Stereo Replacement
Discussion in 'Audio & Video' started by Bekah0306, Apr 24, 2024.
  1. Apr 24, 2024 at 5:08 PM
    Bekah0306
    Bekah0306 [OP] New Member
    Hey errybody.
    I am trying to replace the stereo in my 2003 Access Cab Tundra. I bought a Pioneer stereo, not sure the exact model but I can check if needed, and I absolutely can not figure out how to bypass the factory amp and power the stereo.
    I've spliced the wires from the new stereo to a harness that fits into the harnesses coming from the bottom of the amp, but the stereo is not turning on. I've consulted my BIL who used to work on cars for a living and he's also at a loss.
    I am very new to the car stuffs and any help is appreciated, thanks y'all!
  2. Apr 24, 2024 at 5:09 PM
    CCE525
    CCE525 New Member
    Chad
    2000 SR5
    None
    The amp gets deleted with an aftermarket unit.
  3. Apr 24, 2024 at 5:10 PM
    Bekah0306
    How do I power the new stereo without using the amp?
  4. Apr 24, 2024 at 5:10 PM
    Bekah0306
    For clarification, the harness I bought does not fit onto what was plugged into the factory stereo.
  5. Apr 24, 2024 at 5:11 PM
    CCE525
    CCE525 New Member
    Chad
    2000 SR5
    None
    You should have an adapter harness that wires in and connects your truck to the stereo. 12v power is in that.
    Once you remove the amp it’s straightforward
  6. Apr 24, 2024 at 5:12 PM
    CCE525
    CCE525 New Member
    Chad
    2000 SR5
    None
    May have the wrong harness. Go to crutchfield and verify it’s correct.
    GXPaycheck likes this.
  7. Apr 24, 2024 at 5:14 PM
    Bekah0306
    Dang, I don't have a crutchfield anywhere close
  8. Apr 24, 2024 at 5:25 PM
    shifty` We call it “riding the gravy train”
    @Bekah0306 please read the "Audio, audio upgrades and cameras..." section of this thread: https://www.tundras.com/threads/so-you-wanna-buy-just-bought-a-1st-gen-tundra-eh.115928/
    It will answer most of your questions. It also has links to ALL the harness part numbers, how to install the harness, etc. DO NOT CUT YOUR FACTORY HARNESS.
    And Crutchfield is online. They ship fast. They provide free phone support for your install. Super helpful, and their pricing is not only typically cheaper than scAmazon, but they also give you all the little adapters and crap you need to make your experience plug-and-play. They'll even make wire harnesses for you, for a small upcharge. They're a full-service shop, they've been around for decades.
    GXPaycheck and ATBAV8 like this.
  9. Apr 25, 2024 at 6:57 AM
    kentuckyMarksman
    kentuckyMarksman New Member
    2006 Tundra SR5 Double Cab - 4.7L V8 4x4
