Starting problem
Discussion in '2nd Gen Tundras (2007-2013)' started by Gerthkblue, Mar 8, 2020.
  1. Mar 8, 2020 at 3:53 PM
    Gerthkblue
    Gerthkblue [OP] New Member
    Kurt
    2008 tundra
    Leveling kit
    I have an 08 Tundra. At times the truck will not start and I will need to wait for approx 30 min and it will start. I cleaned the battery terminals thinking they were dirty. That did not help. I changed the computer key to a new one thinking the module in the key was bad. That worked for a few days. However, today the truck just wont start.
    I have noticed this problem intermittently for approximately 6 months. The first time it occurred was 6 months ago and then it worked great for the next 4 mos. Then it happened again when I cleaned the terminals. It worked great for about two weeks and then it happened again. Wouldn't start. It happened again so I swapped the ignition key to a new one thinking he module in the key was bad. It then started great for about a week and now it sits in my driveway dead. Nothing seems to work. Looking for an idea.
    The battery maintains a strong charge and the alternator, when running, is charging the battery. When it is dead there is no clicking sound at the starter which occurred each time the truck would not start.
    Any ideas/thoughts would be greatly appreciated.
  2. Mar 8, 2020 at 4:06 PM
    truckguy84
    truckguy84 New Member
    2011 Black Tundra SR5 TRD
    Welcome!
    The starter is probably bad would be my guess
  3. Mar 8, 2020 at 4:20 PM
    Gerthkblue
    Kurt
    2008 tundra
    Leveling kit
    Would there be a code on the computer?
  4. Mar 8, 2020 at 4:22 PM
    truckguy84
    Sorry just my guess, you checked battery and your truck is 08 so it’s probably due for a starter soon. Hopefully someone with more experience can help you.
  5. Mar 8, 2020 at 4:37 PM
    Gerthkblue
    Kurt
    2008 tundra
    Leveling kit
    Thanks for your help. This has had me stumped for a while.
  6. Mar 9, 2020 at 8:11 AM
    greghoro
    greghoro New Member
    Greg
    2012 Sequoia Limited
    I had this type of problem on another car a while back.
    Connections to the battery was fine, it was a bad negative wire connection to the engine block.
    Check that the two big wires coming from the battery have clean connections at their other ends; positive to starter, negative to engine block. Can’t be more specific than that as to where to find them.
    Greg
  7. Mar 9, 2020 at 8:39 AM
    Gerthkblue
    Kurt
    2008 tundra
    Leveling kit
    Thank you. I will give that a try.
  8. Mar 9, 2020 at 8:47 AM
    blackdemon_tt
    blackdemon_tt Battery Slayer
    I've replacement my starter approximately 6 months ago. I had a similar issue, but within day and it never turned on again. Did get a code for crankshaft position sensor. P0095 if I remember correctly, and I did swap it and no it didn't turn on. If you stall out on the road, because I did. Don't let the tow truck driver hit the starter to turn it on...
    #1 they don't know where it is and might be hitting some other vital component.
    #2 if they're not removing heatshields, yes 2 of them, no one will ever see it, because its hidden..
  9. Mar 9, 2020 at 8:56 AM
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    you could hot wire the starter to see if it's the starter or ignition system. If you have alarm that may be the cause too.
  10. Mar 9, 2020 at 9:00 AM
    blackdemon_tt
    Yes, this may also help. I also tried this and it was u successful.. I could hear a click, but nothing else. You may try to replace your relay. I did this too, but nothing, even replaced my battery on the 11th hour of the warranty and nothing.
    I do this on my Celica and it works marvelous when the relay starts acting up.
  11. Mar 9, 2020 at 9:21 AM
    Lovetrucks
    Lovetrucks Member
    2019 Ram Rebel
    This is exactly what I was going to say . I had that problem with an old ford
  12. Mar 14, 2020 at 8:28 PM
    Gerthkblue
    Kurt
    2008 tundra
    Leveling kit
    Thanks everyone. It ended up being a starter. Had it changed and everything is running well.
  13. Mar 15, 2020 at 1:30 PM
    blackdemon_tt
    Seems premature for the starter, but glad you got it running.
  14. Mar 16, 2020 at 5:41 AM
    Salty
    Salty New Member
    Lance
    2011 Red SR5 DC 4x4 4.6L
    I had something similar to this on my 97 f150, I replaced the starter and it ran great but earlier this year it stopped working again with the same symptoms and I found it to be a bad ground, so make sure your electric is sound in there too
    Glad to hear it's fixed up!
