Squeaky sound when steering after lift.
Discussion in 'Suspension' started by marlon671, Oct 25, 2017.
  1. Oct 25, 2017 at 10:37 AM
    marlon671
    marlon671 [OP] New Member
    Marlon
    2017 MGM Tundra SR5 4x4
    Soooooo. After about a week or so after my lift installation, I noticed a very little squeak when I turn the wheel. It only happens when Im either at a stand still or going at really low speeds like backing into a parking spot which is how I discovered it. Also only present on the drivers side. It wasnt present till a week after my lift install. Im thinking possibly a bolt or nut rattled loose after putting on some miles so I plan on going under and re-torquing bolts to spec. One thing I may have done was just zapping back my axle nut and not torquing with a torque wrench. I remember zapping it and thinkin, "hey the hole lines up with the castle nut so this must be it".. So ill probably check that first.
    With that said, can anyone confirm if 245 ft/lbs of torque is the correct torque for the axle nut?
    Also, if anyone has had this experience please tell me how you fixed the issue or pointers on what I should double check.
    Thanks! Heres the video.
    https://www.youtube.com/watch?v=ZBwGyu6As6k
    Gi-Josean likes this.
  2. Jun 15, 2018 at 7:54 PM
    Jessecocozza
    Jessecocozza New Member
    Jesse
    Sarasota, Florida
    2017 DC 4x4 SR5
    5” zone lift 20x10 Fuel Maverick 35x12.5x20 Toyo RT
    I have the exact same creaking sound after my lift was installed. We’re you ever able to sort this out?
  3. Aug 27, 2020 at 8:08 PM
    Gi-Josean
    Gi-Josean New Member
    Josean
    2019 Tundra TRD PRO
    I have the same problem. Did you fix it?
  4. Aug 27, 2020 at 8:29 PM
    tmart
    tmart New Member
    Travis
    My sound didn’t sound quite like yours but it’s so easy it’s worth a shot. I greased the sway bar end links and my noise stopped
  5. Aug 27, 2020 at 8:30 PM
    tmart
    tmart New Member
    Travis
    Mine was a 7 inch bds by the way
