Squirrel Damage
Discussion in '2.5 Gen Tundras (2014-2021)' started by d_kinneyjr, Feb 11, 2024.
  1. Feb 11, 2024 at 2:29 PM
    d_kinneyjr
    d_kinneyjr [OP] New Member
    Dave
    Southern NH
    2018 Crew Max SR5
    Does anybody know what the circular object behind the air intake box is? It has the name Denso on it. Apparently a squirrel chewed the wire that connects from the engine harness to this mysterious object. I have no dashboard lights going off, and truck runs fine. This is a brand new engine harness. Just got the truck back Friday night after 2 weeks of not having it. Previously the squirrels had caused $9k worth of damage. Good thing for vehicle insurance. Squirrels chewed up 8-10 wires of the engine harness. Tour to hell the insulated engine / hood cover.
    First 3 pictures are from today. Last couple of pictures are from 2 weeks ago
    Thanks for the help in advance.
    vtl likes this.
  2. Feb 11, 2024 at 2:38 PM
    Retired...finally
    Try your horn
    Mr Badwrench likes this.
  3. Feb 11, 2024 at 2:41 PM
    d_kinneyjr
    Dave
    Southern NH
    2018 Crew Max SR5
    That’s what I thought as well. Horn works perfectly fine.
  4. Feb 11, 2024 at 3:00 PM
    Retired...finally
    Sound the same? Two tone?
  5. Feb 11, 2024 at 3:04 PM
    pursuit2550
    pursuit2550 New Member
    Its the alarm horn.
    Retired...finally likes this.
  6. Feb 11, 2024 at 3:05 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    Security horn
  7. Feb 11, 2024 at 3:11 PM
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    Time for 0.22LR
  8. Feb 11, 2024 at 3:56 PM
    huntertn
    huntertn New Member
    Tennessee
    2008 White CrewMax Limited 4x4
    Is it 4WD? Is so, does it work? Mine is 10 years older but a squirrel chewed a green wire on the passenger side fender well and it was for the ADD.
    Squirrels are very destructive.
    Edit:
    I looked up the number on that Denso thing (ND-012). Comes up as a low horn
  9. Feb 12, 2024 at 6:48 AM
    CaptRatBoy
    CaptRatBoy New Member
    Somewhere around 2500' Western Blue Ridge, NC
    Capeable, extensively modified, 2016, Limited, 4 x4 Tundra Off Road, 3td. one
    Got a positive I.D. on the Perp's: cop talk .... kinda looks like a bit more diminutive rodent damage .... mice? Try setting a trap line around the garage. Ya get enough of them ya can make the Mrs. a coat.
  10. Feb 12, 2024 at 7:03 AM
    d_kinneyjr
    Dave
    Southern NH
    2018 Crew Max SR5
    @pursuit2550, @empty_lord, @huntertn
    Thanks for the information. Security horn it is. Never knew there were 2 horns (regular & security horn). Learn something new every day. Appreciate the help. Now I just have to splice the wires together.
    pursuit2550 and empty_lord like this.
  11. Feb 12, 2024 at 8:47 AM
    PKFan
    PKFan my pronouns are (she/it) - c'mon, say it fast
    2018 Inferno! DC SR5 4x4
    Tyger Blade running boards, Valhalla's Shield cat plates
  12. Feb 12, 2024 at 8:55 AM
    d_kinneyjr
    Dave
    Southern NH
    2018 Crew Max SR5
    @PKFan, thanks. I will order this today. I already have installed an ultrasonic deterrent that plugs into the battery, moth balls and cut up Irish Spring soap in bags. What's one more smell / taste added. Can't be too careful I guess, especially after already paying $9k (insurance paid - but sure my payments will go up).
  13. Feb 12, 2024 at 9:14 AM
    PKFan
    Honestly, I think the snap traps did the most good, as they seemed to eliminate the problem squirrels. But I still do the bitter apple occasionally just in case. I also did an ultrasonic unit, as I more recently have had mice or rats messing with the insulation around the manifold and that seems to be doing the trick.
    On a side note, I'm originally from southern NH myself.
    d_kinneyjr[OP] likes this.
  14. Feb 12, 2024 at 11:05 AM
    2014 Black tundra
    2014 Black tundra New Member
    2014 tundra sr5
    If you use snap traps and get about 5-6, you could make a nice batch of squirrel potpie. :yes:
  15. Feb 12, 2024 at 12:05 PM
    TundraMidwesterner
    TundraMidwesterner What?
    Northern Illinois
    2019 Magnetic Gray Metallic CrewMax TSSOR 4x4
    Katzkins, Rostra heated seats(4), Tint (all), TRD rear sway bar, TSS wheels, OEM black lug nuts and wheel locks, OEM LED black fog lights, Driver side grab handle, Rough country LED Bumper bar, Rough Country Hard tri fold tonneau cover, AVS ventshades, Bilstein 5100's on top setting in front, Ready lift 1 inch ready block in the rear with Bilstein 5100's. Fluid Film. ESP under seat storage. LED interior lights and cargo lights swapped. Rear USB charger port swapped for 12v port. Remote start. Leather wrapped steering wheel kit. TRD shift knob. Kenwood dmx1037s. Hertz K170 door speakers/ tweeters, Infinity Reference 7005A 5 channel amp, 2 JBL WS1000 10 inch subs. DDI Seat Jackers. RCI engine Skid and Vahalla's Shields (front and rear) 1/4 aluminum. Stillen intake. LED Pro Headlights with iHacker harness. Cartrimhome auto up and down window switches. Coupe's aluminum battery tie down. Color matched mirror caps. Color matched door handles. Chalk bag cup holder. NFab podium step bars, herculined. Powerstop z36 drilled slotted brake discs w/ceramic pads.
    I started using peppermint oil in my boat for winter storage and I spray under the hood of my truck every 3 months or so. I soaked a few dryer sheets in peppermint oil and shoved them into the trailer frame on my snowmobile trailer because I had to redo the wiring. knock on wood*, its worked so far.
    rodent sheriff on Amazon:
    https://www.amazon.com/RODENT-SHERI...keywords=rodent+sheriff&qid=1707768077&sr=8-5
    I know there are posts on here about where to put some wire mesh under the windshield lower cowl to keep critters from being able to get to the top of the cabin airbox. I haven't done that yet but i keep thinking about it. There are also some posts about the engine wiring harness getting chewed up. I'm not so sure soy based wire insulation was as great an idea as someone thought it was.
    https://www.tundras.com/threads/mouse-rodent-proofing-stage-one.44679/
  16. Feb 12, 2024 at 12:18 PM
    sulli155
    sulli155 New Member
    Ryan
    This is your only viable solution
  17. Feb 12, 2024 at 12:27 PM
    d_kinneyjr
    Dave
    Southern NH
    2018 Crew Max SR5
    @sulli155, the thought did cross my mind! :quickdraw:
    grant.ducckk likes this.
  18. Feb 12, 2024 at 2:21 PM
    XR5dude
    XR5dude New Member
    2021 Tundra
    Had this happen on my previous truck two years ago. Chewed through a wire on harness to a fuel injector. Got a notice on my Ford Pass app that cylinder one was misfiring, looked and noticed the chewed wire and a bunch of foam insulation on top of the engine. I had some pepper spay and fluid film sitting around so used that and never had another problem. Sprayed the fluid film where on places they would need to climb to get up into the engine bay and some pepper spray on the harness and chewed up foam. I figured some fluid film on the harness wouldn't hurt either. Never had another issue. I'm going to do that now as preventive. Once they get that oil on their feet or get a whiff of the pepper spray they should stay clear
