Stick with stock or TRD?
Discussion in '2.5 Gen Tundras (2014-2021)' started by Rustyscrew, Jul 11, 2019.
  1. Jul 13, 2019 at 6:57 AM
    SnrDisregardo
    SnrDisregardo New Member
    Wade
    IL
    2018 Platinum CrewMax 4x4
    TRD Sport Suspension, TRD Front & Rear Sway bar, TRD Pro Shift knob, Charcoal Filter Delete, aFe Pro Dry S w/SABM, LineX bed, Remote Start, OEM tonneau cover, DIY pop'n lock, DIY TRD cold air intake, TRD skid plate, DD SS3 amber fogs, HotShot Offroad Hot Tails, 2020 OE radio with tech12v amp and sub.
    I was really surprised the TRD didn't have some sort of X or H pipe in it.
    Tierhog and Rex Kramer[QUOTED] like this.
  2. Jul 13, 2019 at 7:09 AM
    Razorwyre
    Razorwyre New Member
    2018 Tundra Platinum
    I am going to go against what others are saying here. If you are sensitive to noise, don't get the TRD exhaust. It sounds great at idle and great under medum to hard throttle. The problem is that if you do any amount of freeway driving it has a drone around 1300-1900 RPM, this is where the tundra drives/shifts from 55-70 and you get an annoying (to me resonance) its enough that you can actually feel it through your feet on the floorboard. I have added crazy amounts of sound deadening to the doors and back of cab, and I still hear it.
    Keith sells resonators that you can add to a TRD exhaust system that will help. You do have to cut holes in your TRD tailpipes to mount them. I was going to go that route to try and reduce the drone. Then keith had his sale and I decided to go with his TRD replacement system, 24x5 mild with integral resonators so I would have a "clean" install. The TRD replacement with integral resonators reduced the drone by around 50% but it is still there and noticeable. I am actually considering adding his resonators to the tailpipes (don't ask how deep I would be into an exhaust system at that point) to kill the last bit of resonance or just remove the TRD replacement and go back to stock.
    I used to read all these posts before I got the TRD exhaust about it being awesome and "quiet" and was surprised when I got it. It isn't going to wake up your neighbors, so it is quiet in that sense, but it is noticeable on the highway, and really annoying to get a resonance every time you load up going up a hill or give it a little more gas to speed up while locked up in 6th gear.
    Rex Kramer likes this.
  3. Jul 13, 2019 at 7:16 AM
    Tierhog
    Tierhog SIG-AHOLIC
    2016 Tundra Crewmax Limited 4WD
    Mostly stock/TRD accessories/Morimoto XBs
    Funny you mentioned that, DD went on to mention a Y or H pipe and everyone ran with it for awhile. I probably should look at his website and see what performance oriented systems he has and make a hard comparison to TRD. I like a nice exhaust as much as the next guy, but I'd need to be reassured it's purpose over aesthetics and sound. I think the days of bolt on performance are gone, short of a SC. I'm also done with drone. Too many hot rods and engine swaps in the 70s. My last hearing test was comical. Just my. 02
  4. Jul 13, 2019 at 7:29 AM
    Rig4war
    Rig4war New Member
    Sylvester
    Central California
    14 Attitude Black CM
    I am not quoting dyno’s Here or giving true specs, just my personal opinion with my personal experience with my truck and exhaust coupled with my CAI which he said he said he also had one.
    Tierhog[QUOTED] likes this.
  5. Jul 13, 2019 at 7:49 AM
    Tierhog
    Tierhog SIG-AHOLIC
    I wasn't holding to anything, it's tough to guage what works and how well it works when combined with other performance equipment. Not to hijack, but I wonder how well the TRD/CAI Interacts with the exhaust.. Hmmm
  6. Jul 13, 2019 at 9:37 AM
    Rex Kramer
    Rex Kramer Vinyl Spinner
    Georgia
    True dual systems work best with long tube headers.
  7. Jul 13, 2019 at 9:44 AM
    17TundraDCEd
    17TundraDCEd New Member
    Ed
    SE Pa
    2018 White SR5 Crewmax
    Rear Sway Bar
    For those on the fence, try searching local dealerships to see if you can find a used Tundra for sale with the TRD exhaust and go for a test drive. I say used, because the exhaust does mellow out with some miles vs brand new.
    Rustyscrew[OP] likes this.
  8. Jul 13, 2019 at 11:18 AM
    btanchors
    btanchors New Member
    Yes, this is exactly what I am afraid of. I don't mind increased rumble at idle, nor do I mind lots of sound at medium to hard throttle, but the drone sound at cruise would kill this for me.
  9. Jul 13, 2019 at 11:29 AM
    Rustyscrew
    Rustyscrew [OP] New Member
    Rockledge,Fl
    15 Tundra Platinum
    TRD Front sway bar, TRD Rear sway bar, TRD red and blue shocks, 2018 LED headlights and fogs, TRD intake box lid, TRD air flow accelerator, AFE Super Stock Intake with dry filter, TRD radiator and oil cap, Radium PCV Oil catch can, StopTech SS brake lines, LED puddle lights, VLED interior lights, OEM metal oil filter housing, Fumoto oil drain valve, LED front turn signals, TRD Battery tie down.
    That’s a good idea. I feel like that might be a difficult find but I’ll try that.
  10. Jul 13, 2019 at 11:33 AM
    Rustyscrew
    Rockledge,Fl
    15 Tundra Platinum
    This is good to hear. So the dirty deeds 24x5 is quieter than the TRD mufflers it sounds like.
  11. Jul 13, 2019 at 12:17 PM
    17TundraDCEd
    Ed
    SE Pa
    Rear Sway Bar
    Difficult but possible. Before I purchased the Tundra I have now which came with TRD exhaust new, I drove a used one the dealership had with 30,000 miles. I was surprised how much smoother and quieter it was compared to new. I took a chance and after 6,000 miles I can say mine has gotten better with mileage.
  12. Jul 13, 2019 at 12:28 PM
    TRD-tv
    TRD-tv Menace2Ohio
    Cleveland OH
    2012 MGM Tundra TRD
    Trd or die for me
    10TundraSR5 likes this.
  13. Jul 13, 2019 at 12:29 PM
    TundraLaw
    TundraLaw New Member
    Northern Nevada
    stock dude! Most power, quiet, functional. Toyota's imho are best when true to the sound that comes from the factory. I think DD is good, but that resonator that goes perpendicular is not for everyone.
    The TRD exhaust is just straight up annoying on the highway, and the low end power loss is noticeable.
  14. Jul 13, 2019 at 2:07 PM
    Rex Kramer
    Georgia
    I agree, but if I could boost factory power with an aftermarket cat-back without altering the factory sound - I probably would.
    By the way, to my ears - listening to Stevie Nicks sing is a lot like hearing the dreaded drone most aftermarket systems produce.
  15. Jul 13, 2019 at 8:32 PM
    Rig4war
    Rig4war New Member
    Sylvester
    Central California
    True Dat! TRD Exhaust in conjunction with the TRD CAI or with the AFE CAI? And possibly differences?
  16. Jul 13, 2019 at 8:37 PM
    Rig4war
    Rig4war New Member
    Sylvester
    Central California
    Well.... only one way to rectify this find someone that has a nicely broken in TRD exhaust and ride with them and that will give you your answer. I am in Central California your welcome to ride in mine anytime.
  17. Jul 13, 2019 at 9:47 PM
    Tierhog
    Tierhog SIG-AHOLIC
    Motown here... (Modesto). Might have to take you up on that. Fellow LEOSA... Retired with one agency and just hopped on with another..
    Rica25 likes this.
  18. Jul 13, 2019 at 10:02 PM
    Pbear1454
    Pbear1454 New Member
    NorCal and SoCal
    2010 Tundra TRD
    Bilsteins SPC RCI Steel Bumpers
    Yeah I agree after having stock exhaust for years and then recently upgrading to TRD dual. Listening to music not quite as enjoyable when you have to crank it up over the exhaust on the freeway.
    On the upside, pedestrians and cars should be able to hear me coming in a parking lot so safety factor a bit better
  19. Jul 13, 2019 at 10:18 PM
    #49
    Rig4war
    Rig4war New Member
    Sylvester
    Central California
    Yes sir. Working on 13 years in Santa Maria will be my first and last. Anytime, I would dig it to met up and talk the business.
    Tierhog[QUOTED] and Rica25 like this.
  20. Jul 15, 2019 at 7:15 AM
    #50
    10TundraSR5
    10TundraSR5 Happy Tundra owner
    Tennessee
    2010 Black Tundra SR5
    Curse you Perry the Platypus!
    I tried to be the responsible adult and at first just did a muffler swap with a large Magnaflow muffler (5 x 11 x 24 I think). To my surprise, the drone was beyond horrible. Within a week I got the TRD system and had it installed. No regrets.
    Rica25 and Rustyscrew[OP] like this.
  21. Jul 16, 2019 at 9:48 AM
    #51
    Vector W8
    Vector W8 Old guy with a lot of expensive habits.
    FFV, TRD Supercharger, Bullydog FFV Tune, 2014 Fit Kit, TRD Dual Exhaust, Sequoia Front Sway Bar, TRD Rear Sway Bar, TRD Skid Plate, TRD Pro Grill, 040 White Mirror Covers, 040 White Door Handles, Ready Lift 3"/2", Anzo 3rd Brake Light, Winjet LED Tail Lights, LED Fog Lights, LED Rock Lights, Axle Vent Mod, SDHQ Hidden Winch Mount, 12,000lb Winch. Storm Trooper Shift Knob. BMF BATL Wheels.
    If you live in the snow belt, I would recommend against the TRD. Its made out of some cheap 409 stainless steel that rusts like mad. I would recommend going with Borla if you want something built out of better material. I am pretty disappointed with the amount of corrosion on my TRD exhaust.
