Starter and misc.
Discussion in '1st Gen Tundras (2000-2006)' started by tyler-brown, Oct 12, 2022.
  1. Oct 27, 2022 at 5:51 PM
    bfunke
    bfunke Tundra Curmudgeon
    South Carolina
    I would replace the rear crossover pipe. I'm told it can be done without taking off the intake but it looks to be nearly impossible. I have a leaking gasket on mine and have been putting it off for a couple months. Since you have the intake off just R2 it now.
  2. Oct 27, 2022 at 7:04 PM
    tyler-brown
    tyler-brown [OP] New Member
    Canada, B.C.
    2001 AC Tundra V8 LTD 4x4
    5" tuff country lift 2.5" Eibach front coil overs SPC upper control arms 33x12.5's JBA long tubes Jba mid pipes Jba full exhaust & muffler Dirty deeds 12 hole injectors Front hitch receiver
    Thats what i was afraid of.
    Oh. Everything is back together and I was doing a test run. Made it to a buddies & no leaks every thing was fine. On my way home I was...having fun:rofl:and opening er up. Than I started noticing a puff of smoke behind me...figured it was something worse than a coolant leak so I b-lined it home and when I stopped in the driveway I noticed steam coming from under the hood. So. At some point it must have come loose. I tapped it back in with a piece of wood & a hammer. If it happens again..jb weld it'll be.
    Thanks for the info guys!
    Tundra2 likes this.
