Stock Pro Suspension Front, ICON Progressive AAL Rear?
Discussion in 'Suspension' started by Tundrazy, Aug 23, 2017.
  1. Aug 23, 2017 at 6:01 AM
    Tundrazy
    Tundrazy [OP] Turd Bro
    David
    '17 CM Cement PRO
    My Pro finally came in and knew I couldn't leave it alone for long. While the front looks tough with the 2" lift, the rear of the truck looks a little scared. I do like a little rake to my trucks. I've researched the many lift options and I have kind of settled on the ICON progressive AAL which will give me 1-1.5" of lift in the rear and apparently will improve the ride? @ToyTec Lifts has them on sale right now and with my itchy trigger finger, I am ready to hit "order". Does anybody have any experience with this setup? Do the ICONs actually improve the ride and wheel travel and will I need new rear shocks? I'm trying to keep the Pro as stock as possible but just trying to get the rear bumper and trailer hitch off the ground. One last question... Will the ICONs put me too high in the rear with the 2" lift up front?
    Here is a picture of the stock pro for reference.
    oT02iepU95BOpmJuXkfNujJji8BaTkaEddtc7WWF_2cf6231621ed217d170b99433b036670336c64dd.jpg
  2. Aug 23, 2017 at 6:19 AM
    Tundrazy
    David
    '17 CM Cement PRO
  3. Aug 23, 2017 at 6:21 AM
    PMG
    PMG New Member
    A rear shackle from toytec or dirtydeeds will also get you that rear lift and improve the ride.
  4. Aug 23, 2017 at 6:33 AM
    Tundrazy
    David
    '17 CM Cement PRO
    I actually looked into that as well. Unfortunately with the TRD dual exhaust I cannot install an extended shackle unless I modify/reroute the exhaust which I don't want to do.
  5. Aug 23, 2017 at 7:03 AM
    boardude
    boardude I am Batman
    Kris
    Tucson, AZ
    [YODAGAN]
    2015 Inferno Ex-Pro
    Not true at all. I'm running +2 shackles and an AAL with TRD duals. Lot of guys on here are and didn't have to touch the exhaust
  6. Aug 23, 2017 at 7:06 AM
    boardude
    Kris
    Tucson, AZ
    [YODAGAN]
    2015 Inferno Ex-Pro
    I have CB shims up front on the Pro suspension as well which gave me about a 3" all around stance
    TheBeast and dcsleeper408 like this.
  7. Aug 23, 2017 at 7:15 AM
    Tundrazy
    David
    '17 CM Cement PRO
    Really? I was reading a thread where David at ToyTec stated that since the leaf is being pushed closer to the exhaust (with the shackle), it will come in contact at full flex. Does your AAL make a difference in spring rate so that it doesn't droop down far enough to hit the tailpipe?
    Toytec Lifts likes this.
  8. Aug 23, 2017 at 7:18 AM
    Toytec Lifts
    Toytec Lifts New Member
    Denver, CO.
    Honestly the ICON Progressive AAL is one hot item for Tundra guys. The reason being is that they will maintain factory load and towing capacities, help improve ride quality, and still offer increased wheel travel! Nice easy install that can be done in an afternoon with a couple buddies!
    We have seen our shackles push down the leaf packs onto the TRD Exhaust systems, "custom modifying" may be needed to insure proper clearance with that system and our shackles.
    -David
  9. Aug 23, 2017 at 7:23 AM
    boardude
    Kris
    Tucson, AZ
    [YODAGAN]
    2015 Inferno Ex-Pro
    I can't speak for Toytec but Coachbuilders were built mainly for the Pro application. It was close but never had an issue with the tails hitting the leafs when wheeling.
  10. Aug 23, 2017 at 8:07 AM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    I'm pretty sure most people who add the shackles never check the rear at FULL droop. With 2" CB shackles, it hit my pro exhaust so I cut the tips off. @boardude get your truck where one of those rear wheels is off the ground and look at it, then get back to us and tell us what you see.
    @Tundrazy what you heard and toytec told you is true, but most people don't put their trucks into off road situations severe enough to ever know.
  11. Aug 23, 2017 at 8:14 AM
    14burrito
    14burrito IG @14burrito
    2014 SR5 CM 4x4 5.7
    I love the performance of my ADS rear shocks with the Icon expansion pack and Wheelers bump stock.
    I opted to install the expansion pack without the overload, I wanted ride improvement without adding height. Driver side 3/4" and pass side 1" of lift obtained.
    Ride quality over the factory is like you wouldn't believe both on and off road :)
  12. Aug 23, 2017 at 8:49 AM
    PMG
    PMG New Member
    And then I'll buy your rear shocks
  13. Aug 23, 2017 at 8:49 AM
    boardude
    Kris
    Tucson, AZ
    [YODAGAN]
    2015 Inferno Ex-Pro
    Lol well yeah at full droop I can see it getting close or making contact. Even in extreme situations how much are you really in full droop at one time? Even on a stock application the exhaust would be close to the springs in full droop. That's why the tails have hangars to flex so you're not gonna break anything.
    I've wheeled a ton without any issues so the AAL might have helped but I can also see it making it worse.
    Btw, I'm running BAmufflers with turn downs so can't do your experiment. I ended up replacing the tails with turn downs because I was threatening to crunch the tails into the rear fender in low clearance situations.
    gosolo[QUOTED] likes this.
  14. Aug 23, 2017 at 8:52 AM
    boardude
    Kris
    Tucson, AZ
    [YODAGAN]
    2015 Inferno Ex-Pro
    Just try not to drive like this most of the time and you're good
    GarTX526, gosolo and Toytec Lifts like this.
  15. Aug 23, 2017 at 8:58 AM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    I have heard good things about the Icon aal leaf pack addition. No experience here but it is on my possible list.
    TheBeast likes this.
  16. Aug 23, 2017 at 10:27 AM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    I'm running the Icon leaf pack as well as the CB shackles. Ride is still as smooth as stock. By cutting the tips off i eliminate all chances of contact from full articulation. For the same reason of not diminishing any of the off road capabilities, I will not add the rear sway bar.
    @Tundrazy this could stiffen your ride a bit unless you're carrying a load. I needed to do this because I'm carrying considerable weight all the time.
    boardude likes this.
  17. Aug 23, 2017 at 11:14 AM
    Hattori
    Hattori STOP SHIMMING COILOVERS!!!!
    Tommy
    Nashville
    2012 Tundra CM TRD
    Me.......
    Icon = only way I build em here unless im adding a TC or Camburg shackle:thumbsup:
  18. Aug 23, 2017 at 11:25 AM
    TheBeast The Beach
    yummy
    boardude[QUOTED] likes this.
  19. Apr 23, 2019 at 3:07 PM
    TacoWuzzaTurd
    TacoWuzzaTurd Loving my Tundra
    Scottsdale AZ
    2018 SR5 4x4 Crewmax, TRD Offroad
    6112s @1.9", TRD Dual Exhaust, rims, tires, jl audio system
    FWIW I added the 3 leaf AAL to my 2018 Crewmax SR5 4x4 TRD OR and it *seems* to have only raised the rear .75". Note however measurement was taken with just over 3/4 tank of gas so maybe that has something to do with not getting the full 1" - 1.5" lift in the rear as advertised. I do not have any armor or heavy bumpers that would affect it. I do have 6112s up front at 1.9" and added the AAL Pack to try and regain some factory rake for towing and hauling purposes. They do ride nice but was hoping maybe they'd lift just a tad more than they actually seem to have lifted.
    My hub to bottom of fender measurement was 24.25" with factory rear suspension. After the icon leaf pack I'm measuring at 25.00"....
