Steering rack and pinion leak
Discussion in '1st Gen Tundras (2000-2006)' started by TundraSam25, Nov 15, 2024.
  1. Nov 15, 2024 at 5:58 PM
    TundraSam25
    TundraSam25 [OP] New Member
    Sam
    San Antonio, Texas
    2005 Tundra SR5 Access Cab
    Alright. So, I got this 2005 Tundra 2 weeks ago and so far I’ve done the timing belt and water pump, lower ball joints, and just replaced the original spark plugs today. Truck runs great. I had to take it to get the ball joints done at a Toyota dealership due to work schedule not allowing me to do it myself. The tech informed me that the steering rack and pinion is leaking pretty good. Showed me some pictures and I also looked myself and it does seem to be leaking decently. No drops on the ground, but it’s definitely leaking.
    My question is: how long can I go like this? I have a valve cover gasket leak as well and ordered the parts from Toyota to do it myself, but they were back ordered for over 2 weeks and my work schedule just won’t allow me the time to install them. I bought the truck and have already thrown like $2k in repairs to it already.
  2. Nov 15, 2024 at 6:00 PM
    TundraSam25
    Sam
    San Antonio, Texas
    Mind you, the truck was a 1 owner, in near mint condition. I knew I had to do the valve cover gaskets when I bought it since I saw them leaking. The truck is in such good condition and looks great, just seems to be sucking money from me right now.
  3. Nov 16, 2024 at 2:46 AM
    bfunke
    bfunke Tundra Curmudgeon
    South Carolina
    Keep the PS reservoir topped off. How fast is it dropping fluid level? Maybe post some pics. My leak was the pressure hose which was an easy fix.
    For the VCs, check oil level often. Again pics are valuable.
    PS - Read Shifty’s megathread and update your profile to 2005 AC SR5 4.7 and your city or state.
  4. Nov 16, 2024 at 5:10 AM
    TundraSam25
    Sam
    San Antonio, Texas
    I’ve had the truck 2 weeks and haven’t had to fill the PS reservoir. Same with the oil. Oil level has not dropped since I’ve had it. I’ve kept an eye on both just to make sure but based off the fact I haven’t had to add oil or PS fluid I would assume it’s not a terrible leak.
    I’ll try and snap some picture of the steering rack leak when I get home from work.
    bfunke[QUOTED] likes this.
  5. Nov 16, 2024 at 5:50 AM
    ATBAV8
    ATBAV8 New Member
    Tempe, AZ
    2003 V8 SR5, Access Cab, 4x4, White
    It's a 20 year old vehicle. What did you expect? These trucks can be needy. Seals get old and dry, rubber cracks, etc. If you aren't able to do your own maintenance and repairs, then yes, they can suck the life out of your bank account.
  6. Nov 16, 2024 at 9:19 AM
    shifty` We call it “riding the gravy train”
    Need pics to understand the severity and source. Is it leaking at the inner side of the bellows? If so, AT-205 may help shore that up. If it's leaking at the lines/fittings, you may just need to make sure they're tight, or replace entirely.
  7. Nov 16, 2024 at 2:10 PM
    bfunke
    South Carolina
    Sam -post some pics. We’re here to help
    FrenchToasty likes this.
  8. Nov 17, 2024 at 8:52 AM
    mthoodbill
    mthoodbill New Member
    Mt Hood, Oregon
    2000 Tundra SR5 Access Cab 4x4
    Bilstein 6112, .5" front lift. 5100 rear. 17" FJ steel wheels Gofast topper
    I'm about to tackle this on a friend's tacoma. If we can't find the slow leak, there is an oil based UV dye and the UV flashlight we will use to find it. Hopefully it's just a hose.
