount tire took my old tpms off the steelies, flipped them the opposite direction and installed on the aluminum ones, and everything works fine. Only thing they will tell you is if you ever have a complete flat, it may break the sensor because the angle of the sensor is close to the bead. This is because the steel and aluminum sensors are at 20 and 40 degree angle, can't remember which is which.
    Bob likes this.
  12. Mar 27, 2019 at 1:24 PM
    Ronin73
    If you don't mind telling, how much did Discount Tire charge you to swap everything? Also, did you have to have the TMPS reprogrammed by Toyota?
  13. Mar 27, 2019 at 1:39 PM
    Berdine
    Berdine Voodoo Sport
    Binghamton, NY
    2020 VooDoo Blue Trd Sport
    I used these
    Look at this on eBay https://www.ebay.com/ulk/itm/161395248666
  14. Mar 27, 2019 at 1:55 PM
    Billy I
    Thanks....but those don't appear to have the "washer" portion of the lug nut that holds the center cap on...
  15. Mar 27, 2019 at 2:05 PM
    Smoofers
    Smoofers New Member
    N TX
    2018 TRD Sport
    I bought some TRD offroad wheels/tires with no TPMS and had Discount remove the TPMS from my TRD Sport wheels and tires and install in the TRD offroads, as well as balance them. Total cost was something like $240
  16. Mar 27, 2019 at 2:15 PM
    Berdine
    Binghamton, NY
    Forgot, sorry, I used those on my aftermarket rims
  17. Mar 27, 2019 at 2:30 PM
    Lukester
    Lukester New Member
    SF Bay Area
    I have a 2014. I believe 2018s use a different sensor. I got mine from ebay and it is working so far. Discount tire programmed them for me when I had tires put on by them along with my new wheels. I didn't have to pay any additional cost apart from mounting and balancing.
  18. Mar 28, 2019 at 2:28 PM
    dacunn
    dacunn New Member
    2018 Crewmax
    I replaced my stock 255/70/18s with 275/65/18 KO2s at the same time as I had the new wheels put on, so it didn't cost me any more for the tpms sensor swap. After about 100 miles my tpms light came on, probably because the shop never paid attention to which wheel went on which position. Anyway, I just never did the reset procedure in the manual, but I was taking it in for 10k service the next week. When I picked it up, the service manager says "we reset that tpms light for you", so I never even had to do the reset procedure. All that being said, in about 50k miles when the BFGs wear out, I'll probably put the proper sensors in the wheels while they're apart,but then again...maybe not...
  19. Apr 16, 2019 at 8:00 AM
    Ronin73
    Would my TMPS in my 18' steelies work for these 18' stock wheels?
    10fyt6f_6c1dfc8bc74987853f97084bcf0f385058e895d9.jpg 9sxtsm_dfbea794b047f23bb4c918e7412e7c791f19e8d8.jpg
  20. Apr 16, 2019 at 8:58 AM
    Ronin73
    Anyone?
  21. Apr 16, 2019 at 9:49 AM
    NoMoTaco
    NoMoTaco New Member
    Bluffton SC
    2018 Tundra DC TRD OR Silver
    Great question. No answer
  22. Apr 16, 2019 at 9:57 AM
    matrdguy
    matrdguy New Member
    Pete
    'The Notch' Western MA
    MGM 2016 Tundra Platinum 1794 Edition
    18" TRD Wheels, Falken Wildpeak AT3 275 75 18, Westin Bed Rug with Linex, Window Vents, TRD Sway Bar, Bilstein 6112/5100 CB +3 shackels, CB Shims, Chrome Tailgate Letters. More To Come....
    It is my experience that they will not work, as others have said the angle of the steel wheels is different. I tried it wheen I switched back on my 07, I dont think sensors have changed.
    The Alloys in the picture are still considered TRD wheels
    Im just giving you my experience... there are alot smarter guys on here than myself that might chime in
  23. Apr 16, 2019 at 12:04 PM
    Ronin73
    Someone said they would work (they said they had did it) by flipping the TMPS the opposite direction. I called the Toyota dealership that is selling those rims and told them I had a 2019 with the base steelies and they said everything will work fine. So, I guess we will see. Anyway, thanks for all of the help.
  24. Apr 16, 2019 at 12:20 PM
    matrdguy
    matrdguy New Member
    Pete
    Best to you... hope it does work... please post pics if you can... might help someone else
