Stock Painted Rims Wax?
Discussion in 'Detailing' started by Buildn, Apr 22, 2018.
  1. Apr 22, 2018 at 6:55 AM
    Buildn
    Buildn [OP] 2022 Tundra Limited CM 6.5 Bed TRD Off Road
    Medina, Ohio
    TRD Air Filters, Front door windows tinted to match the rears. Wheel locks, Talons Garage cat shield, Tyger Automotive soft tonneau cover, WeatherTech floor mats with Tuff Skinz Custom Emblem kit, Toyota OEM Emblem Black Out kit. AVS vent covers on all four doors, Red Tundra letters on front bumper & TRD highlighted in Red on front grille. Tailgate Tundra Letters in Black.
    Hi all,
    What do you recommend on the black painted rims to maintain the high gloss?
    Since it’s a high heat area.
  2. Apr 22, 2018 at 7:16 AM
    tomsinamerica
    tomsinamerica New Member
    Tom
    Wilmington, NC
    White 2016 Tundra DC ltd
    If your wheels are a high heat area, I'd take a look at fixing the brakes before I looked for a high temp wax product.
  3. Apr 22, 2018 at 7:22 AM
    15whtrd
    15whtrd Mr. Blonde
    Treat the rims the same way you treat the paint on the truck. Keep in mind black shows hazing easier and brake dust will scratch them if you aren’t delicate with it. Polish and wax as you would a black truck. Maybe get some specific wax for black if you like.
  4. Apr 22, 2018 at 9:58 AM
    Buildn
    Medina, Ohio
    Tom,
    I didn’t mean glowing red hot. Just a hotter area than the rest of the truck
  5. Apr 22, 2018 at 10:00 AM
    Buildn
    Medina, Ohio
    Sean,
    I did use the same wax as the rest of the truck on the rims last fall I just was wondering if there are different waxes out there for black painted rims
    Thanks for the reply
    15whtrd likes this.
  6. Apr 22, 2018 at 11:25 AM
    seniramsu
    seniramsu Pro Runnin
    Nate
    VA
    2017 TRD Pro Tundra Wht
    There is some wax for black vehicles. Of the top of my head I know chemical guys has one and megs has one as well. I’m sure there are others. Good luck and happy waxing!!
    Buildn[OP] and 15whtrd like this.
  7. Apr 22, 2018 at 8:25 PM
    Buildn
    Medina, Ohio
    I found this stuff today!
    Makes them glossy and new.
    15whtrd likes this.
  8. Jun 11, 2018 at 8:20 AM
    briarpatch
    briarpatch New Member
    The biggest issue with a protectant for your wheels is heat. I use McKees Wheel Coating on my tundra, and my wife's Sequoia...great stuff. PoorBoys also makes a wheel sealant, which I've used with good success as well. Finish Kare HiTemp Wax is supposed to be able to take up to 250 degrees.
