steering wheel plug, what is it?
Discussion in '2nd Gen Tundras (2007-2013)' started by TunaDr, Feb 20, 2020.
  1. Feb 20, 2020 at 1:37 PM
    TunaDr
    TunaDr [OP] New Member
    2007 Tundra
    I joined to see what is possible
    anyone know where this plug is supposed to go or what it's for? coworkers tundra has it and I looked at mine and theres no plug there.
    2007 trd
  2. Feb 20, 2020 at 1:44 PM
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
    I'm guessing you don't have steering wheel controls?
  3. Feb 20, 2020 at 9:02 PM
    TunaDr
    2007 Tundra
    correct, he does not have steering wheel controls. my truck (07 sr5) also does not have steering control but mine does not appear to have the plug
  4. Feb 20, 2020 at 9:03 PM
    ZappBrannigan
    Canada, by way of Hawaii
    2018 1794 MGM
    NVS light bar
    That’s for the optional ejector seat button.
  5. Feb 20, 2020 at 9:04 PM
    TunaDr
    2007 Tundra
    here is what mine looked like
  6. Feb 20, 2020 at 9:05 PM
    TunaDr
    2007 Tundra
    ejecto seato?
  7. Feb 21, 2020 at 4:20 PM
    bleach
    bleach MEME Fiend
    DJ
    Battle Ground, WA
    1991 White Xtra-cab SR5 4X4 V6 5 speed 148K
    I got nothing from the wiring diagram. I looked through a lot of the different components and while there were similar plugs, none were in the steering wheel area.
  8. Feb 21, 2020 at 4:48 PM
    Mattyc
    Mattyc <insert custom title>
    Matthew
    NY
    2008 Limited Rock Warrior
    Not stock
    It’s for the voice command option for Bluetooth.
    TunaDr[OP] likes this.
  9. Feb 22, 2020 at 5:49 AM
    TunaDr
    2007 Tundra
    but theres no steering wheel buttons...?
  10. Feb 22, 2020 at 6:02 AM
    Mattyc
    Matthew
    NY
    Not stock
    its pre-wired for it. Instead of making multiple configurations of wiring harnesses, they built one that makes things complete so it’s plug and play with most add-ons (like Bluetooth and volume controls). Cheaper from a manufacturing perspective
    Tundra2 likes this.
  11. Feb 22, 2020 at 7:14 AM
    TunaDr
    2007 Tundra
    do you think that plug was pulled out towards the opening then? because when I opened mine, it's clear that theres no plug in mine unless its tucked away somewhere
  12. Feb 22, 2020 at 7:28 AM
    e30cabrio
    I added auto headlights & HVAC, all the plugs were tucked up in the nearby wiring. Maybe that's where yours are.
  13. Feb 22, 2020 at 9:48 AM
    TunaDr
    2007 Tundra
    okay. how do you add auto headlight? and what do you mean you added hvac? theres AC control from steering wheel?
  14. Feb 22, 2020 at 9:55 AM
    e30cabrio
    I needed the stalk & sensor for auto headlights.
    The AC has nothing to do with the steering wheel, I am pointing out the truck was prewired for several things.
  15. Feb 22, 2020 at 10:07 AM
    JohnLakeman
    Outside of Weird, TX
    2017 MGM DC TSS 4.6L
    Auto headlights will not be plug-n-play on all trim levels. I think it works for SR5. Check to see if your instrument panel harness has a wiring connector plugged into the non-functional sensor plug at the center of dash. If the harness has the wiring at the plug location, then all you'll need is the light sensor and the auto headlight switch stalk. If there's no wires at the sensor location, then auto headlights will be a pita more difficult. Some get used parts cheaper on ebay. There is a thread on this mod somewhere here, use Search.
  16. Feb 22, 2020 at 10:09 AM
    e30cabrio
    I did not know the plug for the light sensor was there and bought it from Japan. The PN did not show up in US dealer searches.
