Steering pump or RACK just went out!!!!!
Discussion in 'General Tundra Discussion' started by csuviper, Jun 28, 2016.
  1. Feb 3, 2019 at 2:20 PM
    #91
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    Issue was on his previous truck. :gossip:
  2. Apr 7, 2019 at 6:29 PM
    #92
    Kn4x2
    Kn4x2 Common sense is not so common!
    3rd rock from the sun
    2010 DC 2WD
    Afe Pro Dry filter Tinted windows Coverking seat covers Traxion tailgate ladder Auto vox M1 backup camera
    I was thinking about leveling my 2010, but will a 2 inch leveling cause the rack to fail prematurely??
  3. Jun 22, 2020 at 2:35 AM
    #93
    NueveTundra
    NueveTundra Mod list in Bio
    Planet Earth
    07, Black Tundra SR5 CrewMax
    Ohhffff 3k thats rough. Still even at 2k a couple days off of work might be worth it unless you make 2k in those couple days... .
    I know this thread hella old at this point just cruisen the forum. Got to pull my Rack and pinion here in a couple days needs new mounting bushings. Things starting to twerk. Have some Energy Suspension poly bushings coming.
    Also saw the part of expensive water pump. I did mime after what the dealer ship told me the price was. Came to find out after i was in their the small leak was from a bolt that goes into the water jacket could of just pulled the bolt an put new sealer on it. But i already had new aisin pump replacement. So it went it. Wasn't as bad as i thought it would be.
    Heads up tho if your ever going to do the pump thats time if you want to put in a high amp alt.
    TheBeast likes this.
  4. Jun 24, 2020 at 5:56 AM
    #94
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Did the OP ever determine why the 2nd rack failed? I've heard good things about the Rack Doctor prior to this. @csuviper
  5. Jun 24, 2020 at 7:09 AM
    #95
    csuviper
    csuviper [OP] Moderator Staff Member
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    This is an old thread. When the second went out I made the decision to trade the truck in. They took it as is with the blown stealing rack and I got good money for the truck on the trade. I do not know why it failed but since it happened so soon after the first I didn’t want to keep wasting money.
  6. Jul 8, 2020 at 7:25 PM
    #96
    DesertGorilla
    DesertGorilla New Member
    Eric
    Tucson
    12 CM SW 4x 35s
    17" Methods 35x12.5 BFG KO2 - OME 612 Kit Dakar Rears OME Shocks & Shackles. - Nitro 5.29s and Auburn LSD
    Thanks for post this...my power steering just went out...fluid everywhere...wheel wells are coating both drivers and passengers...strange this is the ps reservoir is still full...I'll be taking her in, in the morning...but doctor rack has me feeling a little better.
  7. Jul 8, 2020 at 8:16 PM
    #97
    Ruggybuggy
    Ruggybuggy Seasoned Veteran
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Did you lift the new truck?
  8. Jul 8, 2020 at 10:24 PM
    #98
    csuviper
    Broomfield, CO
    Of course :)
  9. Aug 21, 2020 at 3:05 PM
    #99
    meinbomb
    meinbomb New Member
    stephen
    2012 crewmax
    3" ADS w/ resi front and rear, deaver u748 leafs, spc UCAs, coach builder tie rod end, helm joint sway bar link, durobumps, TRD air filter, bullydog tuner, 295/70/17 Duratrack on rock warrior rims when not running lame skinny snow tires on stocks for winter.
    This is a great thread. Just blew out my rack doing a 3 point turn in a driveway, fluid pooled in the inner boot. I'm on vacation near Glacier, MT so can't do it myself. Shop said 20 hrs, WTF. I explained how to do fix it in 5-8 hours and they didn't believe me. After chatting with a dealership, a tech said to look up repair process for 2016+ and has new method that is 5.75hrs according to Toyota. They quotes $870 plus parts and alignment at the dealer. Told the shop to look up repair for 2016+ and all of a sudden the job went from pulling the engine and tranny (20hrs) to 6-8 hours. Thinking of saving the old one to rebuild myself to have a backup, anyone rebuild a rack before? Worth it. This thread and another saved me 12 hours of labor cost. Thanks guys.
    T-Rex266 likes this.
  10. Aug 21, 2020 at 3:58 PM
    #100
    Buckeye1977
    Buckeye1977 New Member
    On a side note I thought my wife’s Honda Odyssey’s power steering pump was going out and my mechanic said “always switch power steering fluid to Lucas” it did bring it back to life for 3 more years.
    It doesn’t solve the rack issues but hope it can help someone.
    Ruggybuggy likes this.
  11. Aug 21, 2020 at 4:15 PM
    #101
    pickeledpigsfeet
    pickeledpigsfeet New Member
    Sierra Foothills, Ca
    2019 Tundra/14 FJ/ 90 SASed xcab
    Kings & Icons
    Damn that would suck to deal with that whike on vacation. What size tires are you running and how many miles are on your truck?
