Steering wheel wobble first thing in the morning?
Discussion in 'Suspension' started by Netmonkey, Apr 7, 2017.
  1. Apr 7, 2017 at 10:16 AM
    Netmonkey
    Netmonkey [OP] Don't be a Dumbass
    Georgetown, TX
    2016 Texas Edition, 5.7, CM, MGM
    Icon stage 2 lift, 295 60 20 nitto ridge grapplers, fuel kranks, TRD dual exhaust, TRD rear sway bar
    so I am experiencing something odd....
    I just had 5100's installed with the ridge grapplers. the alignment is good and the truck drives straight and doesn't wander at all. however, when I first drive the truck for the day, I have a slight left and right steering wheel wobble at 55-60mph. but after about 5 minutes of driving, the wobble goes away. there aren't any other issues and any other speed at any other time.... just when the truck has been sitting out in the driveway all night.
    what does this sound like to you? maybe the tires get a flat spot? or because the tires are cold? is this indicative of any suspension issues? its so weird.
    thanks,
  2. Apr 7, 2017 at 10:31 AM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    Carrier bearing drop?
  3. Apr 7, 2017 at 10:32 AM
    Netmonkey
    Georgetown, TX
    nope... just 5100's at middle setting.
  4. Apr 7, 2017 at 10:33 AM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    At a speed like that it is typically a balance issue. You are hitting the harmonic frequency at that speed and it makes the vibration.
    TheBeast likes this.
  5. Apr 7, 2017 at 10:35 AM
    Netmonkey
    Georgetown, TX
    hmm... would a road force balance correct this? it is odd that it is intermittent though.
  6. Apr 7, 2017 at 10:37 AM
    csuviper
    Broomfield, CO
    Possibly. Not positive.
  7. Apr 7, 2017 at 10:50 AM
    Bprose
    Bprose Old member
    VA
    17 Tundra CM TRD
    I had the same issue w a 2015 Silverado. I put some BFG ko2's and one of them would not balance. Road force balanced also. One of the tires was bad.
    Well, in retrospect, whole truck was bad really. Lemon lawed it and got my tundra.
    Are the tires new?
  8. Apr 7, 2017 at 10:51 AM
    Netmonkey
    Georgetown, TX
    yes, brand new tires.
  9. Apr 7, 2017 at 10:55 AM
    Bprose
    Bprose Old member
    VA
    17 Tundra CM TRD
    Have you taken them back to the shop that installed them to rebalance?
    Might be worth it, could be an easy fix.
  10. Apr 7, 2017 at 10:58 AM
    Netmonkey
    Georgetown, TX
    I haven't, but you are right, that would be the route I should go :)
    NewImprovedRon likes this.
  11. Apr 7, 2017 at 11:03 AM
    Bprose
    Bprose Old member
    VA
    17 Tundra CM TRD
    What you describe is exactly what mine was doing. 3 of tires balanced fine. Was just 1 bad tire.
    If it turns out to be same for you, have them swap that tire.
    After they re- balance, take s look at wheels n check weights. On my bad tire they had stacked s bunch of weights to try n balance. I called them on the bs.
    Never did getfixed as I got rid of truck
  12. Apr 7, 2017 at 1:19 PM
    AxelsHumanDad
    AxelsHumanDad Get off my lawn.
    KAIG, NW of The Frozen Tundra
    2015 CM Platinum
    Some suspension tweaks
    Sounds like flat spots.
    I had some Dunflops that did it daily. Heck, my Michelins do it now when the truck sits for a couple weeks. A little heat in the tires and it goes away.
    Patriot, landphil and 15whtrd like this.
  13. Apr 7, 2017 at 5:12 PM
    bobeast
    bobeast really old member
    Bob
    Hollister, CA
    2008 DC
    One idea would be an out of round tire (it does happen). Once it heats up it comes back into spec.
  14. Apr 7, 2017 at 5:32 PM
    Eclipsed & Floating
    I’m right where I need to be
    Voluptuous Whitey
    Mine have done that, my Taco did that, and my Chevy does it.
    Not everyday, but normally when it's colder or hasn't been driven all night. I chalk it up to cold tires and pressure balances out once it's been heated up
  15. Apr 7, 2017 at 6:05 PM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    Those tires are Load range E 10 ply rated, aren't they? I have it a bit in the Tundra with LRE Duratracs, the Tacoma with LRE 'Tracs was worse. I've accepted it as part of running a stiffer, heavier tire at lower loads and pressures than it was really designed for. Once the tires warm up a bit, mine smooths right out too.
  16. Apr 7, 2017 at 6:32 PM
    Netmonkey
    Georgetown, TX
    Thanks for all the feedback, guys :)
