steering wheel play
Discussion in '2nd Gen Tundras (2007-2013)' started by jmoney2001, Sep 23, 2021.
  1. Sep 23, 2021 at 5:03 AM
    jmoney2001
    jmoney2001 [OP] New Member
    hey has anyone had any issues with their steering wheel. my steering wheel has play in it and it seems to be coming from the middle part of the steering wheel. is their a way to change out the brass part or a way to fix this?
  2. Sep 23, 2021 at 5:36 AM
    toyofan87
    toyofan87 Beer thirty
    Seth
    Gettysburg, Penna
    Given a official welcome to the tundy forum.. Welcome
  3. Sep 23, 2021 at 5:45 AM
    Forcefed
    Forcefed New Member
    2007 Tundra Limited
    6 inch lift, ADS suspension, Alcan custom rear springs, 46 gallon metal gas tank, Full Line-x body, Wheels with 35's, Smittybilt bumpers front and rear, 10k warn winch, custom rack.
    I have a little play but never investigated to see. For me I have had enough old cars I really don't even notice it that much. I have not seen anything about this, most of the time people swap steering wheels for the newer style. I'll be doing a 2.5 swap when I find a good deal on a steering wheel.
  4. Sep 23, 2021 at 5:53 AM
    jmoney2001
    than
    thank you for the welcome!!
    i really dont have the funds for a newer steering wheel plus airbag. i have also looked into used steering wheels and they are in bad shape. mine is in really good shape
    toyofan87[QUOTED] likes this.
  5. Sep 23, 2021 at 6:03 AM
    Forcefed
    Forcefed New Member
    2007 Tundra Limited
    I know a few guys are doing steering wheel swaps, I would find one of them and message them to see if this is an issue with the old unit. You might even be able to get one for nothing, since you want the stock 2gen. Nobody wants those. Search the forums and see what you can find. That's my best advice.
  6. Sep 25, 2021 at 9:44 PM
    NueveTundra
    NueveTundra Mod list in Bio
    Planet Earth
    07, Black Tundra SR5 CrewMax
    does the inner metal piece unscrew?. Also just want to shore up info before going in the wrong direction or down a rabbit hole. How did you come to the conclusion that the insert in the steering wheel is the play in the steering system?
    an welcome to forum. :)
  7. Sep 25, 2021 at 10:00 PM
    junior
    junior Member
    Zach
    Santa Cruz, CA
    2016 Tundra TRD Off Road
    Black Rhino Rapid 17" 35x12.5 Mickey Thompson Baja Boss Fox Performance Elite 2.5 DSC at 3" with Coachbuilder 1/4" shim on driver side JBA UCAs Fox Performance Elite 2.5 DSC rear shocks Dobinsons HD Leaf Springs Firestone Airbags + Daystar Cradles Prinsu Cab Rack 2024 Four Wheel Camper Project M Camper Mods: Goal Zero Yeti 4000 house battery 200w solar IceCo fridge Truma Propane Heater
    Do any of the splines on that part of the wheel or the steering column look damaged? It's easy to replace it with a new wheel using a steering wheel puller — but it wont help if neither of those are damaged. Could just be looseness in the steering linkage somewhere.
  8. Sep 27, 2021 at 5:02 AM
    jmoney2001
    no sorry the middle part does move. i will installing roll pins on the back. will keep this thread updated once i complete
    NueveTundra likes this.
