Steering wheel shake 2007 tundra
Discussion in '2nd Gen Tundras (2007-2013)' started by Sengx1, Mar 23, 2021.
  1. Apr 3, 2021 at 2:16 PM
    Cg13055
    Cg13055 @yota.parts.distributor
    South Florida
    Mcfly Tundra @yota.parts.distributor
    2012’4.0 Tundra-2004’4.7 crewcab-2021 2.7 Tacoma
    what trans and engine do you have? this could definitely be related to what I mentioned earlier. Has to do with the locking on TC for overdrive
    Sengx1[QUOTED][OP] likes this.
  2. Apr 4, 2021 at 7:01 AM
    Tired Traveler
    Tired Traveler New Member
    2010 dbl cab 5.7
    My experiance with Tundra's with oversize tires like a little more pressure then what it says on the door jam. Try adding 5-10 more psi and give it a try and see if it still shakes. Usually this fixes that shake if balancing is not the issue. Just my 2 cents worth.
    Sengx1[OP] likes this.
  3. Apr 4, 2021 at 7:20 PM
    joseph_womack
    joseph_womack @ 4x4bound
    Joe
    Louisiana
    2007 RCLB, 4WD, 4.7L V8
    3/1 Lift, 35s, Front Bumper, etc etc
    any chance you know someone with stock tundra wheels and tires you could swap just to test?
  4. Apr 4, 2021 at 8:03 PM
    Sengx1
    Sengx1 [OP] New Member
    Seng
    2007 tundra SR5
    Level 8 wheel tracker 1/2" leveling kit Hankook dyna pro at2s
    @Cg13055 I have a 2007 4.6L V8. Just the regular 6 speed transmission
    @joseph_womack I unfortunately don't know anyone with stock tundra tires in a close distance. My rims are custom with the hankook tires. I was also thinking of swapping out if I could.
    Thanks for the responses, been busy last couple days.
  5. Apr 4, 2021 at 8:03 PM
    Sengx1
    Seng
    2007 tundra SR5
  6. Apr 4, 2021 at 8:06 PM
    Sengx1
    Seng
    2007 tundra SR5
    @frichco228
    Thanks for the detailed response. It does seem to be an unusual balancing issue. It seems less aggressive and certain tires such as the michelins S2/M2s seem to help others. Im thinking ill eventually have to swap tires and rims at some point.
    My rear shocks were leaking a little bit last the technicians checked. The fronts did seem fine. But I will definitely keep that in mind.
  7. Apr 8, 2021 at 6:46 AM
    joseph_womack
    Joe
    Louisiana
    Shouldn't it be the 4.7? I don't think the 4.6 was made until 2010, but anyway, did you ever get the wheels and tires balanced and road force tested?
  8. Apr 8, 2021 at 12:21 PM
    Sengx1
    Seng
    2007 tundra SR5
    @joseph_womack oops, yea I meant 4.7. Idk why I wrote 4.6 lol. The balancing and alignment did not help. Noticed quite a bit of shaking the other day. I asked the tech that if he recommended road force balancing, to go ahead. But I don't think he did. Since normal balancing did not help, Ill most likely take it in again for road force balancing, if yall think it will make a big difference. Never done road force balancing before.
  9. Apr 11, 2021 at 5:45 PM
    joseph_womack
    Joe
    Louisiana
    Is it just the steering wheel or the whole truck? And to be honest I'm not too sure if it will help a ton either
  10. Apr 11, 2021 at 9:56 PM
    Sengx1
    Seng
    2007 tundra SR5
    @joseph_womack well after driving some more, I noticed its driving smoother and shaking less at 60mph than before the balancing. At 70mph+ it still shakes, seems like abit more actually. Intermittent shaking as usual. Takes a min or two to stop shaking.
    Just the steering wheel shakes.
    Not sure what I'm going to do next. Maybe take it in for a second opinion but not really optmistic atm. Or possibly change out my tires at some point in the future. Will definitely update the forum when the time comes. Thanks for the input yall
  11. Apr 11, 2021 at 10:10 PM
    alb1k
    Left Coast
    05 2WD DC w/ attitude
    It's good
    I know wheels tires alignment and suspension geometry can cause similar problems. But doesn't the intermittent part, assuming same speeds, torque, etc, sound like a bearing or joint? I'm only asking, but intermittent sticks with me.
  12. Apr 12, 2021 at 12:34 AM
    Sengx1
    Seng
    2007 tundra SR5
    @alb1k the intermittent part is what confuses me. Based on what the technician said, the reason why its intermittent is because the balance is off and takes time for it to "balance" and sit in right. Or itll be off balance when turning or sudden bumps etc. Something in that nature. Definitely an unusual issue.
    I dont think its a bearing or joint as im thinking I'd be able to hear a constant drone or have nonstop shaking.
    Anyways I should get a second opinion soon. Get it checked out.
    joseph_womack likes this.
  13. Apr 12, 2021 at 6:41 AM
    joseph_womack
    Joe
    Louisiana
    Good luck!
  14. Apr 12, 2021 at 10:47 AM
    Danny3737
    Danny3737 New Member
    2012 Tundra Limited Platinum
    This may sound dumb, but I had something very similar happen on my daughters V6 Highlander. After rotating, rebalancing, etc with no changes, on a whim I went and changed all the coil packs. It only happened once when I drove it, but I did notice a very slight loss of power ( almost not noticeable) It never through any codes, but couldn’t get it out of my mind that maybe one of the coil packs was missing. It didn’t do it all the time, it just kind of came and went. After replacing all of them, the problem went away. It was a $300 gamble, but it worked out.
  15. Apr 12, 2021 at 11:44 AM
    Rex Kramer
    Rex Kramer Vinyl Spinner
    Georgia
  16. Apr 26, 2021 at 9:42 AM
    Cg13055
    South Florida
    Like I said check out the trans valve body and torque converter
