Stock Tires 4 or 5 Tire Rotation?
Discussion in 'General Tundra Discussion' started by khunk, Dec 23, 2016.
  1. Dec 23, 2016 at 3:46 AM
    khunk
    khunk [OP] Tundra Fan
    Marty
    Leland, NC
    2017 CM Limited 4x4
    Sorry if I missed the thread but here is my question;
    Stock tires, getting close to 5k and 1st service, should I go with a 5 tire rotation or a 4 tire rotation. No plans to change my tires anytime soon, want to get what I can out of them and then maybe see what happens. What are the pro & cons of both?
    Thanks in advance for your time:popcorn:
  2. Dec 23, 2016 at 4:39 AM
    CaptTyler
    CaptTyler Life’s too short to have an ugly boat.
    Tyler
    2018 Ram 2500 Cummins
    This is how I rotate my tires every 5k miles or so. I don't touch my spare tire.
    Just how I've always done it.
  3. Dec 23, 2016 at 7:13 AM
    chphilo
    chphilo Tundra addict
    Western PA
    I think your spares are mounted on cheaper wheels (I am not sure if they even have the same brand tires). If you want 5 tire rotations, you probably should match the tires and wheels.
    joonbug and NewImprovedRon like this.
  4. Dec 23, 2016 at 7:21 AM
    Backslider
    Backslider Thirsty...
    Tooele, UT
    You dont want to include the spare - too much variance in tread. The spare is for emergencies only. even if you do have to use it you should in most cases immediately replace the opposite side tire as well so you don't create a high traction pivot point.
  5. Dec 23, 2016 at 8:07 AM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    I agree with 4 tire rotation only on stock tires. You can only do a 5 tire rotation when the wheels and tires are all the same. Different wheel and/or tire can cause vibrations and uneven tire wear.
    TechWrench and zcarpenter92 like this.
  6. Dec 23, 2016 at 8:08 AM
    csuviper
    Broomfield, CO
  7. Dec 23, 2016 at 8:12 AM
    csuviper
    Broomfield, CO
  8. Dec 23, 2016 at 8:12 AM
    csuviper
    Broomfield, CO
  9. Dec 23, 2016 at 8:13 AM
    csuviper
    Broomfield, CO
  10. Dec 23, 2016 at 8:59 AM
    bsavoir
    bsavoir New Member
    Killeen, TX
    2016 Tundra Limited CM 4x4
    Gibson Metal Mulisha Exhaust, Replaced bulbs w/ LED's, AFe intake, Bullydog Tuner, Aftermarket Audio system, Rhino Bed Light sports bar, Tonneau Cover, Spyder Auto Headlights and Taillights, Recon 3rd Brake Light, Kensun HID's, Fender Flares, Custom Leather Interior, Heated Seats, 5% Tint on the Rear Windows, Pod light Foglights, 31" light bar behind the grille, linex spray bedliner, linex sprayed grille, ditch lights w/ dual 3in LED pods, 60" Tailgate LED strip.
    On my 2014 Tundra SR5 DC, the spare tire has the same exact tire as the other 4 it was just mounted on a dummy rim. I found this out when I drove over something that tore through where the tread and sidewall meet. I was sort of surprised that it was the same brand, type, rating etc.. but again its a truck that has to tow/haul putting something different could cause issues driving especially for people who cant afford a quick tire change. When I got my aftermarket wheels and tires I made sure the spare was the exact same.
  11. Dec 23, 2016 at 10:30 AM
    ChucklesToy
    ChucklesToy Retired
    Chuck
    Georgetown , TX
    2024 Honda Ridgeline Black Edition
    My spare is not only a different brand (Michelin instead of Bridgestone), but it is a different size and different wheel. 4 wheel rotation for me!
  12. Nov 19, 2019 at 4:01 AM
    Flyinryank
    Flyinryank New Member
    Ryan
    Las Vegas, NV
    White 2015 CM 4x4
    How do you factor tpms into a 5 tire rotation?
  13. Nov 19, 2019 at 5:03 AM
    Stig
    Stig New Member
    TTund16 and Zebruaj like this.
  14. Nov 19, 2019 at 5:03 AM
    Zebruaj
    Zebruaj New Member
    MN
    08 CM SR5
    I don't recall the spare having a tpms sensor. The receiver only picks up 4 sensors. So it won't matter. Just make sure whatever 4 tires are aired up.
    My Rav4 and 4Runner reads 5 sensors. PIA to make sure the spare is inflated in the winter. 99% of the time the dummy light is because of a deflated spare.
    Flyinryank likes this.
  15. Nov 19, 2019 at 5:25 AM
    JohnLakeman
    Outside of Weird, TX
    2017 MGM DC TSS 4.6L
    "There's got to be a pony in there somewhere..." :D
    Zebruaj[QUOTED] likes this.
