Stock wheel question for the pros
Discussion in 'Wheels & Tires' started by Greybeard, Jan 11, 2019.
  1. Jan 11, 2019 at 5:59 AM
    Greybeard
    Greybeard [OP] Neither here nor there
    GA
    2014 SR5 Double Cab
    i have a stock 2014 2wd DC with the alloy wheels. I want to put on a set of factory TRD alloy wheels because I think they look better. Will they interchange and will I need to swap the TPMS out so I'm using the ones that came on my truck or will the ones on the TRD wheels work. ( I'm not doing anything with my spare)
    I have these wheels
    I want these wheels
    Stormtrooper81 and Rica25 like this.
  2. Jan 11, 2019 at 6:29 AM
    k9shag
    k9shag New Member
    Tony
    Midland, NC
    2017 Tundra DC SR5 MGM
    You will be fine with the swap. The TPMS in your current wheels should work fine in the TRD wheels since they are both alloy they have the same angle. Its going from steel wheels to alloys the TPMS can be finicky.
    Greybeard [OP] likes this.
  3. Jan 11, 2019 at 6:38 AM
    Hammerhead
    Hammerhead First scratch out of the way.
    Don
    Watertown, NY
    2019 dc MGM
    Should be able to get a good deal on those wheels used. There are a lot of people with them that have replaced with aftermarket wheels.
  4. Jan 11, 2019 at 6:44 AM
    Greybeard
    GA
    2014 SR5 Double Cab
    Thanks. I guess what I meant was, will I have to swap out my TPMS or just use the ones in the TRD wheels? Wasn't sure if they are programmed vehicle specific.
  5. Jan 11, 2019 at 6:45 AM
    Greybeard
    GA
    2014 SR5 Double Cab
    Good...the ones I found sold before I even got the question typed above :frusty:
    Hammerhead likes this.
  6. Jan 11, 2019 at 7:01 AM
    k9shag
    k9shag New Member
    Tony
    Midland, NC
    If the new wheels come with TPMS just have them programmed to your computer. Discount tire does this for $20 sometimes free depending on the location. The dealer will charge around $100 for the reprogram which is ridiculous. If you just buy the TRD rims with no tires or TPMS yours will fit fine and will not need to be reprogrammed.
    Where in GA are you these (TRD rims) are available a lot here in the Charlotte area.
  7. Jan 11, 2019 at 7:31 AM
    Greybeard
    GA
    2014 SR5 Double Cab
    Middle Ga. I'm checking the tire shops in the surrounding areas for take-offs.
