Steering wheel shake/vibration on my new 1794 Tundra. Please help.
Discussion in 'Wheels & Tires' started by MoreCowbell, Apr 18, 2019.
  1. Aug 24, 2019 at 6:04 PM
    #91
    Moon Puppy
    Moon Puppy I'm not new!
    Bob
    South Carolina
    2020 Tundra Limited
    HA! Small world.
    I'm in Greenwood. If you're close take it to Mike Horne out on 72.
    Mike's Auto & Truck Alignment
  2. Aug 27, 2019 at 2:44 PM
    #92
    smalls_ADV78
    smalls_ADV78 New Member
    Just wanted to come back and update my complaint: Fixed.
    Installed new JBA Upper Control Arms and alignment. Apparently you may not "need" UCAs with a 3/2 lift, but in my case it was definitely on the limit and these helped.
  3. Aug 27, 2019 at 3:30 PM
    #93
    Hey would you happen to have your alignment numbers from your shaking before you did the control arms? I am having issues with mine shaking and I have the ReadyLift 3/2. I am wondering if I'm in the same boat as you with being on the limit. I will scan and post my alignment sheet tonight.
  4. Aug 27, 2019 at 3:40 PM
    #94
    smalls_ADV78
    It’s still pulling to the right ever so slightly. I’m taking it back tomorrow morning to have them do a small adjustment. But all in all, huge difference and I am completely satisfied.
    32848116-38C4-4F72-9AA9-266637AD7654.jpg 4F53A0B0-B006-4DB3-9478-94033FBB2266.jpg
  5. Aug 27, 2019 at 3:48 PM
    #95
    Thanks. This is the before and after with the UCAs installed?
  6. Aug 27, 2019 at 6:01 PM
    #96
    smalls_ADV78
    I believe those before numbers are right after the install of the new upper control arms, and they are not reflective of the stock upper control arms. I cannot answer that with certainty.
    I will say this, with the stock UCAs the truck drove straight it just felt off, and had a shake. On my Tacoma, I had a similar issue with the same Ready Lift 3/2 kit. I was told similar to the Tundra that I did not need upper control arms, that was complete false. Once I put the UCAs on the Tacoma, it was night and day. Reasoning for explaining all of this...when you hit 3in front lift, you need UCAs.
  7. Aug 28, 2019 at 8:28 AM
    #97
    smalls_ADV78
    Updated alignment specs: went back today to adjust the slight sway to the right. All fixed, rides great!
    To the OP thanks for starting this thread. Found great info here. All the best to everyone!
  8. Sep 13, 2019 at 5:51 PM
    #98
    Big Red 1969
    Big Red 1969 New Member
    I have a 2007 regular cab, short bed, that does the same thing -- shimmies at 60-65 mph and then smooths out at 70. The truck is lowered and the wheels have been balanced several times. The alignment was done after the suspension work was completed.
  9. Dec 10, 2020 at 12:27 PM
    #99
    Joe24
    Joe24 New Member
    Jose
    SJ, Puerto Rico
    2019 WHITE TRD SPORT
    Hi.. I have a 2019 tundra trd sport.. the same thing is happening to the truck right after the first tire change.. I have tried over two sets of tires and expensive balancing and allingment.. but still no change
  10. Jun 25, 2021 at 1:54 PM
    #100
    Joe24
    Joe24 New Member
    Jose
    SJ, Puerto Rico
    Have you been able to solve it?
    I have a 19 TRD Sport, ever since i got my truck new it had that steering wheel shake but not to bad. My stock tires only lasted about 9,000 miles, but after i replaced them, its gotten worse, i have 46,000 miles on it and still haven't found the problem and on my fourth set of wheels now.
    I love the truck, but i am really close to trade it in.
    Rob's Inferno likes this.
