SSO Slimline Bumper - Install and First Impressions
Discussion in 'Recovery & Gear' started by Cemented, Apr 6, 2018.
  1. Jun 24, 2020 at 12:49 PM
    #241
    mightyowl
    mightyowl New Member
    does the weight of the bumper and winch enough to dip the height on front end?
    Beesta likes this.
  2. Jun 26, 2020 at 3:24 PM
    #242
    Weavin Pro
    Weavin Pro New Member
    2020 Army Green TRD PRO
    Not at all!!!!
  3. Jul 24, 2020 at 10:33 AM
    #243
    Uhhhh....
    Uhhhh.... New Member
    Dave
    2016 Silver Limited DC
    7” BDS, 37s
    Finally arriving on Wednesday. It was originally ordered in Nov; extra delay cause lots of Black Friday sales; changed my mind on the "no access holes" in March and modified order to have access holes. (I was originally gonna get a Warn Zeon 12k winch w/ remote, but after stewing on it for a long time, I couldn't justify that ridiculous price tag of $2k. Waaay overpriced. Went with a Smittybilt XRC Gen3 12k for $665.) Changing to having access holes started the bumper process all over, which is fine. Then COVID hit. Just got email today saying it shipped.
    @Weavin Pro How long did the install take you?
    Tundyfundy likes this.
  4. Jul 25, 2020 at 3:26 AM
    #244
    Weavin Pro
    Uhhhh congratulations! Lol
    It took me and a buddy about 4-5 hours to install. We weren’t busting ass or anything...just a steady pace. It’s actually a pretty easy, straight forward install, but definitely need 4 hands! Post some pics!
    Beesta and Uhhhh.... like this.
  5. Aug 12, 2020 at 2:14 PM
    #245
    Weavin Pro
    Be careful! I was winding my winch cable in and bowed the bumper a little! I have a Factor 55 flat hook and hit the IN button a little extra and could actually see the bumper metal bend in...I quickly hit the OUT button and it popped right out...just be careful!
  6. Aug 12, 2020 at 3:22 PM
    #246
    Uhhhh....
    Dave
    7” BDS, 37s
    Yeah I noticed there was a chance that could happen. Gotta be careful!
    Mine is on. I still have a little more work to do. All together, it took me about a full 24 hours or so. Three different days. (Everything tends to take me a while though. I'm meticulous, go kinda slow.) I initially got it all installed in one day (bout 8 or 9 hours...told ya I'm slow), but then had severe rubbing issues on bumper ends. I'm running 37s. It would've torn the bumper clean off if I drove it like that. Lol. B/c of the thickness of the SSO steel that went on the frame bolts (same bolts I had bumper shims on), I couldn't fit the bumper shims anymore.
    Long story short, the only options I had was to get a different bumper - which wasn't an option - or replace the frame bolts. So I cut out the OEM frame bolts (the three bolts lined up vertically on each side) and put in longer ones. It's all together now w/o rubbing for the most part. Still have slight rubbing at full cut in reverse only (same thing happened when I needed to trim just a hair more off bumper plastic before the SSO install). I have it shimmed out about an inch or so right now using the new 2" bolts. Have to buy 2.5" bolts & install them so I can shim it another 1/2" or so. Then I'll be good.
    Sounds like a pain, but I did it solo & it was pretty fun. Pics eventually...
  7. Aug 12, 2020 at 6:30 PM
    #247
    Northern Inferno
    Northern Inferno New Member
    2016 Tundra Trd inferno
    Ome bp51, JBA uca
    Mines being installed today. I'll post picks when I get it back.
  8. Aug 14, 2020 at 8:32 PM
    #248
    Weavin Pro
    Geez Uhhhh, would love to see pics...37s!!!
    Uhhhh.... likes this.
  9. Aug 15, 2020 at 6:17 AM
    #249
    Rc23
    Rc23 New Member
    Ross
    Chesapeake
    '16 Super White CrewMax
    I really like this setup but I’m kind of in the same boat with uhhhh
    Im on 37’s too and have my bumper shimmed out and trimmed as well. *subscribing
  10. Aug 17, 2020 at 1:36 PM
    #250
    Uhhhh....
    Dave
    7” BDS, 37s
    In order to get the shims on, these are the new 3/8, 2.5” long, grade-8 bolts I replaced the OEM frame bolts with. (Cut out old ones with angle grinder.) Three on each side. My shims comprised of leftover OEM frame nuts (the galvanized ones in pic) that fit over the new 3/8 bolts nice & loosey-goosey. Then a new grade-8 flange nut over it (shiney zinc-coated in pic), tightened down till you fart.
    Finished product below. It still needs some minor adjustments. The passenger side OEM bumper is sitting a little higher than driver side. It’s most pronounced right above the SSO. I’ve taken this thing apart and put it back together so many freaking times that I don’t care one side is sitting higher than the other. I’m sure at some point I’ll have to take it back off for something else, and I will adjust it then.
    Re-shimming gave me full clearance again; the only downside was it made the OEM bumper sit out further than the SSO. If you look closely, you can see about a 1 inch gap between OEM and SSO (on both ends of the SSO). Again, I’ve taken it apart and put it back together so many times that I really don’t care anymore. It did bothered me at first, but I’ve accepted it. I’m not getting rid of my 37’s!
    Beesta and mgm16trdpro like this.
  11. Aug 17, 2020 at 1:40 PM
    #251
    Uhhhh....
    Dave
    7” BDS, 37s
    A closeup of that gap.
    Rc23 likes this.
  12. Aug 17, 2020 at 2:24 PM
    #252
    Rc23
    Rc23 New Member
    Ross
    Chesapeake
    Dammit - now I want those tow mirrors too.
    I shimmed my stock bumper with spacers I bought to clear my 37's also.
    *side* just noticed your tags - where in VA are you? I'm in Chesapeake.
  13. Aug 17, 2020 at 3:44 PM
    #253
    Uhhhh....
    Dave
    7” BDS, 37s
    Lol. The tow mirrors are expensive! Well, the power-folding ones are. I think the non-power folding are quite a bit cheaper.
    I’m in Ashburn, about a half hour west of DC.
  14. Aug 17, 2020 at 8:22 PM
    #254
    Rc23
    Rc23 New Member
    Ross
    Chesapeake
    Yea I’m good without the power. Just need the extra view. I lived in Chantilly for a few years and Fairfax. Parents lived outside of Sperryville.
    Uhhhh....[QUOTED] likes this.
  15. Aug 18, 2020 at 4:02 AM
    #255
    Uhhhh....
    Dave
    7” BDS, 37s
    I don’t blame you for moving. Very busy area - and not very friendly either.
  16. Aug 21, 2020 at 4:35 AM
    #256
    Beesta
    Beesta New Member
    Jay
    Loudoun County
    2019 Pro Midnight Black Metallic
    Hey man.. pretty tough looking ... i also have a Pro but worried about the TSS sensor with getting the BullBar ... any issue with this at all ..?
  17. Sep 9, 2020 at 10:54 AM
    #257
    crabbymcnab
    crabbymcnab New Member
    2016 Inferno SR5
    what did you use to mount your license plate? MD requires a front and I haven’t figured out how to mount mine yet.
  18. Sep 9, 2020 at 10:57 AM
    #258
    crabbymcnab
    2016 Inferno SR5
    FYI, if anyone is interested, the Diode Dynamics 30 inch light bar fits the SSO brackets. The light bar sticks out of the cutout a tad, but it’s secure in there
  19. Sep 9, 2020 at 11:17 AM
    #259
    Uhhhh....
    Dave
    7” BDS, 37s
  20. Sep 9, 2020 at 11:29 AM
    #260
    crabbymcnab
    2016 Inferno SR5
  21. Oct 10, 2020 at 5:28 PM
    #261
    Northern Inferno
    Ome bp51, JBA uca
    Here's my SSO bumper. Haven't decided on the winch to go with I'm thinking smittybilt x20 or warn platinum I want the wireless remote.
    Beesta, Wrongside and mgm16trdpro like this.
  22. Nov 11, 2020 at 3:47 PM
    #262
    Weavin Pro
    Late response...but I have had zero issues with the TSS sensors. Everything works as it should.
    Also, I have the Smittybilt X20 wireless winch, have used it a dozen times, works perfectly!
  23. Nov 11, 2020 at 3:54 PM
    #263
    fundra_goes_west
    fundra_goes_west I’m just a guy with a girl
    Evan
    2022 SQ8
    I will be selling mine in Denver in the next month or so if anyone wants to skip the lead times and save a few bucks.
  24. May 9, 2021 at 4:23 PM
    #264
    Piki
    Piki New Member
    2017 Tundra crewmax 1794 TRD
    After 6 months of waiting my SSO bumper showed up and is installed.
  25. Nov 15, 2021 at 11:04 AM
    #265
    TrdPro89
    TrdPro89 New Member
    Did you end up selling this bumper?
  26. Nov 15, 2021 at 11:46 AM
    #266
    fundra_goes_west
    Evan
    2022 SQ8
    I did
  27. Nov 15, 2021 at 11:51 AM
    #267
    TrdPro89
    TrdPro89 New Member
    Thanks
  28. Nov 30, 2021 at 4:53 PM
    #268
    Tonkatoytaco
    Tonkatoytaco New Member
    Louie
    Maryland
    2017 Platinum XP MGM
    LRO 3/1 Leveling Kit, Dirty Deeds 10" exhaust, Bully Dog Programmer, AFE Super stock Intake with TB Spacer, Custom Rough Country Grill, Andres Devil Horns, Caliraised Fog lights, Morimoto XB Headlights, HRS taillight, Boost Auto tow mirrors, LED interior lights and Reg, light, Trail edition bed compartment, TRD rear sway bar, weathertech floor mats and window visor, Nitto Ridge grappler.
    Just ordered my SSO slimline for my Tundra. Im sure I'll be on a waiting list but is there anything I need to plan for before I get it? 1 Question is I see you guys have a rubber edge around the bumper where you cut out the plastic bumper. Does that come with the SSO bumper?
    Piki likes this.
  29. Nov 30, 2021 at 5:35 PM
    #269
    Piki
    Piki New Member
    Nice.
    Yes it will come as a kit with everything what you need for install.
    Tonkatoytaco[QUOTED] likes this.
  30. Dec 1, 2021 at 4:02 AM
    #270
    Tonkatoytaco
    Louie
    Maryland
    Perfect thank you, now its just a waiting game
