SR (Factory) Navigation Antenna Solution
Discussion in '2.5 Gen Tundras (2014-2021)' started by Slag_Dynamics, Jan 16, 2023.
  1. Jan 16, 2023 at 8:19 AM
    Slag_Dynamics
    Slag_Dynamics [OP] Cut. Weld. Repeat.
    Arizona
    Gone
    Do you have a 2014-2019 SR Model Tundra?
    Did you purchase a later model (Bigger Screen, etc) Entune Head Unit with Navigation, only to realize everything is plug and play but you don’t have a factory GPS antenna?
    WELL! This happened to me too.
    I searched the Internet for a solution and only found universal Amazon work-arounds that did not use a factory style connector and were just held in place by friction. I read several threads where people had used them without issue, but I wanted something more secure.
    The factory Tundra GPS Antennas were $250+ on EBay and I exponentially more through the dealer.
    I did some research on the connector and came to find (as expected) a lot of Lexus models utilize the same style GPS connector on their Antennas.
    I searched EBay for the best deal on a Lexus GPS Antenna with the WHITE connector I could find.
    I found a decent deal (Average Price is Approx. $60 on EBay) on a GPS Antenna out of a 2015-2017 Lexus RC-F (Part Number: 86860-53070)
    The part arrived with a plastic mounting tray and the Antenna mounted to a piece of metal. The antenna plugged directly into the back of the stereo and I mounted it on the tray behind the stereo under the speaker grill in the dash. I turned the stereo on and it immediately began searching for GPS signal. I drove around a bit and the GPS calibrated after about 10 or so miles and is extremely accurate.
    LONG STORY SHORT:
    A GPS Antenna out of a 2015-2017 Lexus RC-F (Part Number: 86860-53070) will work, plug and play, in a 2014-2019 Toyota Tundra.
    Hopefully this helps someone.
    **Also, I ended up winning the bid on a second one if anyone is interested in purchasing it from me, shoot me a PM.**
