Starter had one job
Discussion in '1st Gen Tundras (2000-2006)' started by RUSTYNUTS, Sep 5, 2023.
  1. Sep 13, 2023 at 4:07 AM
    #61
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
  2. Sep 13, 2023 at 5:39 AM
    #62
    metalpete
    metalpete New Member
    ID
    2001 Tundra 4.7 4x4 SR5
    Toytech 2.0 Coilovers Camburg UCA's JBA headers Dynomax cat-back exhaust 90-221HD Leafs
    True. But this was years ago, way before I knew what an in-ground splice kit was :D
    RUSTYNUTS[OP] likes this.
  3. Sep 13, 2023 at 6:10 PM
    #63
    RUSTYNUTS
    RUSTYNUTS [OP] Diagnosed: incurable
    Rusty
    sOCal
    to be continued...
    well now you've gotta share with the class. What is an in-ground splice kit? (i'm pretending we're in pre-google times. just play along)
  4. Sep 13, 2023 at 6:49 PM
    #64
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    The in-ground splice kits we used made one hell of a hand warmer after mixing the 2 gels
    bmf4069 likes this.
  5. Sep 13, 2023 at 8:42 PM
    #65
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    Anything is an in-ground splice kit. Just depends on how long you want it to last...
    metalpete, shifty` and FrenchToasty like this.
  6. Sep 14, 2023 at 5:47 AM
    #66
    metalpete
    ID
    Basically, a piece of heat shrink over a mechanical splice, holding 2 electrical connections together. Like, for when you run over nana's landscape lights with a tiller and need her to stop crying.
    Exactly!
  7. Sep 14, 2023 at 5:48 AM
    #67
    shifty` In South Dakota Trouble ain't hard to find
    #OddlySpecificReferences
  8. Sep 14, 2023 at 7:24 AM
    #68
    RUSTYNUTS
    Rusty
    sOCal
    to be continued...
    I'm familiar with those splice kits, just never heard 'em called 'in-ground'. Makes sense tho.
  9. Sep 14, 2023 at 7:51 AM
    #69
    RUSTYNUTS
    Rusty
    sOCal
    to be continued...
    Yeah, so..... another update on the starter/battery terminal failure issue fkn headache;
    Everything was great for a couple days, then began the new problem. Turned key once and didn't fire up right away. Hmmmm..... 2nd turn fired right up. Thought it must've been a fluke. A few starts later it did it again. A couple more and then took several turns to fire. Yesterday, it got to the point where I had to turn it 15-20 times, then it would halfway turn over, then back to another 20 turns, and then fired up. Clearly no fluke and worsening rapidly. I keep saying 'turns' of the key rather than 'click's' because it is not the same as the single loud 'click' that I was experiencing before. Anyways, so last night after turning the key bout 60 times to get it running, I pulled away from the fuel pump into a parking spot. disconnected the battery terminals and wire brushed the shit outta the battery posts, and sanded the insides of the clamp terminals with 120 grit. Loosened the 7/16" bolts and wire brushed the shit outta those ring connectors. Bolted everything down with all the uggas and the duggas. Hopped in confident I'd have no more problems. Nope. Same shit. Guess I'll be hunting with my DVMM.
    https://media.giphy.com/media/NxrmdIuhu843JCwPTE/giphy.gif
  10. Sep 14, 2023 at 7:55 AM
    #70
    Do something next time, for shits and giggles: When it won't start, shift to Neutral and see if it suddenly starts.
    kyle11863, AZBoatHauler and Mr.bee like this.
  11. Sep 14, 2023 at 8:00 AM
    #71
    Mr.bee
    Mr.bee King Turdra
    SATX
    '02 AC TRD
    When you turn the key nothing happens? Then when it does catch, starter motor spins fine?
  12. Sep 14, 2023 at 9:53 AM
    #72
    BubbaW
    Bubba
    Where Eagles Nest
    T150 Lover
    Like a strong battery reaction crank that quit after a ~second or weak struggling crank.l that quit quickly.
    The crank in neutral is a good thought and only add to that by suggesting, go thru gears from top to bottom and them back to neutral….somewhat of a Park/Neutral switch test.
  13. Sep 14, 2023 at 10:58 AM
    #73
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    Ignition switch?
  14. Sep 14, 2023 at 11:49 AM
    #74
    That's my other thought, if it won't crank from a different-start-allowed gear position. Asking to shift from P to N while cracking just to see if maybe it has something to do with the PNS (that's not "penis", breau! and it's not a definitive test, just for shits and giggles). My other thought is "old key in ignition", but could be a variety of other things, I'm sure.
    bmf4069[QUOTED] likes this.
  15. Sep 14, 2023 at 12:30 PM
    #75
    kyle11863
    kyle11863 Tundra Recovery Guy
    Kyle
    Big Bear CA
    1991 Toyota Pickup
    AllPro Rock Sliders Custom Short Travel Suspension Pretty Blue Lights Terraflex Hand Throttle Front and Rear Eaton E-Lockers Revolution 4.88s LCE Street Clutch Kit Mishimoto Radiator Lasfit Led Lights Mox Motors Rox Lights VoSwitch Switch Panel Lots of mud holding it all together
    So what exactly is the starter doing now? is it not doing anything, turning the engine over slowly, or turning it over normally but without it firing the engine? Depending on which it is can give clue to what the issue could be.
    I like the neutral start idea, but if the starter rotates at all during the attempts its not going to be that.
  16. Sep 14, 2023 at 8:01 PM
    #76
    RUSTYNUTS
    Rusty
    sOCal
    to be continued...
    I went thru and gave it a good wiggle-down this morning, all cables in and out of the relay box, and the motor harness. I've started it probably 10 times today. About 50% fired right up. The others took at most 7-8 key turns.
    When I turn the key and it does not start, it does still click, but as I said, it's not the same single loud click that it was before. It's much softer. Seems like before it was the solenoid clicking, and now possibly just the relay. Clearly a different click. Then maybe 10% of the time, it starts to turn over the motor, (very weak like a dead battery) not even a full revolution before nothing. If I hold the key turned, it doesn't continue trying to start, I have to release and turn again. The times that the starter spins normally, the truck starts, every time. I haven't had a chance to start checking legs for low continuity/high resistance (or open) with a multimeter yet, but I think I'm going to find a stranded wire breaking at a connector, hopefully not the one at the starter. I should note; I am doing all this with a 2 month old key that was cut at the dealership.
    shifty` likes this.
  17. Sep 15, 2023 at 4:14 AM
    #77
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    Yeah, sounds like something isn't letting full power through, but only sometimes. I hate intermittent faults, and I really hate intermittent electrical faults.
  18. Sep 15, 2023 at 7:58 AM
    #78
    RUSTYNUTS
    Rusty
    sOCal
    to be continued...
    That's why they're called 'gremlins', and notice how people are always talkin about chasing them more than catching them.
  19. Sep 15, 2023 at 8:35 AM
    #79
    Honestly, they're not good eatin'. Too slimy, too many bones.
  20. Sep 15, 2023 at 1:02 PM
    #80
    RUSTYNUTS
    Rusty
    sOCal
    to be continued...
    Well, neutral or park-same behavior.
  21. Sep 15, 2023 at 1:06 PM
    #81
    Mr.bee
    Mr.bee King Turdra
    SATX
    '02 AC TRD
    Swapped relays around?
    shifty` likes this.
