Staining my deck
Discussion in 'Home Improvement' started by Pudge, May 23, 2017.
  1. May 23, 2017 at 2:44 PM
    Pudge
    Pudge [OP] Super Secret Elite Member #7
    CT
    2015 Blue Ribbon Platinum
    I redid my decking last year. I had previous repaired framing. Had to do it in stages for cost reasons.
    It has come time to stain it. I don't need to or really even want to match the color that's their but I could. Just looking for advice on what products to use and if anyone has experience with this. It's pressure treated lumber. I'll clean it and use a wood brightener then stain. Thanks for any advice
  2. May 23, 2017 at 4:34 PM
    JMB
    Chesapeake, VA
    2013 Super White Tundra DC
    Pudge[OP] likes this.
  3. May 23, 2017 at 5:00 PM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    I like that deck! Loving the color
  4. May 23, 2017 at 5:07 PM
    tye
    tye New Member
    tye
    2016 TRD Pro DC
    Diamondback cover, flowmaster exhaust, n-fab sliders
    I recommend sanding the deck prior to staining to clean and smooth out potential splinters
  5. May 23, 2017 at 5:07 PM
    Patriot
    Patriot Member
    Western NC, “Boondocks”
    I always thought that the drift would stain looked pretty cool and aged well in the sun. But really it depends what you like bro. Looking good!
  6. May 23, 2017 at 5:16 PM
    Pudge
    CT
    Even if it's brand new wood?
  7. May 23, 2017 at 5:19 PM
    Bad ass deck
    GNTundra and Pudge[QUOTED][OP] like this.
  8. May 23, 2017 at 5:23 PM
    Tacogrande
    Tacogrande New Member
    Jeremy
    2016 SR5 dbl. cab long bed gray
    Husky weatherbeaters,short antenna,window deflectors
    Might be worth it to look at sikkens products usually found at a real paint supply.
    1UPPER and MakMurph like this.
  9. May 23, 2017 at 5:25 PM
    Pudge
    CT
    I have read good things about sikkens that's high on my list right now
  10. May 23, 2017 at 5:46 PM
    Alloutdrs1
    Alloutdrs1 New Member
    Andrew
    Virginia Beach, VA
    Sikkens is a good product but make sure you follow all guidelines when applying. I have seen some messed up decks from people using this brand and don't have an understanding of it. Flood also makes some good products as well. Biggest thing is prep it correctly, when rolling make sure you use long when strokes to avoid lap marks. I usually will run 2 boards at a time and go full length and repeat until done. It makes for a better finished product.
    driverdog, MakMurph and Pudge[OP] like this.
  11. May 23, 2017 at 6:15 PM
    Pudge
    CT
    Thanks guys. Doing the "picture framing" work was a pain in the ass. Took much more work, had to add extra framing and bracing but it was well worth it for the look and no end grain showing. Here a few pics of the process.
  12. May 23, 2017 at 6:19 PM
    Pudge
    CT
    Then I removed the railings, added new top and bottom rails, reused 4x4 posts which were good and well anchored also kept the ballasters which saved me a few hundred bucks and they were in good shape.
    I used GRK deck screws and GRK structural screws to beef up framing. I highly recommend GRK products. So nice to work with. Also I added this outlet because I had no power out there.
  13. May 23, 2017 at 6:22 PM
    CM-LENNY
    CM-LENNY No Complaints
    San Diego, CA
    2015 4x4 CrewMax SR5
    PRO shocks, 37's Nitto G2's 4:88 diffs, few other mods
    Nice clean work. You have a great eye for detail...:thumbsup:
    GNTundra likes this.
  14. May 23, 2017 at 6:33 PM
    Pudge
    CT
    Thanks. It took me forever lol. Did it alone with "help" from my at the time 4 year old daughter
  15. May 23, 2017 at 6:47 PM
    R0CKETMAN
    R0CKETMAN IG: @rocketmanmtb
    NGAMTNS
    '17 TUNDRA TRD PRO CEMENT ‘15 TUNDRA SR-5 WHITE
    I used Australian Timber oil in natural. Good stuff and keeps look of wood.
  16. May 23, 2017 at 6:49 PM
    Pudge
    CT
    I did the deck about 10 months ago. You think I should wait longer? I really want to make sure I do it right so I'm not doing it every year
  17. May 23, 2017 at 7:38 PM
    R0CKETMAN
    NGAMTNS
    Long enough. You're gtg
    driverdog likes this.
  18. May 24, 2017 at 5:14 AM
    Alloutdrs1
    Andrew
    Virginia Beach, VA
    Rule of thumb for pressure treated lumber is if you spill some water on it and the water beads then its not ready to accept a topcoat.
  19. May 24, 2017 at 1:33 PM
    Pudge
    CT
    Anyone have experience with Benjamin Moore arbor coat oil based deck stain. Or TWP stain? Local store has them both.
  20. May 24, 2017 at 2:08 PM
    Darth Tundra
    Curt
    17 CM TRD Black
    Nice work !!!!...I had a HUGE deck at my last home i owned....Penofin Stain !!!!..Awesome product ...a tad spendy !!!..But you get what you pay for !!
  21. May 24, 2017 at 2:10 PM
    Pudge
    CT
    I need to stop reading online reviews and just buy something lol.
    Now I'm considering Armstrong Clark stain. Has great reviews but not available locally, so I'd have to order online.
  22. May 24, 2017 at 2:15 PM
    Darth Tundra
    Curt
    17 CM TRD Black
    Penofin Stain is top notch....The best stain I have ever used
    Pudge[QUOTED][OP] likes this.
  23. May 24, 2017 at 2:30 PM
    Darth Tundra
    Curt
    17 CM TRD Black
    LOL.....Yes, online reviews are not reliable as you have inexperienced people applying the product and not having a clue on what they are doing....all I can tell you is my experience with Penofin. My deck was 850 sq. feet ........it lasted for a good 7 years before I had to treat it again.
  24. May 24, 2017 at 2:56 PM
    Pudge
    CT
    That's awesome. Where do you live?
  25. May 24, 2017 at 2:59 PM
    Darth Tundra
    Curt
    17 CM TRD Black
    I did live on the Oregon Coast at the time I had the deck...I now live up in Portland....There are probably a few other good stains out on the market, just giving you my experience with the Penofin.....and the Oregon Coast gets A LOT OF RAIN !!!....Thompsons water stain IMO....IS GARBAGE !!!
  26. Jun 17, 2017 at 4:14 PM
    Pudge
    CT
    Finally got around to getting the deck cleaned and prepped for stain today. I used a product called restore a deck. It has a cleaner and a wood brightener. I used my power washer as well and I think it came out great. Took a couple hours but the gray color is all gone and the wood looks even and brand new. It rained after I finished so only pic I have now, the deck is wet. Will post more pics as I go.
  27. Jun 17, 2017 at 4:14 PM
    Pudge
    CT
    This attachment came with my Kärcher post washer. I was surprised how well it worked and the time and effort it saved me
  28. Jun 17, 2017 at 4:17 PM
    Pudge
    CT
    I ended up getting 5 gallons of armstrong clark oil based stain online. It was $20 more than most 5 gallon pails I could find at big box stores. Shipping was free and I got the restore a deck along with it for $40, and they sent enough of that to use on my deck twice so I will have enough for the next restain
  29. Jun 17, 2017 at 4:35 PM
    1UPPER
    1UPPER Not A New Member
    TEXAS
    Flux capacitor!
    Just make sure before you stain you let the deck wood dry out since you power washed it . I do like the Sekins products as well. Very good stuff if applied correctly. If you are ever in doubt about the process call the phone number on the product for questions. I find they often tell you tips and hints you don't find on the product labels.
  30. Jun 17, 2017 at 5:00 PM
    Pudge
    CT
    It will have at least 3 or 4 days to dry by the time I'll be able to get around to staining it.
