Squealing brakes when in reverse
Discussion in 'New Member Introductions' started by 4x4 work horse, Dec 6, 2022.
  1. Dec 6, 2022 at 2:22 PM
    4x4 work horse
    4x4 work horse [OP] New Member
    2000 toyota tundra limited 4x4
    Hi Everyone , I'm a newbie here, but Im looking for a solution to my problem. In 2008 bought
    a 2000 Tundra 4x4 and it has been an exceptional vehicle. About 3 or 4 months ago , the brakes started squealing pretty loud when in reverse . Have brake shoes in rear and disks in front. What could be my problem?
  2. Dec 6, 2022 at 3:33 PM
    Johnsonman
    Johnsonman New Member
    Austin
    Sequoia
    So is the noise only first backup of the day or all day long? It is common in humidish areas for surface rust to develop on rotors overnight and the first scrape of the day is a little noisy. Could be dirt in system (rinse it down) or maybe a rock shield bent slightly out of shape. After that, I'd take it apart, inspect, lube moving parts (slides) and re-install if OK. Luck.
  3. Dec 6, 2022 at 7:45 PM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
  4. Dec 7, 2022 at 12:11 AM
    NickB_01TRD
    Nick
    KY
    01 Tundra V8 4X4 AC SR5 TRD
    Mine does that. I put new pads and rotors on since I needed them anyway and the new ones do it the exact same as the old. Only does it sometimes and only on the first backup of the day.
    FrenchToasty likes this.
  5. Dec 7, 2022 at 7:17 AM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    very common with toyotas and often in just the first reverse of the day. Post number 2 above, corrosion forms and gets scraped off, not sure why it happens more in revserse vs forward but it does. No issue unless you are having brake noise, vibration, etc all the time.
  6. Dec 7, 2022 at 7:41 AM
    ProtoJ
    ProtoJ New Member
    2018 Crewmax TRD Off-Road
    My 2018 has always done that...the colder it is, the more it squeaks in reverse.
    jtwags likes this.
  7. Dec 7, 2022 at 8:13 AM
    4x4 work horse
    ProtoJ, so there is not much that can be done to correct this condition?
  8. Dec 7, 2022 at 8:58 AM
    ProtoJ
    ProtoJ New Member
    No idea…..I just saw it was common and didn’t worry about it. My neighbors Gen 1 tundra does it when he backs out of the garage too!
  9. Dec 7, 2022 at 9:15 AM
    jtwags
    jtwags Concrete jungle
    League City, TX
    2018 Tundra CM
    Undercover Elite LX, Xact Contour
    X2^ same thing
