Stock 18 inch tire psi?
Discussion in 'Wheels & Tires' started by Rski85, Feb 8, 2018.
  1. Feb 8, 2018 at 9:08 PM
    Rski85
    Rski85 [OP] New Member
    the guys that are still running their 18 inch wheels, what psi are you running?
  2. Feb 8, 2018 at 9:32 PM
    ninjajay
    Spoolston, TX
    2018 MGM 1794 TRD 4x4
    I usually do 35 all around (P rated)
  3. Feb 9, 2018 at 5:07 AM
    JeremyGSU
    JeremyGSU New Member
    Jeremy
    2016 Tundra
    This. I have the stock Bridgestone Dueler H/T's.
  4. Feb 9, 2018 at 5:10 AM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    get aftermarket tires......bridgestone duelers S.U.C.K.
    Mine lasted less than 30K before they went completely bald.
    kenomouth64 likes this.
  5. Feb 9, 2018 at 10:14 AM
    JeremyGSU
    Jeremy
    2016 Tundra
    I intend to get something different when they wear out but I'm not going to get something prematurely. They have 30k on them now. I think I can get another 10k out of them and then they are done.
    Law323[QUOTED] likes this.
  6. Feb 9, 2018 at 10:56 AM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    don't blame you, I did the same thing. Just senseless to waste perfectly good tires for no reason other than want. Luckily, mine didn't give me much time LOL
  7. Feb 9, 2018 at 11:12 AM
    Dmas
    Dmas New Member
    FTL, FL
    2018 SR5 Tundra DC TRD Off Road 4x4
    I do 32-33 psi on stock Michelin LTX A/T2 P275/65R18
  8. Feb 9, 2018 at 11:53 AM
    kenomouth64
    kenomouth64 New Member
    Tetrus
    2007 Toyota Tundra Sr5 4x4 (TRD Off Road) Crewmax 5.7L
    Hold the Line! If you are not holding the line, abandon your ship. Destruction is inevitable without more to hold the line!
    I had the exact same experience with those tires.
  9. Feb 9, 2018 at 11:53 AM
    kenomouth64
    Tetrus
    I run 40 PSI on my p-rated tires.
  10. Feb 9, 2018 at 12:25 PM
    Tierhog
    Tierhog SIG-AHOLIC
    2016 Tundra Crewmax Limited 4WD
    Mostly stock/TRD accessories/Morimoto XBs
    36 or so cold. I inflate in the garage in the morning as the pressure increases when the tires warm. I have Michelin LTX2 and at 22k the trucks tires are wearing appropriately.
    Next tire is likely the Michelin Defender or another high mileage mild AT for a decent compromise between snow and dirt and asphalt.
  11. Feb 9, 2018 at 12:35 PM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    did you tow any? I know I towed a few times and hauled plenty.
  12. Feb 9, 2018 at 2:04 PM
    kenomouth64
    Tetrus
    I actually never towed at all, when I had them. I did not rotate them as often as I should have (every 7500 Miles they were rotated). I ran them on my 4runner actually. They lasted around 23k miles before they were bald.
  13. Feb 10, 2018 at 5:52 AM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    Man, if that isn't a testament to how crappy they are! I could see a P rated tire not lasting long under the weight of the tundra (Added tow and haul), but a 4 runner?? That's bad LOL
    Even if you didn't rotate as often as you should've, 23K is balls low!
    kenomouth64[QUOTED] likes this.
  14. Feb 13, 2018 at 10:27 PM
    jHpowderhound
    jHpowderhound New Member
    Eric
    Jackson Wyoming
    Yeah, I got over 50k on my bfg’s
    Eric
  15. Feb 13, 2018 at 10:37 PM
    Darth Tundra
    Curt
    17 CM TRD Black
    35 PSI...on my Cooper A/T'S....Pathfinders
  16. Sep 5, 2020 at 3:59 PM
    greg52673
    greg52673 2010 Toyota Tundra double cab 4.6 with
    Greg
    Saint Augustine FL
    Reverse license plate camera
    I have 17000 miles on my 18inch Duelers and they still look and drive brand new.. I'll have to see how the fair as the miles pile on. But I believe I got 0ver 50thousand on my last set.. 2010 Toyota Tundra double cab 4.6
  17. Sep 5, 2020 at 4:20 PM
    ninjajay
    Spoolston, TX
    some trucks/drivers seem to do extremely well with the duelers
