SR5 "Upgrade" not 38GL tank?
Discussion in '2.5 Gen Tundras (2014-2021)' started by Norfolk757, May 29, 2018.
  1. May 29, 2018 at 5:38 AM
    Norfolk757
    Norfolk757 [OP] עַם יִשְׂרָאֵל חַי
    Tom
    Norfolk, VA
    2015 White Tundra- CrewMax TRD Off Road
    I hate posting because as usual, some jackass will make a comment about doing a search for the question.... I did and still have questions.
    I just got a 2015 CM that show up as the "SP SR5 Upgrade Package" and the "OF TRD Off-Road Package" from the Toyota website in regard to the packages that were installed at the factory. I was under the impression that the SR5 Upgrade would include the 38 Gallon tank but Ive already filled this truck two times and it only holds 26 Gallon.. What is that about?
    Thank you all who are helpful and a kind community of Tundra owners.
  2. May 29, 2018 at 5:56 AM
    alpinepro4
    alpinepro4 What is your MPG Today!
    Pat
    2017 TRD Pro Cement DC
    Baja Designs Squadron Sport Fog lights, ARE CX Series Topper, Alcan Springs , DAP Tune, Coach Builder +1 Shackles, Headlight Revolution Supernova V.4 LED bulbs, HR LED interior bulbs. General Grabber ATX 275/70/R18
    I don't think 38 gal tank was availible till 2016. I know the TRD Pros didn't get 38 gal tank till 2016. Pro is SR5 with upgrades.
    Norfolk757[OP] and Boerseun like this.
  3. May 29, 2018 at 5:59 AM
    BlueBottle
    BlueBottle not a PRO
    '16 Platinum 4x4
    See fine print
    You are not tripping. The 38g didn’t come out until 2016 so you don’t have it. :D
    Norfolk757[OP] likes this.
  4. May 29, 2018 at 6:03 AM
    Norfolk757
    Tom
    Norfolk, VA
    Ahhh.... I see, Thanks @BlueBottle I have been doing a whole bunch of search and somehow missed that little fact.
  5. Jun 9, 2018 at 9:06 PM
    Wolvi71
    Wolvi71 New Member
    Franco
    2016 red tundra SR5
    @Norfolk757
    What MPG are you getting with your tundra. I also have a 2016 SR5. Every time I fill up the tank it tells me I have 320 miles til empty but I feel that is wrong if it has a 26 gallon tank. That would be around 12.30mpg
  6. Jun 9, 2018 at 9:09 PM
    alpinepro4
    Pat
    How many gal are you putting in at empty?
  7. Jun 9, 2018 at 10:52 PM
    big_jarv
    big_jarv New Member
    2021 TRD Pro
    Mine says ~426 every time I fill up with my 38 gallon tank.
  8. Jun 10, 2018 at 3:59 AM
    Norfolk757
    Tom
    Norfolk, VA
    That sounds right about mine. I get 13.2 mpg no matter how hard or gentle I drive.
  9. Jun 10, 2018 at 6:19 AM
    alpinepro4
    Pat
    I DAP tuned mine and get 519 miles out of a tank or 17.7 mpg. Hand calculated so it’s right. Tune changed my mileage. Most of the time that driving 55 to 60 mph. Before I was getting 15 to 16 mpg or 478 miles out of a tank.
    You guys running stock tires or larger? I am still running stock. Figure mileage will change once I get 275 70 R 18.
  10. Jun 10, 2018 at 10:56 AM
    Wolvi71
    Wolvi71 New Member
    Franco
    2016 red tundra SR5
    That’s what I am afraid of. How much will the MPG be after modification of tires and lift.
    I don’t want to be at 10-11mpg.
  11. Jun 10, 2018 at 12:53 PM
    JeremyGSU
    JeremyGSU New Member
    Jeremy
    2016 Tundra
    The 320 run to 0 is only about 20-22 gallons back in the tank so do your math based off that and you'll be getting better than 12.3. 320/21= 15.23
    Typically:
    26 gallon tank = 20-22 gallons back in
    38 gallon tank = 30-32 gallons back in
    Toyota has a VERY early low fuel warning.
    Wolvi71[QUOTED] likes this.
  12. Jun 10, 2018 at 6:41 PM
    Wolvi71
    Wolvi71 New Member
    Franco
    2016 red tundra SR5
    That’s what I figured but everywhere I looked all I saw was that 2016 tundra has a 26 gallon gas tank. I figured my tundra has a 23g tank. That is the only way it could show me on a full tank I had 320 miles before empty.
    Thanks
  13. Nov 28, 2018 at 8:19 AM
    Ronin73
    Ronin73 New Member
    2019 Tundra Crewmax SR5 4x4 5.7 Magnetic Grey Metallic
    Mine says 560 after every fillup.
  14. Nov 28, 2018 at 6:41 PM
    mojojo
    mojojo New Member
    2018 Cement SR5 CM
    I have a 2018 sr5 crew max with 26 gallon tank and bench seat. The 38 gallon tank and bucket seats is the first upgrade for the sr5 package as of 2018 my.
  15. Nov 28, 2018 at 7:07 PM
    Hammy68
    Hammy68 Peak Bagger
    New Hampshire
    2018 Silver Tundra TRD Off Road Crewmax
    RC 1.75” Front, 1” Rear, TRD Dual Exhaust, Nitto RGs 275/70/18, TRD Center Caps, Rugged Cover Hard Tonneau, Rhino Liner, LED interior/exterior upgrade
    Mine said 530 miles when I filled up with 275/70 RGs. Now with studded Cooper M+S 275/70s, it says 485 upon fill up. 38 gallon tank
  16. Nov 28, 2018 at 7:13 PM
    airgunner
    airgunner New Member
    N-KY
    2015 DC MGM TRD
    This is the answer. The 38gal tank didn't come with the SR5 upgrade package until 2016.
    I made the same mistake. Bought a '15 last year assuming it had the bigger tank because it had the SR5 upgrade package and boy was I disappointed the first time I filled up from empty. :(
  17. Nov 29, 2018 at 12:27 PM
    curt37
    curt37 New Member
    FRESNO, CA
    2018 Tundra Limited Crew Cab white
    SNUGTOP BED COVER
    If you calculate the hash marks on the fuel gauge, each mark is 8 gals. I tow a travel trailer (5200 lbs) and to the camp ground 274 miles, and when I filled up I took 24+gals, and I was on the 1/4 mark. So with that I stilled had 16 gals left, from what Toyota has told me when the gauge is pointed to empty you still have 8 gals in reserve.
