SR Trim
Discussion in '3rd Gen Tundras (2022+)' started by TicTacx, Dec 4, 2021.
  1. Jan 21, 2022 at 8:32 AM
    #91
    SRPoor
    SRPoor New Member
    Is the plastic thing on top of the tailgate color matched in the other trims or missing? I haven't seen one in person and I can't tell.
  2. Jan 21, 2022 at 8:47 AM
    #92
    SRPoor
    SRPoor New Member
  3. Jan 21, 2022 at 9:05 AM
    #93
    mountaingroan
    mountaingroan New Member
    North Idaho
    2020 SR5 DC VooDoo 4WD Bench!
    Thanks for posting, great pics. That's exactly what I'm awaiting but add the spray-in liner and 4WD.
    Curious if the SR has the same center console 4WD actuator button as the SR5? Suspect that Toyota may have put a more plain setup on the dash.
  4. Jan 21, 2022 at 9:10 AM
    #94
    gulfcoast850
    gulfcoast850 New Member
    Thanks for the detailed inside pics. Gets me excited for mine to arrive. Almost a month late but looks like it will be worth it!
  5. Jan 21, 2022 at 9:34 AM
    #95
    SRPoor
    SRPoor New Member
    Looking at the SR video posted by london toyota it looks like selector is in the same place on the console. Here is a screenshot.
    https://www.youtube.com/watch?v=wRmu0xfHG2k
  6. Jan 21, 2022 at 9:43 AM
    #96
    mountaingroan
    North Idaho
  7. Jan 21, 2022 at 7:34 PM
    #97
    TitanTiger09
    TitanTiger09 New Member
    Very true. Most of my driving (90%+) is spent on interstate 65 and then a state highway so I would likely see mpg towards the top end of the epa rating. The larger tank would just come in handy for longer trips with the family, honestly.
    Quick comments about the de-tuned engine…
    Ford does the same thing in its lineup, except they use a completely different engine instead of the same one with different software tunes (I’m making an assumption that the SR engine itself is identical to the SR5 and above). The 2.7 ecoboost power output is nearly identical to the SR power output.
    2.7 ecoboost - 325hp / 400lb ft
    SR 3.5 twin turbo - 348hp / 405lb ft
    Don’t know the exact sales numbers but I’m pretty sure the 2.7 ecoboost sells really well in the f150…more than the 5.0 v8 and probably as well as the 3.5 ecoboost or better.
    My guess, without having driven a new tundra in any configuration, is that the SR engine variant is quite enjoyable to drive simply given how popular the 2.7 ecoboost is and especially when you factor in how quickly you hit peak power with the tundra engine.
    In some ways I wish Toyota would have taken a page out of Ford’s playbook and offered both engine variants, as well as the hybrid powertrain in all trim levels (Ford’s powerboost hybrid is available in their lowest trim level).
    TL;DR
    Fuel tank size probably won’t be an issue for most people, including me. A few more options for powertrains and add on packages throughout all trim levels would be nice.
    mountaingroan likes this.
  8. Jan 21, 2022 at 7:44 PM
    #98
    mass-hole
    mass-hole New Member
    The 2.7L is a ridiculously good engine. By all accounts its the perfect half ton motor. Its very reliable, it gets very good mpg, and if you exceed its capabilities you should probably be looking at a 3/4 ton or more.
    The detuned 3.5 in the SR is really, really weird to me. If its physically identical to the higher trim engine, then it wont get better mpg. For a given engine load, how would toyota tune it more efficiently if everything else is the same? I would assume if both engines are physically the same then the fuel they require to create a certain power is the same. Why would Toyota want the higher spec motor to get worse mileage.
  9. Jan 21, 2022 at 8:00 PM
    #99
    TitanTiger09
    That’s a great question that I don’t have an answer for to be honest.
    Here’s a stupid question(s) that someone smarter can probably answer…you can buy aftermarket tuners for trucks, correct? Some of those products have different pre-set tunes whether it’s for more power, achieving better mpg, or giving you a little of both, correct? If those aftermarket tuners actually yield results then how do they actually work? Wouldn’t that be our answer as to how Toyota is “de-tuning” an engine to achieve slightly better mpg.
    To your point though, there could very well be a mechanical or physical design difference between the SR engine and the one used in higher trims. Meaning, it’s not just a difference in programming like we are all assuming.
  10. Jan 22, 2022 at 3:32 AM
    #100
    raylo
    raylo not so new member
    Frederick, MD
    Does seem silly to me, too. It's almost like the detuned motor's default would be similar to how the higher trim motor might behave in Eco mode to cap the power and maybe alter the boost curve.
    Henry1jg likes this.
  11. Jan 23, 2022 at 6:30 AM
    #101
    yooperbikemike
    yooperbikemike New Member
    2022 SR5 TRD OR Premium CM 5.5
    So, I'm checking the major on-line tire sellers for snow tires and find that they carry no tires of *any* kind in the SR OEM size (245/75R18)...
  12. Jan 23, 2022 at 6:49 AM
    #102
    ezdog
    ezdog New Member
    Gateway To The West
    So get a different size?
    Which year truck do you have?
  13. Jan 23, 2022 at 6:52 AM
    #103
    yooperbikemike
    I haven't bought yet, but I'm considering a 2022 SR. Reason for searching is that I usually mount snow tires on dedicated rims.
  14. Jan 23, 2022 at 6:56 AM
    #104
    ezdog
    ezdog New Member
    Gateway To The West
    Well you can usually easily substitute for different sizes pretty easily.
    RavingOx likes this.
  15. Jan 23, 2022 at 8:07 AM
    #105
    raylo
    Frederick, MD
    Yup... even get a different size wheel and different aspect ratio tires that work out to ~ the same diameter and width as the OEM. Lots of options that way, especially for snow tires/wheels where wheel appearance may not be very important.
  16. Jan 23, 2022 at 8:09 AM
    #106
    SRPoor
    SRPoor New Member
    Is the bolt pattern different on the sr?
  17. Jan 23, 2022 at 9:06 AM
    #107
    ezdog
    ezdog New Member
    Gateway To The West
    I can not imagine why it would be?
  18. Jan 26, 2022 at 6:45 PM
    #108
    alibongo
    alibongo New Member
    White looks good with black wheels and a level kit.
    Henry1jg, junior, MTRock and 3 others like this.
  19. Jan 26, 2022 at 6:55 PM
    #109
    17TundraDCEd
    17TundraDCEd New Member
    Ed
    SE Pa
    2018 White SR5 Crewmax
    Rear Sway Bar
    I like it. Which wheels are they?
  20. Jan 26, 2022 at 7:50 PM
    #110
    mountaingroan
    North Idaho
    Bitchin' SR!.... Thanks for sharing.
  21. Jan 27, 2022 at 1:51 AM
    #111
    TitanTiger09
    Nice looking truck. Is this yours? If so, would love a report on how it drives and handles especially with the de-tuned engine.
  22. Jan 28, 2022 at 7:09 AM
    #112
    alibongo
    alibongo New Member
  23. Jan 28, 2022 at 7:09 AM
    #113
    alibongo
    alibongo New Member
    Sorry for the delay guys. No its not mine. Found the photo on the net.
  24. Jan 28, 2022 at 7:59 AM
    #114
    gulfcoast850
    Has anyone got a truck from south east Toyota? My truck was allocated to my dealer since it was built in early November with delivery around the end of December. I put my deposit down December 10th was told 15 to 20 days. I still have not received the truck dealer says it’s been sitting at port since January 1st. Nobody knows why. No package add one just the basic sr crew max 4x4.
  25. Feb 17, 2022 at 5:18 PM
    #115
    gulfcoast850
    I got my sr crewmax 4x4 on Valentine’s Day. So far I love this truck! I will be adding some different wheels and tires. Also putting on predator steps.
  26. Feb 17, 2022 at 5:51 PM
    #116
    yooperbikemike
    I've been looking all over for that exact truck but couldn't find one listed anywhere.
    gulfcoast850[QUOTED] likes this.
  27. Mar 4, 2022 at 7:03 PM
    #117
    Warthogdrifter
    Warthogdrifter New Member
    Test drove a SR crewmax today. Both the lady and I thought it felt faster than her 21 double cab. I really like it a lot. Can't image it with the SR5 higher boost. Unfortunately the dealer in Daytona, FL wanted a 6k mark up, so I didn't buy it. Sorry for the one picture. I should have taken more but they got pretty hostile when we disagreed on the price.
  28. Mar 4, 2022 at 7:07 PM
    #118
    Warthogdrifter
    Not sure if this is common knowledge, but something I found awesome was the lack of fake V8 sounds in the cabin. I guess that's a premium speaker lol. I could clearly hear the turbos and I really enjoyed that.
    Henry1jg and OnThaLake like this.
  29. Mar 5, 2022 at 7:06 AM
    #119
    Totherion
    Totherion New Member
    I don't care how bad the market is right now. One should never pay over msrp.
    You made the right call.
  30. Mar 5, 2022 at 7:52 AM
    #120
    yooperbikemike
    PXL_20220304_181640114.jpg PXL_20220304_181554110.MP.jpg So, I finally had a chance to inspect an SR in real life. I was very impressed by the trim level, particularly the interior, which is more of a monochromic black, without the silver accents if the higher levels. The truck I looked at was a DC, which solidified my decision to hold out for a crewmax. The truck I looked at was sold, but I could have reserved an Identical truck due in at the end of the month. If I were presented with an SR and an SR5 that ticked the boxes, it's be a tough call.
