Starts but won't operate
Discussion in '2.5 Gen Tundras (2014-2021)' started by GasGuzzler, Nov 21, 2020.
  1. Nov 21, 2020 at 4:23 PM
    GasGuzzler
    GasGuzzler [OP] New Member
    2019 Tundra
    6” Readylift AMP Research Power Step Sides Fuel Grenade wheels Toto Tire Complete Stereo Overhaul
    So tonight I went out put the key in & turned it.... the truck started but I have no electronics, NONE!. This renders the truck inoperable. Does anyone know what could cause this? I recently had a recall issue with the front sensor (1 week ago) with not issues since.
    What I find real strange is that if I start the truck with the remote start (12Volt Solutions) the computer will boot up. as soon as I put my key in and turn it, all electronics shut down but the truck continues to run. What the hell could this be?
  2. Nov 21, 2020 at 4:24 PM
    CaptainGrumpus
    CaptainGrumpus The Mailman
    Maine
    2018 Inferno Tundra TRD
    Contact James @tech12volts and see what he has to say.
  3. Nov 21, 2020 at 4:53 PM
    Lovetrucks
    Lovetrucks Member
    2019 Ram Rebel
    That sounds like your key isn’t turning all the way back to run . Sounds like it’s sticking between run and start .
  4. Nov 21, 2020 at 5:44 PM
    PeakIT
    PeakIT Old Member
    Utah
    2019 OR Tundra Double cab
    Coachbuilder 3” shackles, King extended travel, SPC upper arms, 5:29 gears, FN FX rims,35"tires, leer shell, grill
    Maybe a bad ignition fuse or relay
  5. Nov 23, 2020 at 11:43 AM
    GasGuzzler
    2019 Tundra
    Well, I pulled the 12Volt Solutions Remote starter and that fixed it. What a pain. I have had it in the truck without any issues for over a year. They still haven't replied to any of my requests & I certainly can't wait as I need the truck to work. :mad:
  6. Nov 23, 2020 at 12:05 PM
    timsp8
    NY
    Did you install any other electronics recently that could mess with it? I’ve had a different brand remote start for 2 years, but mine just started acting up this year.
  7. Nov 23, 2020 at 12:10 PM
    GasGuzzler
    2019 Tundra
    No. I do have a lot of aftermarket parts but they have all been installed for a while. I did recently have my Morimoto Headlights fail as well. Guess that is the problem with aftermarket parts... It's also why I keep all of my factory parts. I am back to factory headlights until Morimoto designs new wiring harness. :angrygirl:
  8. Nov 23, 2020 at 1:12 PM
    TTund16
    TTund16 New Member
    What do you mean by having no electronics? Do the gauges (fuel, volt, little computer mpg display, etc.) work?
    Are you talking about radio or heater, accessories, etc.
  9. Nov 24, 2020 at 12:36 PM
    GasGuzzler
    2019 Tundra
    Everything you mentioned +. The interior of the vehicle acted as though truck was off. The motor & power steering were operational but the transmission was locked.
  10. Nov 24, 2020 at 5:40 PM
    TTund16
    TTund16 New Member
    Sounds like the remote starter may have some relays that are not working or not re-energizing and disconnecting some of the electronics.
    Just a wild guess as far as relays ... I don't have any experience with any remote starter.
    How did you pull the remote starter off? Is it a module you insert somewhere and can easily bypass?
  11. Nov 25, 2020 at 10:09 AM
    GasGuzzler
    2019 Tundra
    It is a plug & play module. I have actually really enjoyed having it. I used it all of time. I believe it is out of warranty so it probably won't be putting it back into the vehicle. As it was $400 I do not intend on purchasing a second one. It's a bummer but that has always been the problem with aftermarket parts. :(
    TTund16[QUOTED] likes this.
