Steering wheel vibration and hopeful solution
Discussion in '2.5 Gen Tundras (2014-2021)' started by nl59, Jan 11, 2023.
  1. Jan 11, 2023 at 3:14 PM
    nl59
    nl59 [OP] New Member
    Hello! Just switched from a taco to Tundra. I purchased a 2015 tundra dbl cab long bed with 100k miles. Upon picking it up from the dealer I drove from Denver Co to Indiana for Christmas. I noticed the steering wheel vibration/shake at higher speeds above 50MPH. Fast forward to today... the dealer had my truck to install the tires and wheels I purchased. They ended up replacing the front rotors and pads because I mentioned the shake. Upon doing the alignment and balance and new brakes they took the truck for a test ride. They then noticed the vibration is still present.
    I will keep you all updated with the findings and what the solution is. I know that it isn't alignment, balance, or rotors/pads at this point.
  2. Jan 11, 2023 at 3:30 PM
    It's still possible to have an incorrect alignment or bad tire balance. They need to look at the tie rods, ball joints, etc.
    KNABORES likes this.
  3. Jan 11, 2023 at 3:31 PM
    When you are over 50 and tap the brakes, does the shake get worse?
  4. Jan 11, 2023 at 4:19 PM
    Depending on what wheels and tires you bought and who did the balance and with what, you could absolutely still have a wheel balance or out of round issue.
    agrestic1 and Tundra234 like this.
  5. Jan 12, 2023 at 9:20 AM
    Baja1000
    Baja1000 New Member
    Andy
    SOCAL
    2018 TRD 4X4 Cement CM
    My18 CM with 30Kmi steering wheel vibrates like crazy. Multiple alignments, tire rotations and still vibrates. Stock suspension and I have BFG AT's but it also did it with the stock ones as well. I hope someone can chime in here with a solution
    Thanks
  6. Jan 16, 2023 at 1:20 PM
    nl59
    They finally got back to me and they believed this to be the rear drive shaft bearing. They are replacing it today and I will update!
  7. Apr 2, 2023 at 2:02 PM
    SoTexTundra
    SoTexTundra New Member
    19 DC TRD OFF-ROAD
    Anymore info on this matter? I to have a steering wheel vibration before and after new tires, brakes and ecgs bushing installed.
