Stock Tire Pressure?
Discussion in 'Wheels & Tires' started by markjeff880, Dec 5, 2015.
  1. Dec 5, 2015 at 12:26 AM
    markjeff880
    markjeff880 [OP] New Member
    Hey all
    So I run my tires at stock pressure, 30 and 32 PSI as per the door sticker. During my last maintenance cycle the dealer over pumped my tires alot, up to 38 psi.
    Is this normal or was this just some dumb ass over pumping my tires?
  2. Dec 5, 2015 at 2:18 PM
    TXMiamiFan
    Jose
    2016 White Crew Max TRD
    Check max pressure noted on tire. You might be OK at 38 PSI.
  3. Dec 5, 2015 at 2:23 PM
    andrew
    andrew where's the beer?
    andrew
    2012 rockwarrior
    stock
    I wouldn't worry about 6 PSI. depending on where you live, the cold weather will probably bounce you down few PSI since winter is coming.
  4. Dec 6, 2015 at 2:22 PM
    markjeff880
    cool thanks guys
  5. Dec 6, 2015 at 2:41 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
  6. Dec 10, 2015 at 6:32 PM
    j2x
    j2x New Member
    Slidell, La
    2012 TSS Tundra
    Stock
    Mine are set at 37.
  7. Dec 12, 2015 at 5:54 AM
    chphilo
    chphilo Tundra addict
    Western PA
    I used to use 35 psi on stock tires.
