Stillen TruPower Stage 2 Cold Air Intake
Discussion in 'Performance and Tuning' started by 2020Platinum, Jun 21, 2020.
  1. Jan 10, 2021 at 6:37 AM
    #91
    Funnyguy713
    Funnyguy713 I can't get Jiggy with this Sh!t
    Houston TX
    2017 Tundra 1794 4x4
    35s on 20s with 6" Pro Comp
    Yes i will probably go with the oiled and just replace it with a AFE down the road. I was just worried about the maf but it would only be in danger if not oiled properly.
  2. Jan 19, 2021 at 6:55 AM
    #92
    cleanTundra
    cleanTundra New Member
    Danny
    2021 Tundra trd pro
    ive just installed the stillen intake also, and the check engine light came on also. cant figure out what i did wrong. watched the videos and follow instructions. I called stillen and they said its probably a vacuum leak. ive double check everything again and dont see how there would be a vacuum leak anywhere. anybody else have this problem??? at this point im ready to just remove and sell it. not worth the damn headache.
  3. Jan 19, 2021 at 7:15 AM
    #93
    Funnyguy713
    Houston TX
    :eek2: Did you disconnect your battery?
    Rica25 likes this.
  4. Jan 19, 2021 at 7:17 AM
    #94
    cleanTundra
    Danny
    2021 Tundra trd pro
    yes, i also disconnect it to reset the cel a couple times to reset it. the longest it went without check engine light was about a 20 mile drive.
    Rica25 likes this.
  5. Jan 19, 2021 at 7:40 AM
    #95
    beaver6713
    beaver6713 2015 CM
    Kleve
    Safford Arizona
    2015 Tundra CM
    6 inch Pro Comp lift. OME rear springs with Coach Builder +3 shackles. Coach Builder tie rod ends. ICON 2.5 front and rear shocks with remote res. ICON Hyd bump stops. 35" Nitto Trail Grapplers on 18" fuel rims. Kenwood DNX 892 head unit with JL audio and RF amp pushing 2 Image Dynamics idq10 subs. SABM, S POD switches for 42" in bumper and 32" behind grille LED light bars. Full interior and exterior LED conversion. LED flush mount back up lights in rear bumper. Valentine one radar detector. V Leds under dash and seats foot well lighting. TRD pro head lights and grille. Full AJT dash kit
    I have the STILLEN on my 2015 5.7, I also did the SABM to it as well, also installed the JET MAFS(JET MAFS I would not recommend as it really does nothing) and got a tune from D.A.P. and installed 4:88 gears. Truck runs like a champ now.
    diablodalton, prevent, MTRock and 2 others like this.
  6. May 5, 2021 at 6:54 AM
    #96
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
    What is the difference between
    TP403200 and TP403202 except 47.37? Looks like there is an extra coupler in the 200.
    Rica25 likes this.
  7. May 5, 2021 at 7:11 AM
    #97
    prevent
    prevent New Member
    2014 5.7L Tundra SR5 DC
    TRD Catback Stillen CAI DAP Tune Tow Mirrors Light sensor Dashcam TRD Pro Grill LED Interior lights + DRL’s
    The 3200 includes a extra thing that you can use to block the front intake.
    I haven’t heard of anyone having problems with rain or snow getting in the airbox that way, but I’ve seen some members say that they’d use it if they’re off-roading on dirt/sandy roads so they don’t suck up the debris from the vehicle in front of them.
    I figured I might use it when I use one of those automated car washes, but I never use those so I got the kit without it.
    e30cabrio likes this.
  8. May 5, 2021 at 7:18 AM
    #98
    Funnyguy713
    Houston TX
    I got a pre-filter cover that protects it from water and dust from Rough Country that fits the STILLEN filter
    BigHornMtnTundra likes this.
  9. May 5, 2021 at 1:54 PM
    #99
    e30cabrio
    Thanks, has anyone put it on a second-gen Sequoia?
    Rica25 likes this.
  10. May 12, 2021 at 6:53 PM
    #100
    CoryShap09
    CoryShap09 New Member
    Cory
    2020 CM XP
    Any noticeable power / MPG gains with this intake? CELs?
    Joro43 and Rica25 like this.
  11. May 12, 2021 at 7:29 PM
    #101
    Funnyguy713
    Houston TX
    I don't know if its my butt dyno, the StilIen, the BAMuffler, or Pedal Commander but my Tundra hauls ass. Not too sure about mpg, its still bad but I only drive it on the weekends. :mudding:
    omgboost, TX210Tundra and Black Wolf like this.
  12. May 13, 2021 at 5:23 AM
    #102
    prevent
    prevent New Member
    I felt like I had a little more “get up and go” and my mpg went from 9.9 to 10.8/10.9 after running it for awhile.
    I don’t think any intake will increase fuel efficiency enough to pay for itself in any reasonable amount of time, but if seeing the number go up helps justify it on your end… I say go for it! The Stillen definitely improves the sound with my TRD exhaust at the very least, and although I see it annoys some people, I really dig the whistle sound too.
    Normally I don’t think CAI’s give enough performance gains to be worthwhile, but I’m pretty convinced the Stillen had a noticeable effect on the butt dyno.
    No codes or anything on my end.
    Rica25 likes this.
  13. May 13, 2021 at 11:10 AM
    #103
    Danman34
    Danman34 New Member
    Danny
    2018 White Tundra TRD Sport
    Same. The throttle feels slightly better with the intake. It takes a little less throttle to get up to speed than it did with stock. Passing on the interstate is a bit smoother as well and the truck feels as if it needs to downshift less. I do average about 1 mpg better in the city than I did with the stock. Intake has been on a year now. Zero issues.
    Rica25 likes this.
  14. May 16, 2021 at 11:49 AM
    #104
    Bigkitchens
    Bigkitchens New Member
    Alabama
    2014 1794 crewmax 4x4
    Front and back trd sway bars, 14 inch magnaflow dual in dual out exhaust, undercover bedcover, rough country 2 inch leveling coilovers and rear shocks, 285/60/20 nitto ridge grapplers, wireless charger, driver grab handle, tech12volt 10 inch sub and enclosure upgrade , and stillen cold air intake .
    I installed a stillen intake a week ago. For those who had problems with the 2 air box bolts, I didn't press in the bolts like the video says. I lined up the box with one hole then slightly pressed in one bushing until i got it started. Then I lined up the second hole with a screwdriver and tightened the first bolt down. Then lined up the second hole by eye and started the second bolt. This seemed much easier. I haven't had any check engine lights. The truck does get moving easier with it. It made up for the extra weight of my bigger tires.
    I can't say if it's louder, because my exhaust is very loud. I think it has the same low tone as my magnoflow exhaust.
  15. Nov 11, 2021 at 4:22 PM
    #105
    Ragnarkov
    Ragnarkov New Member
    Stephen
    2021 Silver Sky Metalic Platinum Tundra
    Nothing.... yet.
    Just finished Installing the intake this afternoon. Screws in box were a PITA like everyone says, but everything else went smooth. I did have to cut the silicone coupler between the throttle body and intake, as well as the larger extension tube coming into the back of the intake (next to the MAFS).
    One question, did your engine covers sit on the intake tube, or was there some room between the two? I'm wondering if I might not have the intake rotated enough in the right direction.
    I disconnected the battery prior to starting the job, double checked all connections twice before connecting it back, and so far no CEL . Let's hope it stays that way.
    Liking it so far. Quiet when it needs to be loud when I want it. And definitely seems more peppy, although jury is out on my butt Dino.
    SteyrM40A1, TX210Tundra and omgboost like this.
  16. Nov 12, 2021 at 10:04 AM
    #106
    Dogsled
    Dogsled New Member
    White 2020 1794 4x4
    Currency converter= Earned to wasted dollars
    Has anyone that has the aftermarket ATF cooler sold by ’Nichol’s installed on their truck… had problems installing the Stillen with the front air intake shroud placement? Thanks
  17. Nov 13, 2021 at 12:36 PM
    #107
    RRC
    RRC New Member
    Ronny
    21 nightshade
    Nice video, now I have to buy one!
    Rica25 likes this.
