Started my Ham Radio install
Discussion in 'Recovery & Gear' started by vader7071, Sep 8, 2018.
  1. Sep 8, 2018 at 5:41 PM
    vader7071
    vader7071 [OP] New Member
    Dothan, AL
    2018 SR5
    Well, I finally made some progress. Got my antennas mounted. The true test will be this week to see how well the mount holds.
    Yes I know my choke coil doesn't need to go around the mount......lol just hanging it there for now as I road test the mount.
    Once this gets locked in, on to the mounting of the rigs.
  2. Sep 8, 2018 at 7:14 PM
    MotoTundra
    MotoTundra The Ocho
    Don
    I don't know a thing about HAM radio, but that looks cool.
  3. Sep 8, 2018 at 7:38 PM
    baylrballa
    baylrballa New Member
    2016 Black Crewmax Limited
    Ditto
  4. Sep 9, 2018 at 7:55 AM
    vader7071
    Dothan, AL
    2018 SR5
    @MotoTundra @baylrballa , thanks.
    For ham radio, think CB radio on crack, and those hand held family radios sold at Wal-mart on crack plus.
  5. Sep 9, 2018 at 8:03 AM
    MotoTundra
    MotoTundra The Ocho
    Don
    Nice!
  6. Sep 9, 2018 at 9:50 AM
    Randy Morton
    Randy
    Deepinahearta, Texas
    2012 Tundra Double Cab (I call it my Land Yacht)
    Great job. What radio are you using, and whose antenna mounts are those? How about some interior pictures?
  7. Sep 9, 2018 at 10:13 AM
    vader7071
    Dothan, AL
    2018 SR5
    Haven't quite got to the inside yet. That is next once these mounts pass my Interstate test this week.
    Radios are an Icom 706MKIIg and a TYT TH-9800.
    Antennas are a Comet UHV-6 and a Comet UHV-4
    Mounts. Ah, there it gets fun. I used this as a starting point:
    Tenq Car Antenna Mount Stainless Steel Car Clip Mount Trunk Lid Hatchback Mount Bracket for Mobile Vehicle Car Radio Car Two Way Radio Radio Antenna + 5m Antenna Cable
    Took the base off
    And drilled the hole out to 1/2". Then i got a 1/2" x 1" stainless steel carriage bolt, (2) 1/2" flat washers, (2) star washers, and a 1/2" stainless steel nut.
    From here on, I forgot to take pics. But I ground/cut two edges off the carriage bolt head so it would slip in the factory side rail.
    Slid the bolt into the rail, got it to the first notch, slipped on a flat washer, then a star washer, then the mount, the other star washer, the final flat washer, and then the nut.
    Tighten till it don't want to wiggle and screw the antenna on.
    I am worried at prolonged interstate speeds it may want to rotate, so I either have to figure out how to lock the unit from rotating, or move it to the rail at the front of the bed and have the antennas right at the cab. The latter is the absolute last resort.
    Total cost to mount both, maybe $80. $35 each for the 2 mounts, and maybe $10 tops in stainless steel hardware. And the mounts came with coax, so that helps alleviate some cost.
    Next step is to pull the back seat and mount the bodies, antenna tuner, 1 farad capacitor, and power distribution block.
    3rd step is mounting the faces. But I think I have that fully figured out.
  8. Sep 9, 2018 at 10:18 AM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    Stuff on crack is good... I think... just not people.
  9. Sep 9, 2018 at 1:44 PM
    HighDesertSurfer
    HighDesertSurfer Surf The Dirt
    New Mexico
    2018 SuperWhite DC TRD OR
    Leer shell
    Looking good on the truck, sir...and totally digging the bedside decal! :thumbsup:
    I find HAM radio very intriguing...in the truck, at home and especially for a grid down SHTF scenario!
    Getting a license seems like a worthy endeavor.
    And you need 2 antennas, eh?
  10. Sep 9, 2018 at 3:49 PM
    vader7071
    Dothan, AL
    2018 SR5
    A) TY!!! Custom made ;) goes well with my Deadpool costume.
    B ) yeah, the license is not that hard, and it is a fun hobby.
    C) well, I need 2 antennas because i am using 2 radios. But "technically" I really should be running 3. I've just combined 2 into 1.
  11. Sep 11, 2018 at 4:43 AM
    vader7071
    Dothan, AL
    2018 SR5
    Ok, suggestion. If you mount on the passenger side, all is good. If you mount on the driver side, either change to a nylon locking nut, change to a left-handed thread, or crank down on the nut like mad.
    Other than that, I have driven about 500-600 miles at 60 to 80mph and they have held up well.
  12. Sep 11, 2018 at 8:47 AM
    parallax
    parallax Professional Zamboni stunt driver
    Oregon
    2018 White Tundra Crewmax SR5 5.7 TRD 4x4
    Dash camera
  13. Sep 11, 2018 at 11:22 PM
    parallax
    Oregon
    Dash camera
    Looks awesome. I am still contemplating a vhf Mount. Can you send a pic of where you mounted your radio or control head.?
  14. Sep 12, 2018 at 2:51 AM
    vader7071
    Dothan, AL
    2018 SR5
    Haven't mounted the heads yet. So far, this is all I have done.
    My "plan" is to use these parts to mount the faces:
    https://www.amazon.com/dp/B0057JYEUG
    https://www.amazon.com/dp/B002KO5XVU
    https://www.amazon.com/dp/B07FN11KM2
    https://www.amazon.com/dp/B075V79QN6
    Use the cup mount in the very front cup holder, then mount the ball on the back of the face. This lets me swing the faces where I want.
    But, I haven't done it yet. Got to order the parts.
  15. Sep 12, 2018 at 6:33 AM
    Wilbur
    Wilbur New Member
    Savannah, GA
    2014 MGM
    This is awesome. I want to put a CB in my truck since I do a lot of highway driving. Nice to know what is going on around you.
    vader7071[OP] likes this.
  16. Sep 12, 2018 at 7:24 AM
    Tierhog
    Tierhog SIG-AHOLIC
    2016 Tundra Crewmax Limited 4WD
    Mostly stock/TRD accessories/Morimoto XBs
    Oh yeah? Check this guy out.
    texasrho83 likes this.
  17. Sep 14, 2018 at 3:02 PM
    vader7071
    Dothan, AL
    2018 SR5
    Well, after driving over 1,500 miles on the interstate over a week, still had a little of the layover issue. But it was a ridiculously easy fix. The factory tie down points that slide in the rails? Yeah. They but right up next to the mount and keep them from rotating over. No cost fix.
    I'll get a pic and post it.
  18. Aug 1, 2022 at 8:06 AM
    GuyActual
    GuyActual New Member
    Guy
    2022 Toyota Tundra TSS (SR5+)
    2022 TRD Skid Plate
    Vader7071,
    I wanted to take a moment to thank you for this forum post. I just purchased a 2022 Tundra and have been looking for an Antenna mount solution for the integrated rail, thus far this seems like the best solution.
    Are you still using the mount in this configuration, and how has it held up to the testament of time?
    -GuyA
  19. Aug 1, 2022 at 8:18 AM
    Welcome from NY.
    Vader hasn't been on here in over 3 years, FYI.
    Mater and texasrho83 like this.
  20. Aug 1, 2022 at 8:35 AM
    GuyActual
    Guy
    2022 TRD Skid Plate
    Well Darn....
    Was really hoping that they would be able to respond. If anyone else has tried this, I would love to hear any feedback. (Or if there is another solution that anyone has tried. Ill keep looking too. )
    Thanks Jim!
  21. Aug 1, 2022 at 8:41 AM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    @TRDFerguson might be able to chime in on a rail mounted antenna as he's got one
    TRDFerguson likes this.
  22. Aug 1, 2022 at 9:11 AM
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrĂĽeMax
    I'm using this mount for my light whip, but it's very well made and heavy duty - should be no problem using it for radio antennas.
    https://www.bayareametalfab.com/Bed-Rail-CB-Mount_p_54.html
    JwBgKDDmu6nsOxgmXQ3aVy4VorSddmX4qd0TEO3Z_dc28d06bcbfb44188f68bb5c5eb785de88bc0d59.jpg
    Disregard the plastic chips from the bull ring install...
    xXR2i9EXhl3xK00D1pWx8TmMU02O4shEXR8rJCil_eec1e953953d09ec2faedce8f83d89013b9f19e1.jpg
  23. Aug 1, 2022 at 11:07 AM
    GuyActual
    Guy
    2022 TRD Skid Plate
    Is it mounted directly to the bed? (Drilled)
    the link looks like it may work with the rail system, but not entirely sure.
    thank you for the post, this looks very sturdy and looks well designed.
  24. Aug 1, 2022 at 11:33 AM
    TRDFerguson
    Jake
    2018 MGM CrĂĽeMax
    It works with the rail system. BAMF provides T-nuts that will work with the OEM bed rails, but I made DIY rails out of unistrut and had to use spring rail nuts instead.
  25. Aug 1, 2022 at 11:51 AM
    GuyActual
    Guy
    2022 TRD Skid Plate
    This is Perfect!!!
    Thank you TRDFerguson I just looked at your thread on your build and I have to say its inspiring. Congrats on an awesome build, and now I have something to get ideas for my 2022. I build my own batteries and was thinking about installing one of my larger cell batteries in the center console. its comprised of 12 40152 Headway batteries with a 100amp BMS. It would be nice to have a stand-alone power system to pull from along side the trucks system. Also looking at a number of upgrades and your thread is simply awesome.
    Thank you again!
    GuyA
  26. Jul 25, 2023 at 1:38 PM
    boundless4x4
    boundless4x4 New Member
    nhan
    Nice set up
