SR Trim
Discussion in '3rd Gen Tundras (2022+)' started by TicTacx, Dec 4, 2021.
  1. Apr 14, 2023 at 11:06 AM
    #301
    SR4x4DC
    SR4x4DC New Member
    Because Toyota engineer said it did not. He said it wasn’t needed for SR because for what it is rated to tow which is 8300 lbs, that isn’t enough weight to push the driveline cooling. The torque converter will stay in lockup and the tranny temp will stay within the range.
  2. Apr 14, 2023 at 11:09 AM
    #302
    SR4x4DC
    SR4x4DC New Member
    Toyota engineer said for what the SR is rated to tow which is 8300 lbs, that isn’t enough weight to push the driveline cooling. The torque converter will stay in lockup and the tranny temp will stay within the range.
    Now I don’t know what that means in plain English but that was his explanation for why the SR didn’t need a trans cooler.
    I wonder if there still is one integrated as you mention since it’s an automatic.
  3. Apr 14, 2023 at 11:51 AM
    #303
    4mm
    4mm New Member
    Francisco
    2015 Sequoia
    Perhaps an external cooler isn’t needed.
  4. May 26, 2023 at 7:20 AM
    #304
    rst
    rst New Member
    how many SRs do they produce?
    is it possible to get production numbers by trim?
    trying to figure out wait time after asking dealer to allocate one
  5. May 30, 2023 at 3:32 PM
    #305
    yooperbikemike
    yooperbikemike New Member
    2022 SR5 TRD OR Premium CM 5.5
    An admittedly unscientific method would be to do a nationwide search on Cargurus. CG shows a grand total of 108 (2 and 4wd) SR against roughly 1800 SR5
  6. Sep 27, 2024 at 4:00 PM
    #306
    HB_Tundra
    HB_Tundra New Member
    2023 SR DC
    Does anyone know what the rear ring gear size is for a 2023 SR Double Cab? Did they use the same 10.5" as the 2nd gens? I want to get a PowerTrax LSD and that only comes in 10.5" ring gear size.
  7. Oct 20, 2024 at 7:52 PM
    #307
    Treeviper
    Treeviper New Member
    Daniel
    2021 4runner
    Hybrid tires, mud flap delete, crossbars
    Does anyone have pics of upgraded tires on the stock 18" steel wheels?
  8. Oct 25, 2024 at 3:17 PM
    #308
    Treeviper
    Daniel
    2021 4runner
    I'm going to pull the trigger on a 2025 Tundra SR crew max 4x4. I have a few questions for current SR owners.
    1. Do they all have spray in bed liner over the composite bed? Not crazy about this.
    2. Do they all have locking glove boxes? If so, where's the key?
    3. Do the tailgates lock when you lock the truck like the SR5 does?
    Woocawachie likes this.
  9. Oct 27, 2024 at 11:09 AM
    #309
    Woocawachie
    Woocawachie New Member
    Dickens
    Philadelphia
    2023 Tundra Limited CM 6.5. WindChillPearl
    1. No sprain on, at least not stock. I’m sure you can add it as an option. 2. The glove box in front of the passenger seat does have a lock, the key is in your key FOB. 3. Yes, when you hit the lock button on your key fob all the doors including the tailgate locks.
    Treeviper[QUOTED] likes this.
  10. Oct 27, 2024 at 11:10 AM
    #310
    Woocawachie
    Dickens
    Philadelphia
    Just get the premium wheels on the marketplace here. That’s what I did. Also got a deal on a grill. Hard to tell that it’s an SR trim
  11. Oct 28, 2024 at 2:58 AM
    #311
    Treeviper
    Daniel
    2021 4runner
    Thanks for the replies. I'll post my mods/progress as I add things to the truck.
    4mm likes this.
