Starter runs in accessory position
Discussion in '2.5 Gen Tundras (2014-2021)' started by toolman.dustin, Apr 10, 2022.
  1. Oct 5, 2023 at 12:31 PM
    gamparano
    gamparano New Member
    NW Missouri
    2015 Tundra SR5 5.7L
  2. Oct 5, 2023 at 12:39 PM
    coTony
    Tony
    Montrose, CO
    The default behavior for the ignition is to perform as you describe. When your battery is not going south on you, you can turn the ignition quickly to the start position and immediately let go. It will crank until it starts but I 'thought' there was a time limit and it would stop itself. I use this time to put my seatbelt on and check the gauges. It is in the owners manual... somewhere.
    Wynnded likes this.
  3. Feb 10, 2024 at 11:07 AM
    toolman.dustin
    toolman.dustin [OP] New Member
    Dustin
    Central Kansas
    Tundra 2016, CrewMax 4x4
    Thanks for this post and link: This problem went away in May 2023 and has now re-appeared in Feb 2024. There's a video on the link and my truck does exactly what is shown in the video. Starts on the 3rd attempt. I guess I'll go get my truck flashed. Very odd this problem would come and go like this.
    edit: so apparently this problem is caused by a variation in ethanol content in the fuel. I guess the computer is trying to compensate for what it thinks is "out of range" ethanol. I almost always but my gas at a Shell station, but the last tank I got was at a Sam's. The tank before that was at a Dillon's. So, I'm guessing once I get gas back at my Shell, I'm good to go.
    https://www.tsbsearch.com/Toyota/T-SB-0166-19#google_vignette
    Dustin
  4. Feb 10, 2024 at 3:37 PM
    Ruggybuggy
    Ruggybuggy Seasoned Veteran
    Dave
    NW ON, CANADA
    2016 Tundra OR
    If you have the flex fuel vehicle you should have the TSB performed. Changing your fuel station will no let likely fix the no start issue.
    KNABORES likes this.
