Steering issues
Discussion in '1st Gen Tundras (2000-2006)' started by JaceSlack1, Dec 26, 2023.
  1. Dec 26, 2023 at 11:40 AM
    JaceSlack1
    JaceSlack1 [OP] New Member
    Jace
    2000 Imperial Jade Tundra SR5
    So I have a 2000 Tundra 4wheel drive and here recently when I steer somewhere in my front end will pop n kinda jerk real bad n I had it apart n checked the CV joint and it’s good no play and my wheel bearing and ball joints are good as well as my steering arms I have no play what so ever but I’m curious if anyone has had this problem and if a bad rack could potentially cause this issue
  2. Dec 26, 2023 at 11:51 AM
    The Black Mamba
    The Black Mamba Black Sneks Matter
    Ryan
    DFW
    Black 00 SR5 AC 5VZ PreRunner
    Imma keep it stock
    Low speeds, high speeds? Left, right? How tight of a turn? Need more info, please.
    EDIT: Is it different than the feeling of turning a pavement when 4WD is engaged? Just want to rule that out first.
    shifty` likes this.
  3. Dec 26, 2023 at 11:54 AM
    shifty` All my rowdy friends have settled down
    This was my first thought. "Hope this person realizes you can't have the truck in 4WD while driving on paved surfaces..."
    That would be really, really unfortunate. Or if it was stuck in 4WD somehow.
  4. Dec 26, 2023 at 1:21 PM
    Aerindel
    Aerindel New Member
    Montana
    Well, you can. Its just a chore.
  5. Dec 26, 2023 at 1:23 PM
    The Black Mamba
    Ryan
    DFW
    Imma keep it stock
    "shouldn't" I guess would have been the better choice word. I'm sure shifty is well aware that you "can" as I would bet that he tests the operation of his on at regular intervals.
  6. Dec 26, 2023 at 1:23 PM
    The one time I did it totally by accident (was wet out, pulled into dry, covered asphalt parking lot, POP POP POP!)
    Shit binds or wheels skip if they can, but on asphalt… they stick. I caught it by the 2nd really aggressive pop. It’s not just difficult to steer, things bind up.
  7. Dec 26, 2023 at 1:37 PM
    JaceSlack1
    Jace
    So I’m in 2 wheel drive and it’s not stuck in 4 wheel but it’s at low and high speeds it’s both when I turn to driver and passenger and it’s don’t have to be turned very tight at all and now it’s also kinda clunking when i go straight and out it in reverse and drive so now I’m thinking it’s not a steering issue but it was acting like it was before
  8. Dec 26, 2023 at 1:43 PM
    The Black Mamba
    Ryan
    DFW
    Imma keep it stock
    Does it sound anything like what is described below?
    shifty`[QUOTED] likes this.
  9. Dec 26, 2023 at 1:49 PM
    JaceSlack1
    Jace
    It could possibly be that I’m gonna check em n grease em and also check the transmission bushing and bolts n all that jazz to see if there could be an issue there
  10. Dec 26, 2023 at 1:55 PM
    The Black Mamba
    Ryan
    DFW
    Imma keep it stock
    It helps so much to read through THIS thread, @shifty` put a lot of time and effort into creating a place where we can have as much info as possible without doing so many searches.
    shifty` likes this.
  11. Dec 26, 2023 at 2:09 PM
    JaceSlack1
    Jace
    gotcha I’ll give it a read and also I think I found it where it shakes the whole truck and when I put it in drive n reverse I watched and my rear end shutters when I go to drive n reverse n all my bolts n everything are tight as well
