Starter problem
Discussion in '2nd Gen Tundras (2007-2013)' started by Hogfandan24, Aug 21, 2024.
  1. Aug 23, 2024 at 1:13 PM
    AZBoatHauler
    So.Arizona
    I’d throw a meter on the battery ASAP and see what voltage you have both truck on and truck off. Could be bad alternator not charging the new (or old) battery well.
    Orions Dad likes this.
  2. Aug 23, 2024 at 1:14 PM
    Hogfandan24
    Hogfandan24 [OP] New Member
    2014 cm tss
    If what I'm hearing is the solenoid click then wouldn't that tell me the relay is doing it's job? That click should let the 12v hot side of starter energize?
  3. Aug 23, 2024 at 1:43 PM
    Hogfandan24
    2014 cm tss
    Will check it first. But I don't think it'll be out of tolerance.
  4. Aug 23, 2024 at 2:18 PM
    blackdemon_tt
    blackdemon_tt Battery Slayer
    Yes, I did it cuz I was in denial and I didn't want to deal with it, but my brother convinced me to do it.
  5. Aug 23, 2024 at 2:25 PM
    Hogfandan24
    2014 cm tss
    Not in denial anymore. Anger
    blackdemon_tt[QUOTED] likes this.
  6. Aug 23, 2024 at 4:57 PM
    blackdemon_tt
    Lol, so was I... I even replaced my battery.... main reason I'm not on my 20th.. only 18th. Lol
  7. Aug 26, 2024 at 9:01 AM
    Hogfandan24
    2014 cm tss
    Solution for those that come in the future with issue. Battery connection for starter at battery was corroded and wasn't carrying current. I took apart cleaned everything then reconnected. Works great. Prob was issue from before but now we have new starter. Some take aways that may help someone down the rd. Prob would check that connection first if you have starter issue. Just in case. Was easy. Ratchet wrenches. Really would help. If your truck isn't from a rust state or isn't rusty I'd pull the manifold. It really wasn't a bad job. Tried it without first. But it was such a headache. No room to work on it.
    AZBoatHauler likes this.
