Stereo Replacement Question
Discussion in '1st Gen Tundras (2000-2006)' started by Glock 40, Dec 17, 2020.
  1. Dec 17, 2020 at 9:41 AM
    Glock 40
    Glock 40 [OP] I'm here to break shit
    Yukon Cornelius
    Way up thar
    2000 AC Limited 4X4 4.7L
    Deadpool Edition
    I'm about to pull the trigger on this Alpine dbl din: https://www.amazon.com/dp/B07NQ2BRF...olid=2G7GSLOYCEIBX&psc=0&ref_=lv_ov_lig_dp_it
    I know others here have installed this model and are happy with it... which is why I settled on it.
    Question: Is this plug & play or will I need to purchase anything else to make it work? I'm absolutely terrible with vehicular electronics. Thanks.
  2. Dec 17, 2020 at 10:02 AM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    On a 00 I believe you'll just need a wiring harness and the brackets from your stock radio.
    tunyota and Glock 40[OP] like this.
  3. Dec 17, 2020 at 10:04 AM
    Glock 40
    Yukon Cornelius
    Way up thar
    Deadpool Edition
    I'll need to get a wiring harness? Which one and where do I get this?
  4. Dec 17, 2020 at 10:16 AM
    Glock 40
    Yukon Cornelius
    Way up thar
    Deadpool Edition
    Crutchfield says in it's description that it comes with a wiring harness with a 15A fuse. Is that what you're referring to or do I need some kind of special wiring harness?
  5. Dec 17, 2020 at 10:47 AM
    TX-TRD1stGEN
    TX-TRD1stGEN Privileged
    Seth
    South East Texas
    2000 Tundra 4x4
    You'll need to use the factory radio's brackets in order to install your new receiver. If you don't have the brackets, you can obtain them from your dealership.
    No dash kit is required for this installation.
    The factory amp is below and behind the radio. You will have to unplug the factory amp to bypass it.
    You will also have to hook up to your emergency brake or by a bypass kit from Amazon and wire that to your new harness. Here is the one I bought.
    https://www.amazon.com/MicroBypass-...d_rd_i=B006FKAHFM&psc=1&ref_=pd_bap_d_rp_27_t
    The Metra 70-1761 is the harness you will need to plug your alpine into the trucks factory plug.
    If you want to add a backup camera or external usb to plug your phone into for android/apple car play then there are more things you will need to buy.
  6. Dec 17, 2020 at 10:49 AM
    back9k9
    back9k9 New Member
    My 0.02 cents is to buy from Crutchfield if you can. They have excellent & very knowledgeable customer support / technical support. When you plug in your vehicle type, they show you exactly which harness & brackets you'll need.
    Pucks18 and Glock 40[OP] like this.
  7. Dec 17, 2020 at 11:17 AM
    rock climber
    rock climber New Member
    2001 Sequoia 4X4, 2000 AC 4X4
    If you have the factory amp below the radio you just have the pull the plugs out from the back of the amp and then connect them to the adapter. If no factory amp just connect the adapter. It will make more sense when you are in there.
    My 01 didn't have the factory amp so it was a very easy install.
  8. Dec 17, 2020 at 11:33 AM
    Festerw
    Festerw New Member
    04 Tundra DC
    Like others stated you'll need an adapter harness to the truck wiring. I'll second @back9k9 order from Crutchfield and for a little extra they'll wire the harness so all you need to do is plug it in you the stock wiring.
    Glock 40[QUOTED][OP] likes this.
  9. Dec 17, 2020 at 11:43 AM
    Glock 40
    Yukon Cornelius
    Way up thar
    Deadpool Edition
    Holy cripes, there's a lot more to it than I figured. Glad I asked.
  10. Dec 17, 2020 at 11:45 AM
    Glock 40
    Yukon Cornelius
    Way up thar
    Deadpool Edition
    I'll try it again, but the last time I entered my vehicle there they didn't offer any other harnesses or brackets when I clicked on that product.
  11. Dec 17, 2020 at 11:50 AM
    Glock 40
    Yukon Cornelius
    Way up thar
    Deadpool Edition
    This is a mystery. The previous owner had a Kenwood single din installed. Hopefully the OE brackets are still in there. I live atop bumfuk egypt so I don't have a stealership anywhere near me. I'll have to find the brackets online if that's the case. Hopefully not.
  12. Dec 17, 2020 at 12:12 PM
    RR60
    RR60 New Member
    2003 SR5 Tundra long bed
    Chances are they also had to use them. Also sometimes better calling Critchfield. Great place and they can tell you everything you need and confirm. Rare case can even get a little discount.
  13. Dec 17, 2020 at 12:21 PM
    Glock 40
    Yukon Cornelius
    Way up thar
    Deadpool Edition
    Thank you, yeah I'll definitely call them when I order it. It's not in stock now but there are "open box" ones available through their outlet. I'm a little leery of going that route and will probably wait until newbies are in stock.
  14. Dec 17, 2020 at 12:22 PM
    weadjust
    weadjust New Member
    Tupelo, MS
    2006 Tundra Limited DC
    I installed a single din Alpine in my 06 and the OEM Toyota radio mounting brackets were not needed for the single din installation. I suspect you will need to find the oem mounting brackets.
    tunyota likes this.
  15. Dec 17, 2020 at 12:31 PM
    Glock 40
    Yukon Cornelius
    Way up thar
    Deadpool Edition
    Well, hopefully they're attached to the existing aftermarket stereo... which is a Kenwood single din.
  16. Dec 17, 2020 at 12:39 PM
    Festerw
    Festerw New Member
    04 Tundra DC
    Later models (04-06 DC for sure, and 05-06 AC/RC) are different, they have a larger dash opening and require a mounting kit. The older models just needed a pocket under the single DIN.
    I may be incorrect on the years. @Glock 40 if you pull the center trim off you should be able to see if they're present.
    Glock 40[OP] likes this.
  17. Dec 17, 2020 at 1:05 PM
    rock climber
    If it's already got an aftermarket stereo than chances are it already has the wiring adapter you need. You should be able to undo the kenwood wires from the wiring adapter and wire up the alpine wires to the wiring adapter. The brackets should be there also. I say should because it's possible somebody did a hack job, but not likely when the adapters are so easy and cheap.
    Do you by chance have JBL speakers? It will say JBL on the door speaker cover. My 01 Sequoia has JBL and it was actually a super easy install.
    Glock 40[QUOTED][OP] and tunyota like this.
  18. Dec 17, 2020 at 1:18 PM
    tunyota
    tunyota Wrenching w/ the beautiful wife.
    Phantom Gray 2006 Regular Cab Long Bed 4WD V8 4.7L
    Front Hitch Receiver, Bilstein 5100s, Denso 130A alternator, LED interior and exterior lighting, Kicker 46CSS674 Car Audio 6 3/4" Component Full Range Stereo Speakers, Pioneer AVHX2700BS w/Pioneer NDBC8 Backup Camera, Transcend Drivepro 550 Dual Lens Dash Camera, and much more!
    @Glock 40 since you have a 2000 I am not 100% but for my 2006 I had to acquire the factory radio brackets in order to replace the older single-din head unit the previous owner installed as it is using an aftermarket plastic mount/bracket that was not compatible to reuse with double din head unit.
    https://www.ebay.com/itm/OEM-TOYOTA-TUNDRA-SEQUOIA-RADIO-MOUNT-BRACKET-SET-86212-0C011-FITS-2002-2006/361752256524?ssPageName=STRK%3AMEBIDX%3AIT
    I would highly recommend watching related YouTube videos to familiarize yourself with the installation requirements before diving in if you have not already done so.
    https://www.youtube.com/results?search_query=2000+tundra+radio+install
    As others have stated you will need a wiring harness to plug directly into the factory harness. The parking brake bypass is usually something everyone gets so you can access the head unit's full range of features while driving etc. It is pretty easy to remove and install so if you decide down the road you want to install a reverse camera, USB, etc. it shouldn't be too much trouble.
  19. Dec 17, 2020 at 1:25 PM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    I wouldn't worry about it. I ordered that exact same stereo from Crutchfield as an open box. It's exactly that, a box someone opened and then returned. There was absolutely nothing wrong with it. And even if you did have an issue, their customer service is so great they will make it right. You'll get no support from Amazon. Also, for around $20 they will pre-crimp the wiring harness for you. I felt it was worth it to have them do it as their work is a lot cleaner than mine. For $256 I would even be tempted to try the scratch and dent unit. They still test everyone before they send them out.
  20. Dec 17, 2020 at 1:31 PM
    Glock 40
    Yukon Cornelius
    Way up thar
    Deadpool Edition
    Nope
  21. Dec 17, 2020 at 1:33 PM
    Glock 40
    Yukon Cornelius
    Way up thar
    Deadpool Edition
    FirstGenVol, I like your advice and I think I'll do that. Thanks.
  22. Dec 17, 2020 at 1:39 PM
    weadjust
    weadjust New Member
    Tupelo, MS
    My 06 had the JBL 8 speaker system and I now have a single din Alpine. My single din mounting kit has the pocket underneath. Perfect place to put my phone when plugged into the Alpine usb port.
    tunyota likes this.
  23. Dec 17, 2020 at 2:21 PM
    Festerw
    Festerw New Member
    04 Tundra DC
    So does my 04, but the earlier trucks have a physically smaller opening so they are different.
    Here's the 00-02 single DIN kit.
    http://www.metraonline.com/part/88-00-8000
    Here's the 03-06 double DIN kit
    http://www.metraonline.com/part/99-8207
    The openings in the early models are nearly the same width as the aftermarket units where the later models are wider and require a spacer.
  24. Dec 17, 2020 at 2:45 PM
    Glock 40
    Yukon Cornelius
    Way up thar
    Deadpool Edition
  25. Dec 17, 2020 at 3:01 PM
    Pucks18
    Pucks18 Fleabit peanut monkey
    2001 Tundra 4x4 Limited trd
    Best buy had the wiring harness I needed for my 2001 tundra
  26. Dec 17, 2020 at 3:08 PM
    Festerw
    Festerw New Member
    04 Tundra DC
    Looks like you should be good according to the directions.
  27. Dec 18, 2020 at 12:03 AM
    artsr2002
    artsr2002 2005 Tundra DC SR5
    'Yonder
    Just a heads up on this Alpine unit. I helped my brother install the same headunit into his 2008 Passat a while back. Recently, he was having issues with his phone disconnecting from the headunit about every 3 or 4 minutes while on Android Auto. We believe his issue lies with the USB extension cable that was included with the radio. We disconnected it from the headunit and plugged in his USB C cable directly into the USB port on the back of the headunit and the disconnects stopped. We also updated to the latest firmware. I'll check with him to see if he continues to have issues with it.
  28. Dec 18, 2020 at 7:53 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    I've had some issues with mine too. Mainly trouble accepting calls while connected to android auto. Lately that problem seems to have stopped. Sometimes the audio quality of the call will start getting bad to the point I have to hang up and start over. That's not very common though. None of the issues are bad enough to make me replace it. I haven't done the firmware update but I've heard that it helps.
  29. Dec 18, 2020 at 11:11 AM
    Glock 40
    Yukon Cornelius
    Way up thar
    Deadpool Edition
    I won't be using it at all for phone conversations. If I can disable the android phone function I would be very happy. Number one rule for me is NO phone conversations of any kind while driving, period. If it starts answering phone calls for me while I'm driving I'll probably hit it with a hammer and buy a more simplistic receiver.
    Casper421 likes this.
  30. Dec 18, 2020 at 11:22 AM
    Festerw
    Festerw New Member
    04 Tundra DC
    When you set it up just block the permission for phone access
