Steering Mods?
Discussion in '2.5 Gen Tundras (2014-2021)' started by ScoutAngler, Feb 8, 2024.
  1. Feb 8, 2024 at 7:08 PM
    ScoutAngler
    ScoutAngler [OP] New Member
    Does anyone know of any steering mods to make the steering feel lighter in the 2.5 gens? Call me crazy but mine feels a little too heavy for my liking.
    Wondering if there is an aftermarket pump or pump adjustment I could make to add pressure?
    I’m also not sure if it could be an issue with the pump, rack or cv’s. The dealership said everything looks good but I really don’t like how heavy the steering feels it’s almost like it’s fighting me a little. No sqealing pump noises or vibrations or leaks.
    It would be the perfect truck if I could just get the steering to lighten up.
  2. Feb 8, 2024 at 7:31 PM
    centex
    centex New Member
    I’d prefer the other way. Mine feels way too light. Need some more heft and road feel in it.
  3. Feb 8, 2024 at 7:33 PM
    2mchfun
    Maybe you could do some various arm and hand exercises to change your physical strength to make it feel different in your hands. Just a quick thought!
  4. Feb 9, 2024 at 12:39 PM
    Jaypown
    Jaypown New Member
    Justin
    Rubber City
    Mine feels completely fine to me.
    If you think yours is abnormally heavy, test drive other 2.5 gens to compare/contrast.
    Different mfg's have different setups. I know Fords are way lighter than Toyota. I personally prefer slightly heavier feel but that's just my opinion.
    2mchfun and ScoutAngler[OP] like this.
  5. Feb 9, 2024 at 12:51 PM
    bflooks
    bflooks New Member
    Metrowest MA
    Check your alignment.
    vtl and ScoutAngler[OP] like this.
  6. Feb 9, 2024 at 12:51 PM
    _none_
    _none_ Poser
    2020 DC SR5 4x4
    Exactly. I came from a Nissan Frontier which had much heavier steering. Took a while to get used to this lighter steering.
  7. Feb 9, 2024 at 1:09 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    Alignment, tire psi, fluid change, etc.
  8. Feb 9, 2024 at 1:28 PM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    Actually tires can impact this as well, heavier and or wider tires will have a large impact on steering feel. I noticed this myself when switching from 275/70-18 Wildpeaks to 285/75/-18 nokians. While the 285s are an inch and a half taller, they are lighter and have a bit smaller contact patch. So the truck feels much more nimble now.
  9. Feb 9, 2024 at 1:33 PM
    Redseal199
    Redseal199 New Member
    2021 CM NightShade
    mine is extremely light. Too light in my opinion
    ScoutAngler[OP] likes this.
  10. Feb 9, 2024 at 1:46 PM
    Mine is very light as well. And the newer Frontier is crazy heavy in comparison. Almost feels like manual steering in tight parking situations.
  11. Feb 9, 2024 at 4:52 PM
    ScoutAngler
    I’m realizing I need to get an alignment I did change the fluid and got OEM fluid from the dealer it definitely helped some but I think the alignment is what I really need
    reywcms[QUOTED] likes this.
  12. Feb 9, 2024 at 4:53 PM
    ScoutAngler
    Is yours stock?
  13. Feb 9, 2024 at 4:53 PM
    ScoutAngler
    But I want a quick fix! Haha
  14. Feb 9, 2024 at 5:21 PM
    2mchfun
    Quick fix...add a supercharger and swap in 5.29 differential gears!
  15. Feb 9, 2024 at 5:42 PM
    ScoutAngler
    Takes too long! Haha
  16. Feb 9, 2024 at 7:07 PM
    BiggHertz
    BiggHertz DZTLIMO
    Chandler, AZ
    IG: dztlimo
    Stuff and Things
    This is actually incorrect….
    increased positive caster actually causes a heavier steering feel…this is a result of “jacking” where the front inside wheel actually “raises” and the front outside wheel to “lower”.
    You’re not overcoming the friction of the steering assy…you’re now transferring the weight of the entire truck…
    Great for performance oriented driving, increased steering wheel centering feel…but more input force is required.
    Cruzer and bflooks[QUOTED] like this.
  17. Feb 9, 2024 at 7:39 PM
    bflooks
    bflooks New Member
    Metrowest MA
    Thank you for the correction. I updated my post.
    Never intentionally "steering" someone wrong. :)
    reywcms and BiggHertz[QUOTED] like this.
  18. Feb 9, 2024 at 7:41 PM
    BiggHertz
    BiggHertz DZTLIMO
    Chandler, AZ
    IG: dztlimo
    Stuff and Things
    bflooks[QUOTED] likes this.
  19. Feb 12, 2024 at 4:49 AM
    Jaypown
    Jaypown New Member
    Justin
    Rubber City
    I agree with heavier and wider tires having an impact on steering. Even the type of tire, AT vs all season/highway touring, can have an impact.
    For the tire size, if your 285's are taller and wider than the 275's, how is there a smaller contact patch? Larger the tire, the larger to footprint.
  20. Feb 12, 2024 at 6:20 AM
    bflooks
    bflooks New Member
    Metrowest MA
  21. Feb 12, 2024 at 6:42 AM
    I smoked pot with Mikey Thompson.
    coTony, Cruzer and des2mtn like this.
  22. Feb 17, 2024 at 6:07 AM
    ScoutAngler
    Just an update I got new tires, Cooper Discoverer 275/60/r20 and changed out the steering fluid for the OEM fluid. This made a big difference much lighter feel.
    These tires are more like a street tire and ride smooth and quiet.
    I also got the front end aligned and it was badly out of alignment which helped too.
    Next I’m going back in to get them to adjust the caster to lessen the caster as this should also make the steering feel lighter.
