steering wheel locked. need help
Discussion in 'Suspension' started by Netmonkey, Mar 4, 2020.
  1. Mar 4, 2020 at 8:27 AM
    Netmonkey
    Netmonkey [OP] Don't be a Dumbass
    Georgetown, TX
    2016 Texas Edition, 5.7, CM, MGM
    Icon stage 2 lift, 295 60 20 nitto ridge grapplers, fuel kranks, TRD dual exhaust, TRD rear sway bar
    hey guys, i turned my steering wheel fully to the right and turned off the truck. the steering wheel locked into place and i took the key out. now, i cannot start the truck because the steering wheel will not release. there is no play in the wheel and i cannot jiggle it to free it.
    what do i do now !??!
    help!
  2. Mar 4, 2020 at 8:36 AM
    sf319
    sf319 New Member
    Utah
    2014 CM Barcelona Red SR5 5.7
    Dash Cam|PowerStop Z36|DIY bed rails|DIY Pop-n-Lock|LED interior
    I do this all the time when I park in my garage, I have to move my truck all the way against the wall which means a hard turn to get it slid into place. All I do is take the pressure off the lock pin in the ignition switch. The steering wheel doesn't move at all, but I have to pull hard on it to relieve the pressure off the locking mechanism. I would suggest having some one in the passenger either pull on the steering wheel or turn the key while you pull on the steering wheel. I now try to remember to relieve the pressure before shutting off the truck, but it doesn't always happen. Good luck!
    JohnLakeman and Netmonkey[OP] like this.
  3. Mar 4, 2020 at 8:37 AM
    Danman34
    Danman34 New Member
    Danny
    2018 White Tundra TRD Sport
    Turn the steering wheel a bit while you turn the key to On. It will unlock the wheel.
  4. Mar 4, 2020 at 8:42 AM
    Netmonkey
    Georgetown, TX
    I know. I have tried. It won’t budge.
  5. Mar 4, 2020 at 8:54 AM
    Netmonkey
    Georgetown, TX
    ok... so wtf? i get back in the truck and now there is play in the wheel and it started. maybe my weight bouncing into the truck freed or unbound something?
    whatever... i will never turn off the truck when the wheel is fully turned :)
    thanks, guys.
    sf319, Danman34 and Pinay like this.
